O-235 Lycoming Mods
Old March 17th 04, 09:59 PM
Do B
Default O-235 Lycoming Mods
Anyone upgraded a O-235-C 6.5 CR 100HP Lycoming using L2C 115HP 9.5 Pistons/Cyl?
If so is it bolt on or is there machining involved?
Any better alternatives? I've heard someone sells high-comp pistons
in the 10.5 CR range.
Thanks!
Old March 19th 04, 02:42 PM
ROBIN FLY
LyCon, in Visalia, (sp?) CA, sells custom pistons at whatever
compression ratio you want.
I am interested in LyCon's pistons for my Conti E225. My stock pistons is 7:1
and LyCon told me that they can make a set for me with 8.6 to 1 as in IO-470N,
or higher CR if I want.
Does anyone have used LyCon's high CR pistons? Do you need to increase fuel
flow or chang inition timing with higher CR pistons?
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? Ron Home Built 2 February 24th 04 04:34 PM
Lycoming Sued jls Home Built 0 February 13th 04 02:01 PM
Weight of Lycoming O290 Ray Toews Home Built 1 December 21st 03 11:56 PM
Lycoming 320 and EAA Light Sport Aircraft ? Dave Jackson Home Built 29 October 20th 03 01:20 AM
lycoming gaskets & parts Paul Home Built 2 October 17th 03 03:49 PM
