Of parachutes and things
Old June 28th 04, 07:24 PM
ShawnD2112
Default Of parachutes and things
Was hoping to get a bit of expertise here. I'm in the market for an
emergency bailout chute for flying in my Pitts S-1D. The top US contenders
seem to be National and Softie but with no experience in the field, and
parachutes not exactly being the kind of object you can try on for size in
the shop, I don't really know what to look for and what to avoid. I'd
appreciate any tips anyone out there could provide. Are there any European
models that anyone has any experience with? Obviously comfort and space in
the cockpit are major considerations.
Thanks!
Shawn
Old June 28th 04, 07:49 PM
Ditch
I like the Security 250. But, I seem to be in the minority on that one.
-John
*You are nothing until you have flown a Douglas, Lockheed, Grumman or North
American*
Old June 28th 04, 07:57 PM
Todd Pattist
Glider pilots routinely fly with parachutes. You may also
want to ask in rec.aviation.soaring. I've flown with
National, Butler and Softie. The usual discussion is
whether it fits into the space available in the cockpit. If
you're buying new, talk to a reputable supplier and tell
them your height (for sizing), weight (right
diameter/descent rate) and aircraft type (you want something
that's comfortable in your type of seat.)
Under TSO C23b, which covers most emergency chutes, some
chutes are "low speed category" for under 150 mph aircraft
and some are "standard category" with no limits (but manfr
will usually give some limits.) Some chutes are certified
under TSO C23c which has three categories A,B and C. B is
the minimum you'd want to consider (150 KIAS at a gross
weight of 254 lb.)
Comfort is paramount. I sat in my Softie for a 12.5 hour
flight.
Todd Pattist
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Old June 28th 04, 08:21 PM
Dale
In article AnZDc.1369$Dq1.851@newsfe6-win,
I wear a parachute for all my flying. I much prefer the Softie to the
Strong rig we have. The Softie comes in many different styles/models.
As far as canopy choice, I want a canopy that is going to work at any
speed I might exit the airplane....as Todd noted that are different
certifcation criteria.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old June 28th 04, 09:21 PM
Dudley Henriques
"ShawnD2112" wrote in message
news:AnZDc.1369$Dq1.851@newsfe6-win...
contenders
and
size in
European
space in
Thanks!
Shawn
Shawn;
I take it you're into negative g these days, or at least thinking about
that side of the envelope :-) I'd suggest the Mini Softie. You can get
it with a very comfortable aerobatic harness which doesn't kill you with
the metalwork if you're working the airplane negative.
It should fit into the D cockpit ok unless you've been hanging out at
Mac Donald's too much lately or into that damn "bloomin onion" thing I
ate the other night at the Outback!! Man, you should have seen THAT
thing!!!! :-)) I think they just dip it into a bucket of LDL Cholesterol
and hand it to you!! :-))
Dudley
Old June 28th 04, 09:49 PM
Dudley Henriques
"Dudley Henriques" wrote in message
ink.net...
Forgot to tell you. Whatever you buy, try it on first and make at least
one flight in it with the Pitts. Don't baby the flight either. Take it
out sustained both ways and see how it feels, especially inverted. Do a
half roll, stabilize there and just hang for a bit and feel it on your
back. You'll know if it's going to do the job for you.
Dudley
Old July 2nd 04, 02:36 AM
ShawnD2112
Dudley,
Sound advice.
Negative stuff isn't the reason I've decided to get a chute. I've done a
bit of negative but I'm staying away from any of the real stuff until I get
some inverted spin training. No, what's really made me decide were two
things. One is that I've started doing some basic formation work with a
mate. While we're taking it slow and investing in some training, there's
always the risk of something going wrong and someone's airplane touching
someone else's. It's that scenario that makes a chute seem like a good
idea. I've also got a bit of a phobia about fire in the cockpit.
The other thing was a long term re-evaluation of the risks. When I first
started flying the Pitts, I thought about a chute but initially ruled it out
(they're not required for aerobatics in the UK, and, in fact, a lot of guys
don't wear them). I ruled it out because I figured that to open the canopy,
exit the aircraft, deploy the chute, and get one swing in before hitting the
ground, I'd need to be about 2,000 feet up. Well, when competing
andpracticing, I only ever got up that high at the tops of aerobatic
maneuvers, not during the bulk of my flying. So, I figured, if I rarely fly
high enough for a chute to work, what are the chances of being able to get
that altitude if I needed it? Pretty slim, I reckoned, so I thought a chute
was a comfort factor more than a real safety option.
Now, that all said, I'd feel like a real tit if I found myself with an
unflyable airplane and no means to get out of it. So screw all that
misguided analysis above, I'm getting a bailout chute. I guess this is a
case of experience and age teaching one a bit of wisdom? It seems silly to
deny myself an option based on some flawed logic applied in the hangar.
Thanks for the tip on the Softie. I'm going to give them a call tonight.
Cheers,
Shawn
link.net...
ink.net...
Dudley
Old July 2nd 04, 06:48 PM
Guenther Eichhorn
I think that practicing aerobatics below 2000' is not really a good idea. A
good friend of mine got killed when he messed up a hammerhead that he started at
1500'. When I practice new maneuvers, I want to be at 4000' to 5000', higher
if they are spins.
As far as the minimum altitude for chute opening is concerned, I believe that
you can get your chute open fromless than 1000', how much less depends on the
circumstances.
Guenther
Guenther Eichhorn |
Smithsonian Astrophysical Observatory, Cambridge, MA
CPL,ASMELS,Glider,LBH,IA,CFI | Pitts S-2A: N1GE
DC-3 type rating | Flying is the Pitts
http://acro.harvard.edu/ACRO
"ShawnD2112" writes:
Dudley,
Sound advice.
Cheers,
Shawn
hlink.net...
ink.net...
Dudley
Old July 2nd 04, 07:40 PM
ShawnD2112
Guenther,
Sorry to hear about your friend, and I appreciate where your advice is
coming from. I agree with you on practicing new maneuvers but when you're
practicing for a competition you have to be able to get your positioning
right. Competition floor in the UK ast Standard level is 1000 ft.
Shawn
"Guenther Eichhorn" wrote in message
A
started at
higher
if they are spins.
that
circumstances.
Guenther
Guenther Eichhorn |
Dudley,
Sound advice.
get
out
guys
canopy,
fly
get
chute
to
Cheers,
Shawn
hlink.net...
ink.net...
Dudley
Old July 3rd 04, 05:16 AM
Dudley Henriques
About the negative stuff; the only reason I mentioned it was for you to
make sure whatever harness you bought was comfortable on the negative
side of things. The aerobatic harness is usually much more comfortable
in this respect.
One thing to keep in mind if you're going to be doing formation in a
Pitts, and unfortunately it's not a very pleasant thought :-) Remember,
if you DO make hard contact and have a wing failure, the flying wires
will probably hold on the top wing and the wing will literally beat you
to death before you can get out....so don't get too close!! :-))
Dudley
Dudley,
Sound advice.
done a
I get
two
a
there's
touching
good
first
it out
guys
canopy,
hitting the
rarely fly
get
chute
is a
silly to
hangar.
tonight.
Cheers,
Shawn
link.net...
ink.net...
least
it
Do a
your
Dudley
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
Of parachutes and things ShawnD2112 Aerobatics 34 July 21st 04 07:13 PM
