Our first annual last year increased our plane ownership cost by 50%
(engine overhaul, prop governor overhaul + few other big ticket replacement parts + labor). When Rick and I tallied up all the things we want our AP to do this year, it looked like we have to reach deep into our pockets again. Here is the list 1. Replace the dry vacuum pump with an Airwolf wet pump + Air/oil separator(~$2500 not including labor - our AP estimated 1-2 days!). Our original plan was to get a new dry pump (the existing one has been spewing some carbon) + Precise Flight backup pump. Since we intend to get instrument rating and may attempt IFR traveling (probably mostly soft IFR), we think that the wet vacuum option would be a wiser choice and may even out the initial cost in the long run. 2. Replace all side windows and the back window. The windshield seems to be in good shape although our AP thinks that we will not like it as much once the other windows are replaced! Of course, we will also want to use the opportunity to add a photo window. This will most likely cost at least $1K not including labor (luckily our AP allows owner-assisted manual). 3. Replace the passenger seatbelt with shoulder harness/seatbelt. We replaced the pilot/copilot belts last year. The cost will be reasonable ($250 or something) but probably will take a bit of labor (will try to this ourselves again). 4. Install a cigarette lighter with multiple plugs. Probably will not cost much but this is something we must ask our AP to do. 5. Replace the two wingtips and one stabilator tip: ~ $1K in part. Not sure about labor. We can either do this now during the annual or let the paint shop do it. The same goes with the nose bowls. Our AP patched them up a bit last year but more extensive restoration will be required for the new paint job. One of the paint shops gave an estimate of $1K for the nose bowl job. 6. Miscellaneous stuffs: Attempt to reinstall the door bracket. Our AP tried it once but a previous repair attempt left some rivets in the wrong place so he had to pop the new bracket out. Pitot/Static/Transponder check: just hope that we don't have to replace anything else! Not sure of the cost. Last summer, Rick got the plane weighed (after we replaced some avionics and added thermal/sound insulation) and had the prop rebalanced. I was surprised to learn that it cost over $500 to weigh the plane but less than $200 for prop balancing. Replace the throttle control (again, just hope that it would be a minor job with minimum cost). Our annual is scheduled for Feb 15. I'm pretty sure we will think of few more items by then. The list above and the paint job (current estimates ranging from $10-$12K) will pretty much preclude us from taking any expensive vacations this year. There go most of our dive trips this year. Just hope that my 92 Honda Accord with over 230K miles will last few more years. A Garmin 430 is most likely on the list for next year. I am trying to convince Rick that with two pilots in the family, we don't need 'no stinking autopilot' ;-). Not sure whether this argument will hold when we face turbulent in IMC after getting our instrument tickets. Speaking of IFR training, I had thought of doing either a West Coast Adventures Trip with Field Morey or an East Coast IFR Trip with Dough Stewart. http://www.ifrwest.com/ http://www.dsflight.com/about.html No doubt that either one will be a tremendous learning experience and we will be much better pilots (and hopefully with instrument ratings) but those trips ain't cheap either. Maybe I should buy a lottery ticket ;-) Hai Longworth N30703 |
![]() wrote in message oups.com... years. A Garmin 430 is most likely on the list for next year. I am trying to convince Rick that with two pilots in the family, we don't need 'no stinking autopilot' ;-). Not sure whether this argument will hold when we face turbulent in IMC after getting our instrument tickets. Unfortunately your typical GA autopilot will be the first thing to quit in turbulence. Still the single best IFR accessory you can have though. -cwk. |
In article . net,
"Colin W Kingsbury" wrote: wrote in message oups.com... years. A Garmin 430 is most likely on the list for next year. I am trying to convince Rick that with two pilots in the family, we don't need 'no stinking autopilot' ;-). Not sure whether this argument will hold when we face turbulent in IMC after getting our instrument tickets. Unfortunately your typical GA autopilot will be the first thing to quit in turbulence. Still the single best IFR accessory you can have though. I agree. Even a simple one which can do nothing more than hold heading is extremely useful. Most planes will do a pretty good job of holding altitude on their own (if you get the trim set right), but will slowly turn one way or the other if you let go of the controls for more than a few seconds. Having something that can hold heading means you can re-fold a chart, dig out an approach plate. or copy down a clearance without wandering all over the sky. It also means you can think about big-picture stuff like evaluating a decaying weather situation or estimate the effect of a re-route on your fuel state. |
$500 to weigh your plane? Yikes! You need to cultivate a relationship with your local EAA chapter. Those guys usually have scales, which they will usually part with for a few hours in exchange for a reasonable "fee". Like a case of good beer, or a fine bottle of Scotch... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() wrote in message oups.com... Our first annual last year increased our plane ownership cost by 50% (engine overhaul, prop governor overhaul + few other big ticket replacement parts + labor). When Rick and I tallied up all the things we want our AP to do this year, it looked like we have to reach deep into our pockets again. Here is the list 1. Replace the dry vacuum pump with an Airwolf wet pump + Air/oil separator(~$2500 not including labor - our AP estimated 1-2 days!). Our original plan was to get a new dry pump (the existing one has been spewing some carbon) + Precise Flight backup pump. Since we intend to get instrument rating and may attempt IFR traveling (probably mostly soft IFR), we think that the wet vacuum option would be a wiser choice and may even out the initial cost in the long run. 2. Replace all side windows and the back window. The windshield seems to be in good shape although our AP thinks that we will not like it as much once the other windows are replaced! Of course, we will also want to use the opportunity to add a photo window. This will most likely cost at least $1K not including labor (luckily our AP allows owner-assisted manual). 3. Replace the passenger seatbelt with shoulder harness/seatbelt. We replaced the pilot/copilot belts last year. The cost will be reasonable ($250 or something) but probably will take a bit of labor (will try to this ourselves again). 4. Install a cigarette lighter with multiple plugs. Probably will not cost much but this is something we must ask our AP to do. 5. Replace the two wingtips and one stabilator tip: ~ $1K in part. Not sure about labor. We can either do this now during the annual or let the paint shop do it. The same goes with the nose bowls. Our AP patched them up a bit last year but more extensive restoration will be required for the new paint job. One of the paint shops gave an estimate of $1K for the nose bowl job. 6. Miscellaneous stuffs: Attempt to reinstall the door bracket. Our AP tried it once but a previous repair attempt left some rivets in the wrong place so he had to pop the new bracket out. Pitot/Static/Transponder check: just hope that we don't have to replace anything else! Not sure of the cost. Last summer, Rick got the plane weighed (after we replaced some avionics and added thermal/sound insulation) and had the prop rebalanced. I was surprised to learn that it cost over $500 to weigh the plane but less than $200 for prop balancing. Replace the throttle control (again, just hope that it would be a minor job with minimum cost). Our annual is scheduled for Feb 15. I'm pretty sure we will think of few more items by then. The list above and the paint job (current estimates ranging from $10-$12K) will pretty much preclude us from taking any expensive vacations this year. There go most of our dive trips this year. Just hope that my 92 Honda Accord with over 230K miles will last few more years. A Garmin 430 is most likely on the list for next year. I am trying to convince Rick that with two pilots in the family, we don't need 'no stinking autopilot' ;-). Not sure whether this argument will hold when we face turbulent in IMC after getting our instrument tickets. Speaking of IFR training, I had thought of doing either a West Coast Adventures Trip with Field Morey or an East Coast IFR Trip with Dough Stewart. http://www.ifrwest.com/ http://www.dsflight.com/about.html No doubt that either one will be a tremendous learning experience and we will be much better pilots (and hopefully with instrument ratings) but those trips ain't cheap either. Maybe I should buy a lottery ticket ;-) Hai Longworth N30703 I don't see an annual inspection anywhere in the list. |
![]() " wrote: I was surprised to learn that it cost over $500 to weigh the plane but less than $200 for prop balancing. It cost me $60 to have my Cessna weighed about 11 years ago. George Patterson The desire for safety stands against every great and noble enterprise. |
![]() Dave Stadt wrote: I don't see an annual inspection anywhere in the list. Dave, We don't expect the annual inspection by itself cost more than $500 or so with an owner-assist annual. We pretty much had all the airworthy stuffs taken care off at last annual and throughout the year (for example, we found a cracked muffler pipe while opening the cowling to rotate the spark plugs last month and had our AP replaced it). Jay, Yep, we did not know our AP had a guy flown in from LI to do the weighing. He charged something like $150 just for the travelling cost! If we had known that, we would have checked around for a more reasonable price. |
![]() "Jay Honeck" wrote in message news:bRGGd.10570$IV5.417@attbi_s54... it cost over $500 to weigh the plane $500 to weigh your plane? Yikes! You need to cultivate a relationship with your local EAA chapter. Those guys usually have scales, which they will usually part with for a few hours in exchange for a reasonable "fee". Like a case of good beer, or a fine bottle of Scotch... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" Hi Jay... Our chapter BOUGHT NEW DIGITAL SCALES last year and spent 1200 bucks or so on them. 4 pad unit for race cars, nice stuff. I can't believe the prices folks get to do this. Scott. |
![]() Maule Driver wrote: It all sounds like good stuff but it's more of a set of small upgrades than an annual. MD, The most likely real annual job is the vaccum pump replacement. With the expected life of dry pump being 500hrs and the fact that they sometimes die without any advanced warning steered us toward the 2000hrs-life wet pump instead of getting a new dry pump + the Precise Flight backup system. You are right that these are more of a set of upgrades than what needed for an annual but an annual downtime is a good opportunity to 'upgrade' and fix little things which are not exactly airworthiness issue but can give us a peace of mind such as adding shoulder harnesses to the backseat, going with a more reliable pump etc.. When we first looking into buying a plane two years ago, we never thought of having to continue pumping greenbacks to it. It's almost like an addiction, you keep having the urge to feed the habit ;-) I had thought of delaying the paint job until next year so that we could spend on the IFR trips. Last weekend in seeing little flakes of paint came off while we were cleaning snow and ice of the poor Cardinal, I swore that I could hear our pet bird crying "I need a new plumage"! Hai Longworth |
Christmas Annual - long drivel | Denny | Owning | 23 | December 31st 04 08:52 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 03:41 PM |
another year, another annual | Doug Vetter | Owning | 4 | November 22nd 03 11:40 AM |
'Good' Annual This Year | Ben Smith | Owning | 38 | July 26th 03 05:44 AM |
