"Jay Honeck" wrote in message news:7oiFb.618964$Fm2.558042@attbi_s04...
With built-in flight timers becoming the norm in virtually all new avionics (heck, even the new transponder I'm getting has one), just wondering if folks are migrating away from using hobbs/tach time to record their flight time? I can't think of any reason to stop using the hobbs. I don't have to leave the avionics on after the flight to check the GPS time, the hobbs is always right there as I'm closing the door. I also use my hobbs to track the time I've spend on each tank (even though I have an EDM fuel flow computer). The hobbs seems like a perfect, simple device. |
14CFR Part 1
Sec 1.1 Flight time means: (1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing; or Ok, so I'm at Dulles. I start up, release the brakes, and start the timer. Start taxiing (it takes forever at Dulles), do my runup, am sixteenth behind a row of jumbos, have to hold a while for IFR release, andforty minutes later the tower tells me position and hold. (not too far off for some flights!). Cleared for takeoff, I accelerate to flying speed, but something isn't right, so I abort the takeoff and taxi back to the ramp and shut down. It's been an hour and eighteen minutes. Do you log it as 1.3? Do you log it if you actually managed to get three feet in the air for twelve seconds before aborting the takeoff and landing again on the mile of runway remaining? Jose -- (for Email, make the obvious changes in my address) |
Tom Sixkiller wrote:
At what point can one start recording _Flight Time_? Engine start? First master switch? I could'nt find anything in the FARS for "when" to start counting, but I am under the impression from my experiences, that anytime the prop is turning is the time you count. Allen |
In article 7oiFb.618964$Fm2.558042@attbi_s04, Jay Honeck
wrote: And if you *are* using the flight timer, have you stopped using the old archaic "1.3 hours" method of recording flight time? Anyone using actual hours and minutes in their logbook instead? I do. I log the following: Hobbs start/Hobbs stop Tach start/Tach stop Clock start/Clock stop Wheels off/Wheels on |
"Teacherjh" wrote in message
... It's been an hour and eighteen minutes. Do you log it as 1.3? Do you log it if you actually managed to get three feet in the air for twelve seconds before aborting the takeoff and landing again on the mile of runway remaining? If your intent was flight (even if you didn't get off the ground), then my understanding is that you can indeed log it. |
![]() "Tom Sixkiller" wrote in message ... At what point can one start recording _Flight Time_? Engine start? First master switch? Since we are talking pilot time (we have bounced back and forth here), the rules say: elapsed time form the time the aircraft first moves under its own power for the purpose of flight until the time it comes to rest at its . Since my plane rears forward a little bit at engine start, and I don't tend to run it for very long when I finally get fully parked, the ENGINE RUNNING (hobbs) time is usually pretty danged close to the definition. |
![]() "A Lieberman" wrote in message ... Tom Sixkiller wrote: At what point can one start recording _Flight Time_? Engine start? First master switch? I could'nt find anything in the FARS for "when" to start counting, but I am under the impression from my experiences, that anytime the prop is turning is the time you count. Flight time is defined in part 1. |
news:7oiFb.618964$Fm2.558042@attbi_s04... snip And if you *are* using the flight timer, have you stopped using the old archaic "1.3 hours" method of recording flight time? Anyone using actual hours and minutes in their logbook instead? Well, most of my flying of late has been towing banners, and the Cubs don't have ANYTHING electrical in 'em. I look at my watch after I start the engine write it down on my sheet, go pull the left chock, walk to get the right one, then hop in and go. When I shut down, I write down that time as well. Then I have to go back and convert from HH:MM to HH.(MM/60) for my logbook. -- Mike |
Ron Rosenfeld wrote:
You didn't look at the beginning: 14CFR Part 1 Sec 1.1 Flight time means: (1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing; or (2) For a glider without self-launch capability, pilot time that commences when the glider is towed for the purpose of flight and ends when the glider comes to rest after landing. Thanks Ron, Guess gliders don't have props!!! Helps to look at the "whole picture"! Allen |
Hobbs start/Hobbs stop Tach start/Tach stop Clock start/Clock stop Wheels off/Wheels on Why do you log four different times? And *where* do you log them? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
p3/95 | [email protected] | Military Aviation | 1 | September 27th 04 12:27 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
