Jay Honeck wrote:
However, the part of the question I was referring to was if you *shortened* the prop. Part of the original post implied that you would be able to simply *increase* the engine's redline RPM if you shortened your prop, regardless of engine limitations. I don't believe this is true. I think at that point, you'd be getting into limitations of the engine components (with some tolerance). -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Shorten the prop, lengthen the prop, change the pitch and you will
necessisarily change the placement of the redline on the tach. No you won't. Redline is engine speed related only. Redline has a fixed rpm no matter what you attach or change at the output shaft (in our case a propeller). Take the prop off and use full throttle... the engine will most certainly reach redline, the same redline you had before you removed the prop. Redline speed does not change. The engine has a point where spinning it faster starts floating valves and causing damage. This is a constant speed. If you change the pitch and/or increase size of the prop, the engine won't be able to spin the large prop up to redline. This doesn't mean the engine won't have huge amount of stress on it trying to do so. It won't reach redline, but redline remains at the same speed. Richard "EDR" wrote in message ... Interesting that many have not defined the origin of the placement of the "red line" on the tachometer. I don't know where to look it up, but I suspect it has something to do with prop tip speed (as one poster mentioned). Change the pistons (bore); change the rods (stroke); change the rings (compression); change the induction system; change the exhaust (back pressure) and you change the torque of the engine, again altering the redline. |
Are You Flying a "Beater?" | Jay Honeck | Piloting | 90 | June 16th 04 11:38 AM |
Contract Tower Program - Discussion Thread | running with scissors | Instrument Flight Rules | 6 | April 22nd 04 04:04 AM |
Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 02:56 AM |
Fuel line thread sealant | Paul Lee | Home Built | 7 | February 26th 04 12:44 AM |
recovery from inverted IMC (a propos of "backup gyros" thread) | Sydney Hoeltzli | Piloting | 4 | July 15th 03 02:00 PM |
