Transponder check-How much?
Old November 22nd 03, 07:36 PM
Ron Natalie
"Robert Moore" wrote in message . 6...
"Ron Natalie" wrote
Did that include the IFR static/altimeter test as well. The
combo runs about $200 from the reputable shops around here.
Because the transponder check involves 2-3 regulations in various
parts of the FAR, the avionics shops have discovered a loophole
that "they say" allows them to do the transponder check without
including a static/encoder check.
Loophole? If you fly VFR only you only need the transponder itself
inspected. The standard question here is whether you need it cert'd
for IFR.
Old November 23rd 03, 02:17 PM
mike regish
Nope. This is a strictly VFR plane. I don't even have an AI. No VOR
receivers either.
mike regish
m...
"mike regish" wrote in message
news:74zvb.206727$ao4.733788@attbi_s51...
I just got a bill for $185 from the guy on my field. Seems kind of
steep.
Did that include the IFR static/altimeter test as well. The combo runs
about $200
from the reputable shops around here. Much more at Capitol Avionics.
Old November 23rd 03, 03:03 PM
Viperdoc
It costs $200 here in Wisconsin, and was about the same in Indiana (Fort
Wayne). This was a transponder and pitot static check.
Old November 25th 03, 02:20 AM
Matthew P. Cummings
On Fri, 21 Nov 2003 19:38:50 -0600, Matt Ketcham wrote:
Just paid 200 for a IFR. Our shop doesn't differentiate between IFR and VFR
checks.
The shop I use charges $60 for a VFR check, and $180 for an IFR check.
There is more work to the IFR check as I understand it.
Old December 1st 03, 11:57 PM
Robert M. Gary
"Matthew P. Cummings" wrote in message gray.net...
checks.
You don't need any pitot-static check for VFR. However, even in the
Aeronca (no electrical) we used to have it checked. Good to know if
you're really at 1000 feet.
Old December 2nd 03, 12:00 AM
Robert M. Gary
checks.
BTW: I was scheduling a checkride for a student this summer and asked
her to ensure her transponder check was current (she only flys VFR).
We found the last one was more than 5 years ago and her checkride was
the next day. She got really lucky to find a shop to do it. The reason
I thought to double check was because the examiner called me up to
tell me of this last minute opening because some "fool" showed up for
his private checkride without a current transponder inspection. !!
Probably the most overlooked inspection for the VFR pilot. Since the
ELT usually gets done by the IA during annual, people assume the
transponder is too. The problem is that the average IA isn't licensed
to do the transponder check.
-Robert, CFI
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
transponder check? Russell Duffy Home Built 10 August 14th 03 11:36 PM
Use of hand-held GPS on FAA check ride Barry Piloting 3 August 9th 03 10:14 PM
Use of hand-held GPS on FAA check ride Barry Instrument Flight Rules 1 August 9th 03 09:25 PM
