Leaving all engines running at the gate
Old February 3rd 04, 06:40 PM
John
Default Leaving all engines running at the gate
Recently at SJU I saw an IB A340-600 arrive from Madrid that left all
four engines running during the 2 hours that it was at the gate before
continuing to Santo Domingo. After all the passengers got off the
entire crew, both cabin AND cockpit crew got off and went to the
transit lounge for about an hour before returning to board for the SDQ
leg. All this time the engines were left running. In fact, they
never stopped running the whole time they were at SJU. I have never
seen an airliner do this before and was wondering if something was
wrong with this particular aircraft or if this is some kind of new
"windmilling" feature on the new A346 or something. Perhaps related,
I've heard that IB have had a horrible experience with their new A346s
and this particular aircraft, EC-INO (Gaudi), the first one they
received, is said to have given then more headaches than all the
others.
What circumcstances would make an airline leave a plane guzzling gas
for such a long time on the ground?
Old February 3rd 04, 07:53 PM
Larry Fransson
Just about none. You couldn't have any ground crew anywhere near the
aircraft doing the usual ground crew stuff (loading/unloading baggage, etc)
with engines running. And nobody in their right mind would leave engines
running without somebody on the flight deck to mind the aircraft.
It seems more likely to me that it might have been very windy at the time
and that the windmilling of the engines along with the noise from the APU
might have given the appearance of having engines running.
Larry Fransson
Seattle, WA
Old February 3rd 04, 08:33 PM
snowy squirrel
If you could see the engines turning, it means that they were shut off and
just slowly turning due to wind.
It would be very hard for maintenance personel to get near the aircraft with
all 4 engines running. And I suspect extremely hazardous (if not illegal) to
refuel while engines are running.
It is far more likely that what you saw were just engines turning slowly due
to wind.
There are situations where engines on one side are left running in extreme
cold arctic conditions, and all passenger, cargo, fuel is handled from the
other side. This is to ensure that at least one engine is available to
generate sufficient power to restart the second engine.
Old February 4th 04, 12:10 AM
Jim Davis Sr.
"snowy squirrel" wrote in message
due
to wind.
Reminds me of what Steven Wright once said. "I used to own a helicopter,
but had no place to park it, so I tied a rope to it, & left it running."
Old February 4th 04, 01:28 AM
John
to wind.
Nope, those four fans were running at a pretty good clip. No wind
involved there. Besides, with the size of those things, it would take
a hurricane to keep them turning for two hours.
Old February 4th 04, 02:29 AM
Robert M. Gary
The fans you saw were probably being turned by the wind. The noise you
heard was probably the APU running in the back. Its not unusual for a
plane to sit at the gate with the APU running in the tail of the
plane. Its a jet too and sounds like one.
John wrote in message . ..
others.
Old February 4th 04, 02:55 AM
John T
"John" wrote in message
Have you ever turned a turbine engine?
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Old February 4th 04, 03:26 AM
John Gaquin
Rotor sections are *extremely* finely balanced, else they would vibrate the
engine right off the wing at operational speeds. What this means is that
the blade wheels will turn freely with very little force applied. A light
breeze will suffice, no hurricane required. In my experience, more often
than not you'll see these things turning (at least with large fan engines)
if there's any breeze exposure at all.
Regards,
John Gaquin
B727, B747
Old February 4th 04, 03:57 AM
Newps
It takes very little wind to turn the blades.
Old February 4th 04, 04:33 AM
karl
If you could see the blades turning then the engines coudn't be running.
Karl
NS Norfolk Gate 2 NATOPS - All Hands Memorize Immediately! Yofuri Naval Aviation 0 December 17th 04 05:38 AM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 02:34 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
