Challenger Crashe at TEB
Old February 2nd 05, 01:24 PM
Jon Kraus
Default Challenger Crashe at TEB
It looks like the Challenger skidded off the runway and crashed into a
warehouse at TEB. Isn't this the same kind of plane that crashed on
takeoff in Colorado? It looks like the plane remained intact so
hopefully the passengers and crew are OK.
http://www.foxnews.com/story/0,2933,146112,00.html
Jon Kraus
PP-ASEL-IA
'79 Mooney 201 4443H
Old February 2nd 05, 04:17 PM
kage
"Jon Kraus" wrote in message
takeoff in Colorado? It looks like the plane remained intact so hopefully
There are no leading edge devices on a Challenger. Bombardier made it cheap
to buy, but that wing is very clean. I'm betting on an emergency AD for
winter operations.
Karl
Old February 2nd 05, 06:39 PM
Aaron Coolidge
In rec.aviation.owning kage wrote:
: There are no leading edge devices on a Challenger. Bombardier made it cheap
: to buy, but that wing is very clean. I'm betting on an emergency AD for
: winter operations.
Kind of like the DC-9-10 series, eh? What, 5% of the DC-9-10 fleet crashed
on take off because of wing contamination?
Even more similar to the Fokker F-28 series, a similar size & weight
aircraft (well, compared to a DC-9, anyway). Crashes at Dryden and La Guardia
because of wing contamination. The Fokker report says that one 1mm ice
particle per square centimeter of wing reduces lift coeficient by at least
22%.
Aaron C.
Old February 3rd 05, 01:18 AM
Guardia because of wing contamination. The Fokker report says that one 1mm
ice
22%.
This is one of the few safety advantages of light piston singles. When you
reach takeoff speed in a single, pull back, but the plane doesn't want to
fly for whatever reason, you will most often have ample runway left to abort
the takeoff (assuming a runway of 3500 ft or longer). And if you do run off
the end, it will be at low speed, so chances are there will be no injuries.
In a jet, once you exceed V1 on takeoff you are committed. Then if the
plane won't fly at Vr, due to wing contamination or some other cause, you
are screwed unless you are on an exceptionally long runway.
-Elliott Drucker
Old February 3rd 05, 04:12 AM
Capt.Doug
"kage" wrote in message I'm betting on an emergency AD for
winter operations.
There was no visible moisture. The sky was crystal clear. The only wing
contamination possible would have been light frost on the bottom of the wing
where the fuel had cold-soaked after landing- if the plane had made a
quick-turn. No other aircraft had requested de-icing. I doubt that the cause
was wing ice.
D.
Old February 3rd 05, 02:09 PM
Peter R.
quick-turn.
Interesting that I have read the "there was no visible moisture" point a
few times in relation to this crash. Based on my experience, no visible
moisture is no guarantee.
I only have about 750 hours of flying in the Northeast US, but during this
short time I have experienced three different situations where frost
appeared over top of the entire aircraft (twice in a C172 and once in a
Bonanza) within 10 minutes of landing in weather that was crystal clear, no
visible moisture.
This happened twice at Niagara Falls and once in Plattsburgh, NY. In all
cases, the sun had either just set or had been down a few hours and outside
temperatures were well below freezing (10 degrees F or so).
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
Old February 3rd 05, 03:56 PM
Gary Mishler
"Capt.Doug"
wing
cause
was wing ice.
Frost on top of the wings, and more importantly - on top of the T-tail is
highly likely. I have flown a T tail jet for 25 years and you can get frost
on top of the wings and tail very easily in the early morning with the right
conditions.
Old February 3rd 05, 04:17 PM
Joe Johnson
To Peter R. and Gary Mishler. Say for sake of argument that the pilots
missed a thin layer of frost. If discovered, are there any remedies short
of a full, formal deicing?
Old February 3rd 05, 04:26 PM
Peter R.
I am not qualified to answer as I have no experience in anything greater
than a single engine piston aircraft.
That said, when my aircraft was frosted over in those three incidents, my
only fly-able option was to request a complete aircraft deicing.
Fortunately, in all three cases the line crew was available, had the deice
fluid nearby, and did it for free. I tipped them generously.
If deicing were not an option, I would have had to get a hotel and wait
until the frost melted off the next day, or some liquid deicing were
available. In no case would I have attempted to take off with it on the
wing surface.
Peter
Challenger forum Dico Reyers Home Built 0 December 30th 03 06:48 PM
Ignoring the Challenger? robert arndt Military Aviation 0 July 1st 03 10:24 AM
