Lycoming intake preheater
Old June 6th 04, 04:12 PM
Dale Larsen
Default Lycoming intake preheater
Anyone know the reasoning for running the intake tubes through the hot oil
in the sump?
Old June 6th 04, 05:11 PM
Dale Larsen wrote:
: Anyone know the reasoning for running the intake tubes through the hot oil
: in the sump?
1. Make oil not so hot
2. Make package more compact
3. Reduce power
4. Decrease detonation margin.
1&2: good
3&4: notsogood
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old June 6th 04, 07:22 PM
Richard Lamb
Richard Riley wrote:
On Sun, 06 Jun 2004 17:46:41 GMT, Richard Lamb
:And help reduce suceptability to carb icing.
I've always heard that, but how?
Carb ice, AFAIK, results from the air cooling as it accellerates
through the venturi, and from the temprature drop from the gasoline
evaporating. Both of those things happen in the carb, before the
fuel/air mix goes through the hot oil-bath intake tubes.
I'm sure there's some heat conducted from the hot oil pan to the carb
itself, keeping it a little warmer. But does carb ice form downstream
of the carb, within intake tubes, in a Cont?
Probably just via conduction of the intake pipes.
They do get quite warm...
All I said was 'reduce suceptability' - not prevent.
Even Lycomings need carb heat at times, but they don't seem
to be as critical as Continentals.
Richard
Old June 6th 04, 10:18 PM
: On Sun, 06 Jun 2004 17:46:41 GMT, Richard Lamb
: wrote:
: :And help reduce suceptability to carb icing.
: I've always heard that, but how?
: Carb ice, AFAIK, results from the air cooling as it accellerates
: through the venturi, and from the temprature drop from the gasoline
: evaporating. Both of those things happen in the carb, before the
: fuel/air mix goes through the hot oil-bath intake tubes.
: I'm sure there's some heat conducted from the hot oil pan to the carb
: itself, keeping it a little warmer. But does carb ice form downstream
: of the carb, within intake tubes, in a Cont?
That's pretty much the explanation I've heard/accepted. I'm not too familiar
with the Cont. induction system, but I think the carb body isn't heated by bolting it
to the oilpan. I've gotten carb ice in my Lycoming O-360 a couple of times... usually
in classically expected conditions (40-50degrees, foggish, low MP at low altitudes so
lots of expansion)
-Cory
Old June 6th 04, 10:32 PM
Jan Carlsson
Some engine design need to heat the intake side to prevent condense in the
tubes that lead to engines that run rough, this is a normal design on carb
engines, even in cars. it also prevent ice in the tubes but that is not the
main goal, even cars use warm air to heat the intake air in the carburator
and tube, manually changed (winter/summer) or by a thermostat
Jan Carlsson
www.jcpropellerdesign.com
"Dale Larsen" skrev i meddelandet
news:GvGwc.53250$eY2.35696@attbi_s02...
in the sump?
O-235 Lycoming Mods Do B Home Built 2 March 19th 04 02:42 PM
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Lycoming Sued jls Home Built 0 February 13th 04 02:01 PM
Weight of Lycoming O290 Ray Toews Home Built 1 December 21st 03 11:56 PM
Lycoming 320 and EAA Light Sport Aircraft ? Dave Jackson Home Built 29 October 20th 03 01:20 AM
