gliding back to your departure airport
Old October 23rd 03, 12:41 PM
David Megginson
Martin Hotze writes:
My examiner showed me at the ppl exam some 180 degree turns with a
C172 at climb-out speed and he lost less than 100ft altitude.
A standard-rate 180-degree turn takes one minute, so even ignoring the
higher wing loading in the turn, a power-off descent rate of less than
100 fpm doesn't make sense for a 172. Which climb-out speed was he
using, Vx, Vy, or enroute climb? If he had enough extra speed, he
could have traded some of it for altitude, but that runs out pretty
fast.
All the best,
David
  #32
Old October 23rd 03, 01:52 PM
Jeff Franks
There was a good article in Plane & Pilot (i think) a few months back about
making your mind up about these kinds of problems well before you need them.
Especially if your flying from your "home" strip, you should already know
where you'd put it down if you lost the engine and you already have the
go/no go altitude in your brain before you depart. If your below your limit
when the engine quits, you don't second guess yourself, you just push over
to best glide and land straight ahead (or as close to it as possible).
It also mentioned that you should consciously fight the urge to save the
plane or "get back to the runway". The kneejerk reaction is to think that
if we can just get back to there, then everything will be ok.
I have a close friend who was an experienced pilot (IFR rating - 6
years of flying - owned his own plane) and had engine failure on
takeoff and did not make it back to the airport. He was practicing a
short field take off which probably didn't help the situation but
impacted terrain about 1/4 mile short of the runway (he hit power
lines that were right next to this airport). Anyway, he died of
injuries from the crash. The wing sheared during the impact dumping
fuel into the cockpit and started a bad fire but fortunately death
occurred upon impact.
Reports placed him at about 700 ft of altitude when engine failure
occurred but it could have been lower than this value.
  #33
Old October 23rd 03, 04:21 PM
Mike Rapoport
Then he lost a lot of airspeed.
Mike
MU-2
"Martin Hotze" wrote in message
"Mike Rapoport" wrote:
Not unless you are planning to glide straight ahead. You will lose a
lot of
altitude in the turn.
My examiner showed me at the ppl exam some 180 degree turns with a C172
#m
http://www.crunchweb.net/87billion/
  #34
Old October 23rd 03, 05:50 PM
David Megginson
fast.
well it worked. and I survived :-)
How about details? What was the entry airspeed and exit airspeed, and
how did he make the turn?
All the best,
David
  #35
Old October 24th 03, 11:12 PM
JerryK
In the sim at Flight Safety, we did these type of turn at 45-60 degrees.
"David Megginson" wrote in message
fast.
All the best,
David
Historic Helsinki-Malmi Airport in trouble - please read Seppo Sipilä General Aviation 0 December 24th 04 09:04 AM
STAR to nearby airport Viperdoc Instrument Flight Rules 33 May 13th 04 10:48 PM
The battle for Arlington Airport begins? Paul Adriance Home Built 45 March 30th 04 11:41 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
Student Pilot Stories Wanted Greg Burkhart Piloting 6 September 18th 03 08:57 PM
