c-152 rudder???
Old December 16th 04, 11:44 PM
Which is what would happen. Any control surface falling off is a
death sentence.
Besides, the rudder is part of the vertical surface contributing to
lateral stability. The airplane would be inclined to fly sideways
without the rudder. Some aircraft, like my Jodel and many of the Zenair
airplanes, have no fixed vertical surface and rely almost entirely on
the rudder for stability.
Dan
Old December 17th 04, 01:13 AM
houstondan
ok, that's something new for me. all i know to do is just look to see
if everything seems connected and wiggle it a little. can you please
talk a little more about how to really check the rudder.?
dan....oh, and thanks!
Old December 17th 04, 02:09 AM
Michael
Any control surface falling off is a death sentence.
I know a pilot who lost a control surface in a 150 Aerobat who will be
very surprised to hear it. Rumors of his death are highly exaggerated.
Michael
Old December 17th 04, 02:19 AM
Newps
Losing a rudder would be no big deal. Losing one aileron doesn't render
the aircraft unflyable, lose both and you'd have to drive with the
rudder. Losing one or both flaps isn't a big deal.
Old December 17th 04, 04:33 AM
Dave Stadt
death sentence.
Not.
Dan
Old December 17th 04, 11:21 AM
nuke
BRBR
I once watched a pipe line patrol hop in a 152, start it up and take off -
missing an aileron. So much for a careful pre-flight. Came around the pattern,
taxied back, shut her down and walked away.
Dr. Nuketopia
Sorry, no e-Mail.
Spam forgeries have resulted in thousands of faked bounces to my address.
  #28
Old December 17th 04, 02:38 PM
Henry and Debbie McFarland
"clyde woempner" wrote in message
I have had our 150/150 for many years. It is a solid honest airplane and I
used it for 8.5 years to commute, about once/twice a month, from the L.A.
area to the Eureka area. With the tip tanks this was a non stop flight
with
enough reserve for another hour. With the prop pitched for cruise, I was
able to throttle back to 2100 RPM and cruised at 110 mph. At this setting
I
burned 6.5 Gals/hour
I have a C-85 with 0-200 insides in my Luscombe 8E. I cruise at 110 mph and
climb about 1000 fpm. I have a standard prop (1A90 at 7151). I burn 5.5 gph
consistently. I carry 27.5 gallons of fuel so my range is longer than I can
endure without a stop.
I can carry 75 lb baggage, but it's hard getting 75 lbs back there! I do use
my airplane to camp regularly.
Deb
1946 Luscombe 8A (His)
1948 Luscombe 8E (Hers)
1954 Cessna 195B, restoring (Ours)
Jasper, Ga. (JZP)
  #29
Old December 17th 04, 03:24 PM
Grab the bottom of the rudder and pull back and down a bit to see if
the hinges are worn. The rudder pedal springs hold the rudder forward
and the slop isn't readily evident during a normal preflight. See if
you can wiggle the bellcrank in the rudder, or if there's any
deformation of the metal that it's attached to. Some nervous pilots
are in the habit of standing on the pedals with tense leg muscles,
putting a lot of strain on the bottom end of the rudder. Some people
have their airplanes tied down outside in strong winds and the rudder
gets bashed against the stops, beating things up.
Dan
  #30
Old December 17th 04, 03:31 PM
Missing a control surface is different than losing one in flight.
Cables are pretty strong and might tend to hold on until something else
breaks, and in the meantime there's a lot of unusual drag and flapping
around going on. I sure wouldn't want to be aboard. A Cessna's aileron
pushrod would probably bust right of and let the aileron go, but a
rudder would be a different story.
I'm an aircraft mechanic and a pilot. I hear stories that make
me look at things closely. I have a mechanic friend who did some
experimental reasearch on the cable breakage of Cessna 185 flap control
system. They disconnected the LH flap and tried to see, in flight, what
might happen if one was down and the other up. They were just able to
keep it level with full aileron as the RH flap came all the way down.
He said that if that cable broke suddenly at low level on approach
there would be no way to control the airplane; it would roll over right
away.
Dan
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 10:43 AM
P-51 Rudder Aerodynamics Hawkeye Hughes Home Built 1 March 15th 04 09:24 AM
rudder cable question Bob Loer Home Built 7 November 26th 03 08:34 AM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 04:14 PM
