Total Air Temperature question
Old December 10th 04, 04:21 PM
Mike Rapoport
Default Total Air Temperature question
"Peter" wrote in message
Hi,
I fly a TB20 and a friend who has the same one with a Shadin air data
computer tells me that he normally gets (say 160 ktas, 10k feet, ISA)
a TAT value of about 3 degC higher than that returned by the existing
OAT sensor.
I looked up TAT and found info like
http://mtp.jpl.nasa.gov/notes/sat/sat.html
which explains TAT as being Ts (static air temp) adjusted for mach
effects.
This raises two questions:
1) Can one really get a 3 degC difference at such a low speed? I
recall a long thread here from some years ago where it was suggested
the increase is below 1 degC.
Accoring to their website Shadin outputs "True Air Temperature" and on the
MU-2 the Shadin temp is lower than the existing OAT guage which uses a, very
accurate, flush, sensor. I haven't found a definition for "True Air
Temperature" but I think that it is "Static Air Temperature". The MU-2
flight manual has a correction table to convert indicated OAT to SAT and the
temperature output by the Shadin is consistant with what SAT should be.
Keep in mind that your friend's OAT sensor is sees Total Air Temperature and
since it doesn't know its Mach number, it can't possibly produce a corrected
temperature like SAT.
The 3C difference is a function of instrument error. The error is greater
than 3C since the Shadin should be showing a lower temp.
2) What is the use of TAT in the context of icing? Presumably the temp
rise will vary over different parts of the aircraft.
If the TAT is above freezing then you won't get much ice but it can still
form. Keep in mind that it is SAT that determines the temperature of the
droplets. You could be flying in -10C (SAT) with a +1C (TAT) and the
supercooled drops would cool the leading edges below 0C and ice would form
(If the mass of the -10C dropplets was large enough to cool the surface
faster than the 1C air could heat it). It would melt off pretty quickly
once you were out of the cloud though since it would be exposed to +1C. I
heard once that if you can go 400kts IAS then airframe icing is imposible. I
forget where I saw this. Yes, the temperature rise varies with location on
the airplane with leading edges and areas of increasing cross section seeing
more temp rise.
MU-2.
Old December 10th 04, 07:16 PM
Julian Scarfe
OAT sensor.
a) 3 degC is exactly what you'd expect between SAT (the temperature of the
air as measured by a thermometer at rest) and Total Air Temperature at 160
KTAS (and it's approximately quadratic in speed)
but
b) Mike is, of course, quite right in suggesting that the "existing OAT
sensor" is not measuring the SAT! It too is affected by the compression
heating of the air.
Neglecting lift for a moment, there are two extremes for the temperature of
the aircraft. Where the air is brought completely to rest, the stagnation
points, the temperature should be the TAT. The air itself outside the
boundary layer is at the SAT. Other parts of the aircraft will have
temperatures in between. If the part is a flat wall parallel to the airflow
and has no heating or cooling other than from the air, it will be heated
above the SAT by about 85% (the recovery factor) of the TAT-SAT. The
recovery factor for a thermometer placed elsewhere will depend on its
location and geometry, but generally speaking the thermometer will measure
an OAT closer to the TAT than the SAT. For a conducting skin, it's a fair
approximation that the skin will be at the TAT.
Where the pressure is lowered, for example on the upper surface of the wing,
the temperature also falls because of that. Thus it is possible for runback
to freeze with the TAT above freezing. The cooling effect depends on wing
loading: for a typical light aircraft the effect will not exceed 1 degC,
while for big jets, you may find a part of the wing 10 degC cooler than the
sensed OAT.
Julian Scarfe
Old December 10th 04, 07:30 PM
Mike Rapoport
Julian, do you know the meaning of "True Air Temperature"? I don't but this
is supposedly what the Shadin ADC outputs. See:
http://www.shadin.com/specs/adc_200.htm
MU-2
"Julian Scarfe" wrote in message
OAT sensor.
but
heating of the air.
of
airflow
wing,
runback
sensed OAT.
Julian Scarfe
Old December 11th 04, 09:11 PM
Julian Scarfe
ink.net...
this
I don't, I'm afraid. Like you, I've not come across True Air Temperature
before.
I looked briefly at a couple of the brochures on the Shadin site after you
posted, and saw mention of True Air Temperature in one, Total Air
Temperature in another. Maybe Peter knows which model the ADC was?
Julian
Oil Temperature sending unit Corky Scott Home Built 2 October 19th 04 12:58 AM
'Room Temperature' Anthony Home Built 11 August 23rd 04 07:36 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
