Thank you.. roger on the slow and high weight.. which equals high AOA which
create stronger vortices... fist time I've heard about gear and flaps breaking up vortices.. as I said MY original response.. I'd have to go back and find the article I read it from BT "Icebound" wrote in message gers.com... "BTIZ" wrote in message news:2fHIc.23345$r3.6120@okepread03... also.. wake turbulence is the worst if the heavier aircraft (bizjet) is configured for landing, flaps and gear etc.. if he was still gear up.. and in level flight... the bumps would not be so bad even if you had 500ft. A quote from a popular primary text: "The greatest vortex strength occurs under CLEAN configuration, high weight, and slow speed." (emphasis mine) (... and high air density) Their contention appears to be that flaps and gear help break up the vortex pattern. The clean configuration at slow speeds results in the highest AOA, supposedly the primary culprit. |
![]() "BTIZ" wrote in message news ![]() ...snip... as I said MY original response.. I'd have to go back and find the article I read it from Since the post, I did a little googling, and found the FAA AIM has basically the same quote: http://www.faa.gov/ATpubs/AIM/Chap7/aim0703.html 7-3-3. Vortex Strength a. ...snip... The greatest vortex strength occurs when the generating aircraft is HEAVY, CLEAN, and SLOW. (this time the emphasis is theirs) |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
caution - wake turbulence | John Harlow | Piloting | 1 | June 4th 04 04:40 PM |
My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 10:21 PM |
Wake turbulence avoidance and ATC | Peter R. | Piloting | 24 | December 20th 03 11:40 AM |
How much turbulence is too much? | Marty Ross | Instrument Flight Rules | 8 | August 21st 03 05:30 PM |
