Challenger Crashe at TEB
Old February 6th 05, 05:24 PM
Blueskies
"Stefan" wrote in message ...
Blueskies wrote:
Runways are selected to assure the ability to accelerate to V1 and then stop with maximum braking.
Isn't it the other way round: The runway length defines v1?
Stefan
Well, yea, gross takeoff weight and density altitude, etc control define V1, so you could look at a runway then decide
the max weight allowable for that day. You need to be sure that the runway is long enough to accel to V1 then stop...
  #62
Old February 6th 05, 05:26 PM
Blueskies
George Patterson wrote:
No mention of the fact that the deceleration produced by barriers like that
would have killed everyone on board this aircraft had they been in place.
Maybe, maybe not, I don't know. But if that plane would have hit a school bus full of kids when crossing the road
and/or that warehouse would not have happened to be empty at that time, I bet the airport would already be closed
right now.
Stefdan
I don't think so...
  #63
Old February 6th 05, 05:27 PM
Blueskies
"George Patterson" wrote in message ...
Jon Kraus wrote:
It looks like the Challenger skidded off the runway and crashed into a
warehouse at TEB.
Yesterday, NPR news stated that the mayor is pushing for reducing the number of
flights at TEB and installing "foam crash barriers" at the ends of the runway.
George Patterson
He who would distinguish what is true from what is false must have an
adequate understanding of truth and falsehood.
Build some sort of ramp thing that would carry the plane up and over the road as it stops, like a runaway truck ramp
  #64
Old February 6th 05, 06:42 PM
Matt Whiting
warehouse at TEB.
Yes, but more voters drive cars on the hiqhway going past TEB than fly
out of it. That is all that matters to politicians.
Matt
  #65
Old February 6th 05, 07:00 PM
Andrew Gideon
Blueskies wrote:
Quite often Vr is faster than V1...
Knowing this, but being only SE rated, I've a question:
It seems that certain problems become apparent only at Vr. So why not use
that as the "size of runway/weight of aircraft" factor?
I'm also curious as to whether the aircraft in this accident gets the same
type of runup as do the little Cessnas I fly. One part of this is always
pulling the yoke back and confirming elevator movement (in the proper
direction).
- Andrew
  #66
Old February 7th 05, 02:48 AM
Gary Mishler
"Matt Whiting" wrote in message
Blueskies wrote:
I've never heard of a modern bizjet using control locks, but I suppose
there are some that do.
Every one I have ever flown does, but I have not flown Challengers. I would
be they do though as they have to have wind gust protection while parked.
  #67
Old February 7th 05, 02:50 AM
Gary Mishler
"Doug Carter" wrote in message
om...
Don't turbine aircraft POH's require sufficient runway length to stop
after an abort?
Yes, but an abort is predicated prior to or at V1 (takeoff decision speed),
not after the higher Vr (rotate speed).
  #68
Old February 7th 05, 02:52 AM
Gary Mishler
"Blueskies" wrote in message
m...
By definition Vr is never less than V1.
  #69
Old February 7th 05, 03:20 AM
Don Hammer
Gary,
The challengers have dampers that come into effect when there is no
boost pressure. On Falcons, the hydraulic actuators essentially lock
up with no pressure. Neither require any other locks. If memory
serves, Gulfstream locks the rudder only.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
  #70
Old February 7th 05, 12:19 PM
Gary Mishler
"Don Hammer" wrote in message
Gary,
Thanks for the clarification. All the ones I have flown are cable actuated
and they of course have gust locks. Even so, one of our Lears had the
rudder stops beat up when a Falcon parked right behind us blew our rudder
around, even with the gust lock installed. Ouch.
Challenger forum Dico Reyers Home Built 0 December 30th 03 06:48 PM
Ignoring the Challenger? robert arndt Military Aviation 0 July 1st 03 10:24 AM
