Glass panels: what OS?
Old June 26th 04, 06:09 AM
C J Campbell
"Andrew Gideon" wrote in message
online.com...
C J Campbell wrote:
You could not even go back to the days when only
research facilities and the military had Internet access.
Considering the economic damages caused by each major worm run, that might
not be a Bad Thing. We'd lose a *lot*. But it might be better, in the
long run.
Better for whom? I submit that your protests are essentially the same as
those of the priests when Gutenberg started printing Bibles. Your high
priesthood is threatened now that the unanointed masses have access to
computers and networks. The reaction was violent when personal computers
were first introduced. The IT priesthood constantly warned of the dangers of
personal computing. Most big corporations and government agencies adopted
policies prohibiting employees from using anything but the company
mainframe. Never mind that the IT priests could not deliver what people
wanted: their own spreadsheets and word processors. Employees had to meet
off site in secret to get real work done on their personal computers.
After thirty plus years, nothing has changed. The ancient priesthood still
tries to hold onto its power, railing against the dangers of Microsoft and
Windows and, yes, personal computing. The days of the priests are numbered.
I think that is a Good Thing.
Still, there's a third alternative: safe computing.
Again, safe for whom? Apparently the high priests are concerned only for
their own safety, ie, jobs.
People don't mind using mechanics or A&Ps because we're told it's
necessary.
As a matter of fact, many people do mind.
  #52
Old June 26th 04, 07:00 AM
Peter Duniho
"Teacherjh" wrote in message
necessary.
The difference is, anybody with a nearby library can learn how to fix a
car or
an airplane. This is not true of Windows, or any closed source software.
The
innards of windows are a secret. You cannot be sure of what the operating
system (or any commercial program) is =really= doing.
There is no such thing as "closed source software", not as you describe it.
The operating system is only mysterious to people who don't take the time to
look at the software. 100% of the operating system is delivered to every
person who installs it, and it is right there for anyone to look at.
Deciphering what the operating system does is orders of magnitude harder
than reverse engineering an airplane engine (for example), but it is not
impossible by any means. How do you think independent third parties
discover vulnerabilities in any operating system?
You can be every bit as sure of what the operating system is really doing as
you like. You need only invest the time and effort to do so. Open source
is somewhat easier to review, but the truth is, if you aren't looking at the
compiled machine code that is actually running on your computer, you don't
really know what the software is doing. The high-level C/C++ (or whatever)
code is very useful for giving you a good idea, but only the actual compiled
result can be considered to be a 100% certain description of what the
computer is doing.
Pete
  #53
Old June 26th 04, 07:34 AM
Greg Copeland
Actually, it's the "high priests" which are trying to hold the line
against safe computing because it's a very high, steep, and sliperly
slope. It's the general public and CTO-Q-public which seems to be pushing
the line for that.
Greg
  #54
Old June 26th 04, 07:48 AM
Greg Copeland
necessary.
car or
The
I disagree.
That's a different issue.
The difference is one of practicality and man hours. With even the source
code, it would take man-years to review NT's code, for example. It would
probably take several orders of magnitude more man-years if it all had to
be done as the machine language level. Ack!
Open source
Somewhat? Try, practicle versus nonpractical. Now, consider the number
of C and C++ programmers. Now, consider the number of even semi-decent
assembler and/or machine language programmers around these days. Starting
to see a resource problem?
This is, of course, a valid point. Just the same, a *mostly* moot point
given the openess of today's open source compilers. GNU's compilers, for
example, are self hosting. That means it compiles a compiler, which
it then uses to compile a new compiler. Then, the new compiler is used to
compile another compiler to compare with the previous compiler, to ensure
that everything is built properly. So, about the only way you're going to
get a surprise there is **if**, your current compiler is trojaned AND it's
smart enough to pass the trojan on to the new compiler. That means it
would have to know when it's compiling a new compiler.
Aside from that, compiler bugs are really the only issue to worry about.
Which means, for the vast, vast, vast majority of the cases, source code
is king!
computer is doing.
Basically, short of a hidden compiler trojan, the source is still the
preferred reference, by anyone's measure. The compiled code is only
checked to ensure proper optimizations or to validate unexpected behavior
which may seem to not coincide with the source (compiler bug, for example).
Long story short, there is a world of difference between open source and
closed source software. The biggest being, it's completley unpractical to
even aspire to audit a closed source OS or application of any significant
scope without the source. Chances are, it would be much easier to write
your own software solution rather than attempt to audit a closed source
solution at the machine language level.
Greg
  #55
Old June 26th 04, 08:12 AM
Greg Copeland
On Fri, 25 Jun 2004 14:54:19 -0500, Bill Denton wrote:
I have seen quite a few Linux admins who had to use cheat sheets for even
the most rudimentary Win server tasks. And during the dot.com bust I saw
more than one Linux admin deliberately allow their Windows boxes to
deteriorate so they couild make the Linux boxes look better, and thus
preserving their jobs.
During the .com boom, there where plenty of completely unqualified people
working in IT. People often needed warm bodies to support their 1, 2,
4 business plans. The scales heavily lean toward WIN admins, IMO, but I
have no doubt that there have and are unqualified Linux/Unix admins out
there too. In fact, I've met unqualified HP/UX admins too. A rotten egg doesn't
spoil the whole batch unless you attempt to cook with it.
I have seen applications crash NT workstation and server four or five times,
and I've crashed Win2K Professional twice; once with Flight Simulator. A
couple of years ago I worked for a software company, and a test suite run of
one of our applications brought down two Linux boxes and one Unix box.
Everything can crash.
Granted, but if an application crashes, it's an OS bug. There are many
ways to "bring down" a system, but not all of these are bugs. In many
cases, it's improper configuration or hardware for a task.
And I saw a Win2K server mysteriously begin going BSOD, for no observable
reason. It looked just like a software crash. I worked in the IBM building
in downtown Chicago, where you would expect the power to be good, but it
turned out we were getting power sags which were crashing the machine.
This is exceedingly common. The more machines you get on a circuit, the
dirtier the power is going to become. People often rush to purchase surge
protecters but fail to realize the brownouts are actually far, far worse
for their computer. Not to mention, very common. They often go
completely unnoticed but cause bit-flip errors or even physical gate
damage to some components. I could go on, you I think you get the point.
It
was plugged into the same outlet with a workstation which never had a
problem.
Different CPUs, chipsets, power supplies, and yes, even computing trends,
can all make a significant difference. Not all computers are created
equal.
I did some testing, and discovered that the sags were long enough
to drop the server, but not long enough to effect the workstation. I put in
a UPS; no problem. But as I said, it looked just like a software problem.
How many other hardware problems get blamed on the OS?
I'm sure many.
It's not a matter of which will do the job, it's a matter of which will do
the job best. And there are things that Win will do better than Linux and
vice-versa. And better is not just a matter of benchmarking: in some small
towns you might find 10 Win administrators and zero Linux administrators. In
that case, Linux is totally worthless. It's all a matter of matching the OS
to the need.
Well, my statement assumed everything being equal. But you are right.
I'm a strong believer in the best tool for the job. If your room of a
thousand monkeys only know typewriters, you don't give them word
processors and hope for the best. You have a valid point here.
And I hate to tell you this, there were LAN's long before the Internet
became "prime time". I did my first Windows For Workgroups (NETBUI) network
Done that too. Ohh...you remember arcnet? Hehe. Those were the days.
in 1992, the Internet did not begin to achieve any sort of mass penetration
until 1996 or so. While the majority of the servers may run Unix/Linux, most
of the outbound data quickly goes through a router onto a Windows network,
Well, before the big days of the net, most were military, dod, and
university users, so it was still mostly unix. Granted, as it grew,
windows networks were certainly plugged in.
I agree with you about the increased vulnerability of Windows, but a case
could also be made that the associated protocols, which were designed by
Unix guys, were poorly engineered. Had they been better designed the spam
problems would not exist. I don't make that argument, but if you talk
about Windows vulnerabilities, you also have to consider lacadasical
engineering.
Hehe. I don't think that's fair. IPv4 works rather well for what it was
designed to do. It's just the IPv4 has grown well beyond it's original
design. This is why IPv6 exists. This is why everyone is wanting the
Interent to transition to IPv6. It addresses most every complaint of
IPv4. So, I don't think it's fair to blame the designers if the market
refuses to adopt the correct technology.
Having said that, spam is actualy an issue of the SMTP protocol and not
the IP protocol. Granted, better facilities in IP may of helped. But
let's face it, the current SMTP protocol (and associated RFCs) would be
hard pressed to become more spam friendly. If you insist on pointing a
finger, feel free to point a finger at the right group.
Cheers!
Greg
  #56
Old June 26th 04, 09:23 AM
Dylan Smith
In article , C J Campbell wrote:
Fine, if you have a huge corporation that can afford a bunch of well-paid
admins. Your argument is beginning to sound an awful lot like you don't
think most people should have computers and that you think that the general
public is a menace.
No, I think Windows as it currently stands is unsuitable for the general
public. Windows as it stands is fine in an environment where a corporate
admin can look after the network. It's not the users fault, it's the
fault of Microsoft because the configuration is insecure by default.
Windows as it stands should have at
least the software firewall on *by default* and almost all services
(most services which home users will never use) *off* by default.
Finally, MS has decided to listen and will have the firewall on by
default in Service Pack 2. Security researchers have been saying this
for *years*, and only now is it being done.
In this instance, Windows 98 is better than Windows XP. The real
problems didn't start happening until XP came out. Windows XP was a
retrograde step for home users on the internet - it just allowed them to
be 0wn3d because of all the additional potentially exploitable (and as
it happens, actually exploitable) services that were running.
It's not a problem with the users. It's entirely a problem with Windows.
The users are essentially decieved - it's a nice easy to set up system,
but they've been tricked into having a system that claims to be easy to
use and maintain, but really requires an expert system administrator to
make secure.
That isn't the fault of Windows.
But it IS the fault of Windows. Having a number of insecure services
turned on by default which the vast majority of home users will *never*
use on a network is purely the fault of Microsoft. The PC manufacturers
also have some responsibility to bear - they could have at least thought
about it and set up a reasonably secure disk image when they duplicated
the hard disk loads for their PCs.
In any case, the Macintosh has been easy to set up since the 1980s
(including setting up a Mac LAN) so ease-of-use is hardly a Microsoft
innovation. It's just a pity that the hardware platform wasn't open.
might start asking yourself what would happen if you really got your way.
Maybe you are a bigger threat than the public you despise.
Gosh, you're reading an awful lot into my post that I didn't write. I
don't think I've seen a non-sequitur like that since Lord Tebbit managed
to turn a radio interview on obesity into how the Government was
encouraging buggery!
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
  #57
Old June 26th 04, 09:29 AM
Dylan Smith
Safe for the general Internet-using public. Is it too much to ask that
operating systems designed for personal use on personal computers aren't
set up by default to be running a huge bunch of exploitable server
processes?
  #60
Old June 26th 04, 02:09 PM
David Reinhart
I'm not a big fan of SCO anymore, and I haven't had to work with the SCO UNIX
for about 10 years, but I used to be the SA for the SCO box that ran the plant
that produces all the chemicals used by a major chip maker. I had that system
so tweaked that when I quit they didn't bother to replace me and the system
kept running fine until it was replaced about five years later. They only
called me in "on contract" once in that whole period and that was for a
hardware problem.
Dave Reinhart
Greg Copeland wrote:
On Thu, 24 Jun 2004 23:16:44 +0000, leslie wrote:
Kevin Darling ) wrote:
: However, Microsoft themselves point out that Windows is not a hard
: realtime OS, and should not be used in more demanding applications
: such as fly-by-wire.
http://www.gcn.com/archives/gcn/1998/july13/cov2.htm
Software glitches leave Navy Smart Ship dead in the water |
GCN July 13, 1998
That's actually an application bug and not an OS bug. One interesting
note is that they also highlight that Unix would be a much more reliable
option, which would be true, excluding SCO, and including Linux.
It's also worth noting, that traditionally, all MS OS's have somehow
managed to sidestep the DoD qualification phases. Some cash and palms are
usually suspected to be the reasons. In fact, while I don't have a link
off hand, there is a fairly well known quote, by a DoD (IIRC) guy, which
can be paraphrase as, "If Windows had been forced to go through the same
channels as every other OS, it would of never qualified."
Cheers!
Glass Goose Website revamped wingsnaprop Home Built 0 December 14th 04 02:58 PM
Glass cockpits & Turn Coordinators Jeremy Lew Piloting 2 May 29th 04 06:16 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 01:20 AM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
Lesson in Glass JimC Owning 3 August 6th 03 01:09 AM
