#31
#32
No, it wouldn't, but it's still not safe. If things are that
worn and beat up, what else on the airplane is waiting to bite someone? Further, if a pilot inadvertently enters an incipient spin because of mishandling, he will, if trained properly, use opposite rudder to recover, and he might do it fast and hard and get rudder lockup and control loss. In Canada spin training is mandatory for Commercial students. The airplanes have to be maintained properly, like they should be anyway. I see lots of horror stories when I look at some neglected airplanes that are still being flown, and wonder why there aren't more accidents. Dan |
#33
#34
![]() wrote: AD forcing modification of the stops. A student and instructor were killed when the rudder locked hard over when entering a practice spin and they couldn't stop the rotation, thereby preventing spin recovery. btw, according to the accident report (you should be able to find it somewhere on www.tsb.gc.ca), the student didn't die, but did sustain serious injuries, since they spun into a lake. And if you haven't read the accident report, there was a bunch of stuff, including a rudder return spring missing, that contributed to the rudder jamming hard over. They couldn't get the rudder to jam over when it was just a worn stop bolt, but they recommended an SB for the stop bolt anyhow. It's well worth the read, rick ps: And it was a C150, not C152. |
#35
A broken rudder return spring won't contribute much, if any, to
the stop-locking problem, but it will make the airplane fly cockeyed unless you hold pedal pressure against the good spring. We used to run two 150s, and had (and still do have) springs break at various times both in the 150s and 172s. The pilot complains of really bad rudder trim. The rudder cable tension is determined by the springs, and isn't very high at any time. As I said earlier, the stop bolts don't wear that much. It's worn hinges and loose bellcranks that allow the little hook on the stop to ride past the bolt head and get caught. Ironically, it's the same little hook that's supposed to prevent the override. Seeing a good stop doesn't mean there's no problem. There are likely very few 150/152s like this, but it's worth getting it checked at annual. The new stops have no hook and are much longer and wider, and the stop bolt has a larger head. Dan |
#36
Losing the rudder cleanly would probably be survivable as students have
been ignoring it for years. However, I contend that losing both the rudder and the vertical fin would almost certainly cause a crash. Any use of the ailerons in that circumstance would create a slight amount of adverse yaw moment that would have almost no reaction surface. The fuselage rear cone (especially on a later small tailcone diameter 150s) would not be very effective restoring moment just at the time when you would want to use a lot of the ailerons to get a semblance of steering. There is redundancy in the aileron system. There is no redundancy in the rudder/fin system. I do recall a picture in Aviation Week many years ago though that showed a B-52 with the whole vertical fin and rudder gone from a thunderstorm. Otherwise it would be the Sioux City DC-10 accident all over again but without the possibilities of differential engine thrust. No thanks. |
#37
The Cessna's aileron control system uses bellcranks in
the wings, with pushrods from the bellcranks to the aileron, and cables from the bellcranks to the control wheels. A departed aileron would hopefully take the rod off and leave the airplane, and the bellcranks should continue to operate. If the rod didn't fail, or iff the bellcrank was damaged, the whole system would be fouled up. An airplane such as a Cub, or my Jodel, that has cables directly to the ailerons, would have no aileron control at all if one aileron failed. All the cable tensions are gone. You might have control in one direction, and not the other. Dan |
#38
The issue on the 150/152 is the vertical stabilizer attachment and not
the rudder. See http://www.cessna150-152.com/acs-vtab.htm Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
#39
Well, there we are. The FAA isn't concerned about the rudder stops;
only Cessna and the Canadian Government are. The fin attach is what the FAA wants looked at, and it seems to be age-related as the rate of SDR reports comes up. They also mention horizontal stab spar cracking, which has been an issue in 172s for years and is (in the 172, at least) often caused by folks pushing down on the stab to turn the airplane on the ground. I would anticipate many more issues arising as the fleet ages. Our older 172s are beginning to show the odd crack here and there, and Cessna sends out Service Bulletins that we take seriously and we often find problems where they tell us to look. There are 172s here in Canada with almost 20,000 hours on them, still flying, but they require watching. I don't think Cessna ever intended them to last so long. I wish new ones cost less. Dan |
#40
![]() wrote: A broken rudder return spring won't contribute much, if any, to the stop-locking problem, but it will make the airplane fly cockeyed unless you hold pedal pressure against the good spring. We used to run two 150s, and had (and still do have) springs break at various times both in the 150s and 172s. The pilot complains of really bad rudder trim. The rudder cable tension is determined by the springs, and isn't very high at any time. Well, the report is at http://www.tsb.gc.ca/en/reports/air/...4/a98q0114.asp and it clearly states that they were only able to reproduce the case where the rudder jammed past the stop bolt by removing the rudder return spring. It's about 2/3rds of the way through the document, after all the stuff about CARs violations. (It sounds like slackness of the rudder cable was the deciding factor.) It also required up elevator to allow it to go past the stop bolt(but of course that would be the case when doing an intentional spin). Interesting reading. Oh, and I was incorrect before, it was a C152, rick |
B2 Split Rudder | Emilio | Military Aviation | 8 | April 12th 04 10:43 AM |
P-51 Rudder Aerodynamics | Hawkeye Hughes | Home Built | 1 | March 15th 04 09:24 AM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
Rudder cable - was The Little Wheel in Back | BD5ER | Home Built | 9 | September 11th 03 04:14 PM |
