Of parachutes and things
Old July 2nd 04, 01:36 AM
ShawnD2112
Dudley,
Sound advice.
Negative stuff isn't the reason I've decided to get a chute. I've done a
bit of negative but I'm staying away from any of the real stuff until I get
some inverted spin training. No, what's really made me decide were two
things. One is that I've started doing some basic formation work with a
mate. While we're taking it slow and investing in some training, there's
always the risk of something going wrong and someone's airplane touching
someone else's. It's that scenario that makes a chute seem like a good
idea. I've also got a bit of a phobia about fire in the cockpit.
The other thing was a long term re-evaluation of the risks. When I first
started flying the Pitts, I thought about a chute but initially ruled it out
(they're not required for aerobatics in the UK, and, in fact, a lot of guys
don't wear them). I ruled it out because I figured that to open the canopy,
exit the aircraft, deploy the chute, and get one swing in before hitting the
ground, I'd need to be about 2,000 feet up. Well, when competing
andpracticing, I only ever got up that high at the tops of aerobatic
maneuvers, not during the bulk of my flying. So, I figured, if I rarely fly
high enough for a chute to work, what are the chances of being able to get
that altitude if I needed it? Pretty slim, I reckoned, so I thought a chute
was a comfort factor more than a real safety option.
Now, that all said, I'd feel like a real tit if I found myself with an
unflyable airplane and no means to get out of it. So screw all that
misguided analysis above, I'm getting a bailout chute. I guess this is a
case of experience and age teaching one a bit of wisdom? It seems silly to
deny myself an option based on some flawed logic applied in the hangar.
Thanks for the tip on the Softie. I'm going to give them a call tonight.
Cheers,
Shawn
link.net...
ink.net...
Forgot to tell you. Whatever you buy, try it on first and make at least
one flight in it with the Pitts. Don't baby the flight either. Take it
out sustained both ways and see how it feels, especially inverted. Do a
half roll, stabilize there and just hang for a bit and feel it on your
back. You'll know if it's going to do the job for you.
Dudley
Old July 2nd 04, 05:25 AM
Doug Carter
"ShawnD2112" wrote in message ...
How well do the seat packs work in the Pitts? While I have a cushion or two
under me, I didn't think there would be enough room for a seatpack chute.
Obviously I was wrong?
I have three cushions, 1", 2" & 4" thick for each seat bottom (as well
as 1" & 2" back cushions). Combination used depends on pilot height.
I'm 5' 11" and use the 1" in the back seat. Note that the back seat
has the least head room; you can jack up a little higher in the
front.
The advantage of the seat pack is that it keeps you further from the
panel. The panel is a bit close (for me) to begin with.
In the Decathlon I used a back pack with no cushion behind it.
Different seat geometry. In the Yak I used seat packs; they have a
bucket for that.
Hope this helps...
Doug Carter
Pitts S2-C.
p.s. All my friends with S1-S & S1-T single seaters use seat packs as
well. dc
Old July 2nd 04, 05:48 PM
Guenther Eichhorn
I think that practicing aerobatics below 2000' is not really a good idea. A
good friend of mine got killed when he messed up a hammerhead that he started at
1500'. When I practice new maneuvers, I want to be at 4000' to 5000', higher
if they are spins.
As far as the minimum altitude for chute opening is concerned, I believe that
you can get your chute open fromless than 1000', how much less depends on the
circumstances.
Guenther
Guenther Eichhorn |
Smithsonian Astrophysical Observatory, Cambridge, MA
CPL,ASMELS,Glider,LBH,IA,CFI | Pitts S-2A: N1GE
DC-3 type rating | Flying is the Pitts
http://acro.harvard.edu/ACRO
"ShawnD2112" writes:
Dudley,
Sound advice.
Cheers,
Shawn
hlink.net...
ink.net...
Dudley
Old July 2nd 04, 06:40 PM
ShawnD2112
Guenther,
Sorry to hear about your friend, and I appreciate where your advice is
coming from. I agree with you on practicing new maneuvers but when you're
practicing for a competition you have to be able to get your positioning
right. Competition floor in the UK ast Standard level is 1000 ft.
Shawn
"Guenther Eichhorn" wrote in message
A
started at
higher
if they are spins.
that
circumstances.
Guenther
Guenther Eichhorn |
Dudley,
Sound advice.
get
out
guys
canopy,
fly
get
chute
to
Cheers,
Shawn
hlink.net...
ink.net...
Dudley
Old July 2nd 04, 07:36 PM
dave
I've been looking for a chute for my citabria - 7ECA. I spoke to Alan
Silver yesterday. He was very nice and explained alot to me about
chutes in the citabria. I'll need to modify my seat back to use a
backpack chute but it sounds worth it.
Some of you may have seen the ad's of pilot standing next to a
demolished citabria. He barely made it out. Alan told me that he had
trouble getting the door off. He pulled the hinger pins successfully
but didn't realize that he needed to push the bottom of the door out to
get it into the slip stream where it will be blown back. According to
Alan the guy had chosen to practice at around 6500AGL. He struggled
with the door for so long that if he had been even a few hundred feet
lower, he might not have made it. Scarey.
The reason he needed to get out was because part of the rear seat came
foward and fouled the rear stick.
I hope I got that story straight.
Dave
7ECA
Martin Hellman wrote:
"ShawnD2112" wrote in message news:AnZDc.1369$Dq1.851@newsfe6-win...
Was hoping to get a bit of expertise here. I'm in the market for an
emergency bailout chute for flying in my Pitts S-1D.
I fly a motor glider with a Paraphenalia Softie, with the "diaper
packed at the bottom" which is how my rigger calls packing it fatter
at the bottom and thinner at the top (as mentioned by an earlier
poster).
As others have recommended, talking to other Pitts owners is clearly a
good move, making sure to compare body sizes. Maybe one of them will
even lend you his chute to try out, on the ground at a minimum.
Other thoughts: My rigger installed an air bladder in the lower back
area that I can pump up for lower back support. Highly recommended. I
pump it, leave it for a while and release the pressure. A kind of slow
massage that seems to keep my back from getting stiff from being in
one position for many hours. Probably less of an issue in aerobatic
flying than soaring since you'll probably run out of fuel before your
back gets sore.
If you're in the San Francisco area -- and maybe even if you're not --
you ought to try Silver Parachute Sales. Alan Silver runs it and is an
excellent rigger who will treat you right both on initial sale and
repacking. He's based near the Hayward airport, just across the bay
from SFO. I know lots of glider pilots who send him their chutes for
repacking even though there are other, closer riggers. His telephone
is 510-785-7070.
Hope this helps and have fun with the Pitts.
Martin
Old July 2nd 04, 07:57 PM
Guenther Eichhorn
Yes, of course for a competition you practice lower (even though I personally still don't go
below 2000', because of noise concerns as much as because of safety concernsS). From your
post I assumed that you were new to the Pitts (you said " When I first started flying the
Pitts... "), which would mean that the maneuvers are new for you.
Guenther
Guenther,
Shawn
A
started at
higher
if they are spins.
that
circumstances.
Guenther
Guenther Eichhorn |
Dudley,
Sound advice.
get
out
guys
canopy,
fly
get
chute
to
Cheers,
Shawn
hlink.net...
ink.net...
Dudley
Old July 3rd 04, 04:16 AM
Dudley Henriques
About the negative stuff; the only reason I mentioned it was for you to
make sure whatever harness you bought was comfortable on the negative
side of things. The aerobatic harness is usually much more comfortable
in this respect.
One thing to keep in mind if you're going to be doing formation in a
Pitts, and unfortunately it's not a very pleasant thought :-) Remember,
if you DO make hard contact and have a wing failure, the flying wires
will probably hold on the top wing and the wing will literally beat you
to death before you can get out....so don't get too close!! :-))
Dudley
Dudley,
Sound advice.
done a
I get
two
a
there's
touching
good
first
it out
guys
canopy,
hitting the
rarely fly
get
chute
is a
silly to
hangar.
tonight.
Cheers,
Shawn
link.net...
ink.net...
least
it
Do a
your
Dudley
  #28
Old July 5th 04, 01:13 AM
ShawnD2112
Cheers, Dudley. As if I didn't have enough things to worry about!!
Spent Sunday briefing and doing a small bit of formation work with a former
Red Arrow pilot. If I get hit by a bus tomorrow, as least my log book will
show that I flew in formation with a former Red Arrow! I couldn't get the
grin off my face while it was happening. I think I'm going to enjoy working
with this guy! We went through a lengthy brief down at the local pub (where
all briefings should be held, if you ask me - very civilized approach to
flying, that!) where we discussed my mate's and my intentions, background,
and set out our stall together. We put together a basic framework of our
work then went into the details of safe formation flying to include
communications, formation placement, joinup and break basics, essentially
all the safety and practical issues associated with the business.
Thoroughly enjoyed it and it was a lot to take in. Some of it we knew, most
of it we didn't and even the stuff we knew we weren't entirely sure how to
apply. Talking to a guy who does it for a living (he still flies Jags) was
an eye-opening and extremely motivating experience.
On the parachute side, have decided on a Softie after talking to thier man,
Jim, for quite a while last week. He's going to make up a seat pack rig for
me with an aerobatic harness, based on your advice about the location of the
hardware (thanks for that, by the way)
It's also become time to replace the surplus bag I've been wearing for 3
years. I've looked at Flightsuits in California but are there any other
shops where guys in the community tend to go for good quality and good
prices? Any tips, as with the parachute advice, greatly appreciated!
Hope you had a good 4th weekend!
Cheers,
Shawn
ink.net...
in this respect.
Dudley
Dudley,
Sound advice.
done a
I get
two
a
there's
touching
good
first
it out
guys
canopy,
hitting the
rarely fly
get
chute
is a
silly to
hangar.
tonight.
Cheers,
Shawn
link.net...
ink.net...
least
it
Do a
your
Dudley
  #29
Old July 6th 04, 01:29 AM
Dudley Henriques
former
will
working
(where
to
background,
our
essentially
knew, most
how to
Jags) was
man,
rig for
of the
3
other
Cheers,
Shawn
ink.net...
to
negative
comfortable
in this respect.
Remember,
wires
you
Dudley
Dudley,
Sound advice.
done a
until
I get
were
two
with
a
there's
touching
good
I
first
ruled
it out
lot of
guys
canopy,
hitting the
aerobatic
rarely fly
able to
get
thought a
chute
with an
that
this
is a
silly to
hangar.
tonight.
Cheers,
Shawn
link.net...
ink.net...
at
least
Take
it
inverted.
Do a
on
your
Dudley
I thought that little "tidbit" about the flying wires would get a Grin
out of you!! :-) It's true though. Getting out of a Pitts after an
upper wing failure is REAL serious stuff!!
Anyway, it's funny you should mention having a briefing at a pub.
Believe it or not, when we were on the display circuit way back when,
almost all of the pilots would get together late at night in some diner
or bar somewhere and hash over programs and routine changes. I remember
spending an entire all nighter one weekend at a diner in Falls Church
Virginia with Art Scholl and two of the Thunderbirds. We were working on
Art's inverted ribbon pickup in the Chipmunk. He wanted to make some
changes and enter it from a modified tailslide. We worked it all out
after eating about a dozen hamburgers washed down with copious amounts
of coffee.
He did it the "new way" the next afternoon.
About the flight suit; you can get them made up custom, which might not
be a bad idea. Be careful about the material. Nomex is an option, but
you might not be as prone to a cockpit fire as I was in a P51 or a
Bearcat! :-) I remember damn near roasting to death in my flight suit.
All of your display flying will probably be done in the summer when it's
hot as heel out on those wide open concrete ramps...not to mention
cramped up in the Pitts cockpit :-)
I'd opt for something "cool" in a flight suit.
Where to get a good one is a toss up really. My wife made mine up for
me. You might want to contact the Arrows and find out who makes theirs,
or give Ray Hanna a call. Almost anyone in the business will have a
handle on who's doing the custom work these days in flight suits.
It's funny. I remember there was a lady in Pensacola who used to do all
the sewing on the Blue Angel flightsuits for the team. Man, was SHE one
busy lady!!! :-)
I'm sure you can come up with something over there. As I said, the best
place to get information on things like this is right inside the
community itself. Don't be shy! Call um!! :-)))
Dudley
  #30
Old July 6th 04, 07:40 AM
ShawnD2112
"Hot as hell in the summer"??? You've not spent much time over here in the
UK, have you, Dudley? It briefly (and I mean for a couple of hours) got to
100 degrees F one August day last year and that was the hottest temperature
ever recorded in the UK. The Brits didn't know what to do with themselves
in the heat! It rarely gets much above 85 even in the dead of summer so
that kind of overheating issue isn't really a problem here. I've currently
got a lightweight Nomex surplus USAF suit, and I'd like to duplicate it, but
it desert sand to match my airplane. While fire may not be as great a
threat in the Pitts, that fuel tank sitting right over your legs tends to
put thoughts into one's head. Good tip about asking the community. Most
guys around here seem to wear surplus RAF suits.
Anyway, off to work in glorious sunshine. It's a real effort not to call in
sick and go fly today!
Shawn
nk.net...
former
will
working
(where
to
background,
our
essentially
knew, most
how to
Jags) was
man,
rig for
of the
3
other
Cheers,
Shawn
ink.net...
to
negative
comfortable
in this respect.
Remember,
wires
you
Dudley
Dudley,
Sound advice.
done a
until
I get
were
two
with
a
there's
touching
good
I
first
ruled
it out
lot of
guys
canopy,
hitting the
aerobatic
rarely fly
able to
get
thought a
chute
with an
that
this
is a
silly to
hangar.
tonight.
Cheers,
Shawn
link.net...
ink.net...
at
least
Take
it
inverted.
Do a
on
your
Dudley
of coffee.
busy lady!!! :-)
Dudley
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Of parachutes and things ShawnD2112 Aerobatics 34 July 21st 04 06:13 PM
