Calibrating temperature probes
Old January 11th 04, 10:26 PM
Casey Wilson
Default Calibrating temperature probes
Background first: Two significant points exist for calibrating a
temperature probe or thermometer without comparing it to a known probe or
thermometer -- freezing and boiling points of water. For the freezing
point, one mixes up a slush of ice and water, the probe should read zero
degrees centigrade when immersed in the liquid. For the boiling point, stick
the probe in a pot of boiling water and it should read 100 degrees. Except,
of course, for the barometric pressure. We all know water boils at lower and
lower temperatures (?? 3 degrees per 1,000 feet??) as altitude is increased.
Question: Why doesn't the same pressure effect occur for the freezing
point?
Oh yeah, to make this an aviation related topic consider calibrating a
temperature probe or thermometer to use as a reference to check the OAT
gauge in your plane once in a while. You all do that now and then, don't
you?
Old January 11th 04, 11:03 PM
Peter Duniho
"Casey Wilson" wrote in message
point?
I believe it does. If I recall correctly, the pressure from the blade of an
ice skate is what melts the ice and allows the skate to glide easily across
the ice. However, it requires a much greater change in pressure to make the
same change in freezing point, so it's not relevant for your purpose.
All off the top of my head...look it up if you really want to know.
Pete
Old January 11th 04, 11:17 PM
Julian Scarfe
stick
Except,
and
increased.
point?
It does. For a phase change, there's an equation called the Clapeyron
equation that shows how the temperature varies with pressure.
dT/dP = T deltaV / deltaH
where deltaV is the volume change and deltaH is the enthalpy change (think
of it as energy and you're not too far off) of the phase change.
(It sort of makes sense that the pressure variation of the phase change
depends on what the volume change is. If there's no volume change it
doesn't really matter what the pressure is, as everything happens in the
same space.)
For water - steam, deltaV is very large, so the variation of T with P is
significant.
For ice-water, deltaV is tiny, so the variation of T with P is miniscule.
At about 130 atmospheres, the melting temperature of water drops by 1 degC.
Julian Scarfe
Old January 11th 04, 11:20 PM
Julian Scarfe
an
across
the ice.
I don't doubt your recall, Peter, as I'm sure I was taught the same.
However, check out:
http://www.physlink.com/Education/AskExperts/ae357.cfm
Julian Scarfe
Old January 11th 04, 11:55 PM
Peter Duniho
"Julian Scarfe" wrote in message
However, check out:
Interesting. Oh well...
I'm at least relieved to find that it is indeed the case that the melting
point changes with pressure, and that it changes very little. It just
changes a lot less than I even suspected.
The explanation on that page *is* a little confusing though. I think they
got their math right, but the wording is odd. They start out talking about
the reduction of freezing point, but then later talk about an increase in
the temperature of the ice. The two are not really the same, even if they
result in the same effect.
Pete
Old January 12th 04, 03:31 AM
L Smith
point?
It does. It's just that the melting point curve is a lot steeper than
the boiling point curve,
so it takes a lot more pressure for the same effect.
An interesting experiment can demonstrate the effect. Suspend an ice
cub between
two supports. Loop a fine wire over the ice cube, and use it to suspend
some significant
weight (say 0.5-1 pounds). After some time the wire will be in the
middle of the ice
cube, with ice above and below it. After even more time, the wire will
"cut" through
the cube and fall out the bottem, leaving behind a solid block of ice.
(The pressure
of the wire on the ice raises the melting point, so that the ice in
immediate contact
with the wire becomes liquid. After the wire passes that spot, the
melting point
returns to normal and the water re-freezes.
Rich Lemert
Old January 12th 04, 03:36 AM
L Smith
point?
The vapor pressure of ice (and ice -water mix) is effectively 0.
Irrelevent! The melting point involves an equilibrium between the
solid ice and the liquid
water. The vapor is totally irrelevent (except at the triple point,
where all three phases
are in equilibrium).
Rich Lemert
Old January 12th 04, 03:42 AM
john smith
Julian, that's the complex answer. Remember PV=nRT?
This is what I use...
Change it to PV/T=nR
From this you can write:
(P1V1)/T1=(P2V2)/T2
same space.)
significant.
Julian Scarfe
Old January 12th 04, 06:24 AM
Morgans
of
an
across
the ice.
However, check out:
Julian Scarfe
I don't buy the physicist's argument. Blades are curved, so there is likely
ten times less surface area on the ice.
Jim in NC
Old January 12th 04, 06:41 AM
Peter Duniho
"john smith" wrote in message
PV=nRT does not apply to solids or liquids. Hell, it barely applies to
gasses, since they rarely are "ideal".
Pete
Total Air Temperature question Mike Rapoport Instrument Flight Rules 12 December 14th 04 06:20 PM
Total Air Temperature question Julian Scarfe General Aviation 6 December 14th 04 06:20 PM
Total Air Temperature question Mike Rapoport General Aviation 5 December 11th 04 09:30 PM
'Room Temperature' Anthony Home Built 11 August 23rd 04 07:36 PM
Wanted to Buy/Trade: CTH Bayonet Type Probes aRKay Aviation Marketplace 0 August 14th 04 03:40 PM
