Cutting Lexan?
Old February 15th 04, 01:36 AM
Scott
Default Cutting Lexan?
If I cut Lexan on a bandsaw, what is the best way to sand out the cut marks
along the cut line? Sand paper? File? I want to make a new windshield and
the cut edge will be the top of the windshield (open cockpit).
Scott
http://corbenflyer.tripod.com/
Building RV-4
Gotta Fly or Gonna Die
Old February 15th 04, 02:28 AM
JDupre5762
You could start with a file if necessary and then go to abrasive paper.
Depending on how the file works start with say 200 grit paper and sand until
the texture of the lexan is uniform before moving on to a finer paper. Do this
till you have gone up to 1000 grit at least. Then get some crocus cloth and
use it wet. I was taught that at this point use one piece of crocus cloth and
use it up till it is gone. After that you can use toothpaste with pumice or
make a solution of chalk dust and turpentine with either apply with your finger
tips.
After the toothpaste the edges of the lexan should be as clear as the rest of
the surface. The important thing is to never move on to a finer grit until the
entire edge is uniform. We did this in A&P school and it will work. Don't
know of any mechanical techniques that will do as well.
John Dupre'
Old February 15th 04, 03:53 AM
rip
File smooth, and then use an oxy-hydrogen torch with a soft flame. This
will give an instant flame polished edge. See your local plastic
supplier if you're not equipped to do this solo.
Rip
Scott
Building RV-4
Old February 15th 04, 05:01 AM
Morgans
"Scott" wrote in message
marks
and
Scott
Building RV-4
Make a template out of medium density fiberboard. sanded to the exact size
you want the windshield to be, then cut the windshield a hair larger than
the template. Use a pattern tracing bit in a router (ball bearing),
variable speed, if possible, run at a fairly slow speed.
If it is a long straight line, a jointer works great. Try it on a scrap.
You will be impressed.
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.580 / Virus Database: 367 - Release Date: 2/6/04
Old February 15th 04, 05:09 AM
Bill Daniels
"rip" wrote in message
news
Rip
Right on, Rip. This is the slickest, easiest, most professional way to get
clean, clear edges on Lexan and Plexiglas. If you are really quick with
the torch, you can de-burr drilled holes this way too.
Bill Daniels
Old February 15th 04, 09:59 PM
Orval Fairbairn
news
Rip
And -- if you are NOT quick with the torch? It is safer to use the
filing/ sanding/polishing technique.
Old February 15th 04, 11:09 PM
Bill Daniels
"Orval Fairbairn" wrote in message
news
news
This
Rip
get
with
Safety has nothing to do with it. Just practice on scrap plastic until you
get the hang of it just like everything else you have to learn building an
airplane. Rip is talking about little more than a match sized flame. It's
a damn useful skill to have and it virtually eliminates any stress risers
that will cause the plastic to crack later.
Bill Daniels
Old February 16th 04, 02:04 PM
plasticguy
marks
and
Scott
Building RV-4
Scott.
I manufacture lexan windshields and acrylic canopies.
If you want to work lexan, and I don't think you do, none of the methods
mentioned by other guys will work. Lexan will not flame polish with a
torch.
Sanding lexan after sawing will take an ENORMOUS amount of effort to
get back to clear, if you can. Using a router giives you a better edge if
you
are tooled to do it. Remember to tape the plastic so the router base
doesn't
mar the plastic. When we cut one-offs, we bandsaw and disc sand with 36
grit
discs and finish with a sheet metal deburring tool. Really does a nice job,
but
the edge will not be clear.
If on the other hand you are talking about ACRYLIC/PLEXIGLASS, then most
of what you have read is applicable. Flame polishing adds huge residual
stresses
to the sheet. Filing in many cases causes chipping when the teeth are too
large.
Sanding gets you real close, but SCRAPING is the best. We prefer to use
routers
on our acrylic parts, but when making one-offs, we bandsaw, disc sand 36
grit,
usa sanding boards at 80 grit and go straight to scraping with a $5 craftics
tool
or piece of tool steel. There isn't a better way to get the edge finished.
We
have to re-sand the scraped edges at 2000 grit but it doesn't buy you that
much.
Call me at the shop if you need to know more.
Scott
SPEKTR PRODUCTS
817-573-2972
Old February 17th 04, 06:51 PM
Ron Natalie
"Scott" wrote in message ...
Are you sure you want to use polycarbonate rather than acrylic?
best cutting fluid/oil/paste 2004..... theory and practice? B2431 Home Built 1 January 20th 04 07:27 PM
Cutting sheet steel Ernest Christley Home Built 28 November 28th 03 07:58 PM
air drill question Ded Dog Home Built 24 November 24th 03 11:43 PM
blue foam & cutting it Richard Riley Home Built 6 November 24th 03 02:53 PM
canopy breaking tool? Russell Duffy Home Built 33 October 1st 03 12:39 AM
