#11
"Peter Duniho" wrote in message ...
"Dale" wrote in message ... It kept the prop from dissipating the heat applied to the engine by my pre-heater. Interesting. I didn't realize so much heat could be transferred through the crankshaft. I guess it makes sense though...the prop does have a lot of surface area, so heat flow is easy to have. There's an AD against Lycomings of 160 HP and over using fixed-pitch props that demands an inspection of the internal bore of the front end of the crank. This end stays pretty cool when the engine is running, even in warm weather, and the low temp causes condensation to form in that bore, which is open to the crankcase, and the water and oil form acidic sludge that eats pits in the bore and weakens the crank. I think there has been only one failure so far, though a lot of cranks have been found with the pitting. Constant-speed props use that bore (plugged off at the rear) to feed oil to the prop, so it's not a problem. And I suppose a composite or wooden prop would be much better, not wicking away so much heat. Dan |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
This week's AW&ST: apparently THAAD will have some ABM (as in anti- *ICBM*) capability. | Scott Ferrin | Military Aviation | 29 | August 31st 04 04:20 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Metal Prop vs. Wood Prop | Larry Smith | Home Built | 21 | September 26th 03 07:45 PM |
