Wake Turbulence Question
Old July 13th 04, 01:37 AM
HankPilot2002
Default Wake Turbulence Question
I was level at 1500' MSL and ATC announced a Gulfstream bizjet crossing from my
right to left, 3000' MSL less than a mile lateral distance. I had my
instrument student do a 360 for wake turbulence separation and dissipation.
ATC questioned my actions and told me the 360 wasn't necessary.
BTW: I was in Class Echo airspace in southern Maine.
I havent been instructing all that long but this did seem to me to be a classic
wake turb encounter in the making. I am interested in hearing from other
pilots and CFII's on this subject. Was I over cautious ? Or prudent.....
Hank
Old July 13th 04, 02:30 AM
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hank
I'll take a crack at it...
Let's say the Gulfstream was IFR, and was level. Judging by
your level altitude, you were VFR. Either way, you still have the
1000ft vertical separation, regardless of lateral separation, so doing
a 360 wouldn't have mattered for separation. As long as you had him in
sight, and being (assumed) VFR, you could maintain visual separation.
In that instance, the 360 wouldn't have been needed.
Let's now say that the Gulfstream was climbing. He was going to
be crossing your path above you, which may mean that you would catch
the underside of his wake before the tail end of it after his climb. In
that instance, you could have done a 360 to avoid the wake altogether,
then continue. But once again, It wouldn't have been needed, as you had
vertical separation of over 1000ft.
Overcautious? yes. But better to be over than under. You would
have been fine, but as CFII, you would have been in the best position
to make the call. Judging that this post happened after your flight,
you walked away from the flight. Which means you lived. Therefore,
your call was a good one.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.sbcglobal.net/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFA8ztMyBkZmuMZ8L8RAtNYAKCWM7okfijLEHOwKLoSky QwZ0M8SACdEowi
YtNXYif1EpxMEY8eXAsmnNI=
=+OlY
-----END PGP SIGNATURE-----
Old July 13th 04, 02:34 AM
Teacherjh
The "classic" wake turbulence encounter is flying up the funnel and being
turned over. To do that, your courses would need to be fairly well aligned.
Your encounter sounds like it was more at right angles. You'd get a bump bump
and be through it. By doing a 360, you allowed your course to parallel the
other aircraft's course, and if you didn't know where he was, you risked the
classic encounter as you passed 90 degrees or 270 degrees of your turn.
If it was indeed crossing right to left, I'd have just proceeded on course.
Jose
Old July 13th 04, 02:52 AM
BTIZ
I'd have to research the study.. but most wake turbulence only drops about
500ft.. if I remember correctly.. if you were 500ft it would not be an
issue..
also.. wake turbulence is the worst if the heavier aircraft (bizjet) is
configured for landing, flaps and gear etc.. if he was still gear up.. and
in level flight... the bumps would not be so bad even if you had 500ft. It's
the wing tip vortices that are the worst, and yes you may get some vortices
from the flap end at mid span.
We've rendezvoused for refueling, 1000ft below a heavy tanker (KC-10/DC10)
and moved into refueling position and not feel his wake until we are
practically on the boom.. at near cruise speeds
BT
"HankPilot2002" wrote in message
from my
dissipation.
classic
Hank
Old July 13th 04, 04:41 AM
Icebound
"BTIZ" wrote in message
news:2fHIc.23345$r3.6120@okepread03...
A quote from a popular primary text:
"The greatest vortex strength occurs under CLEAN configuration, high weight,
and slow speed." (emphasis mine)
(... and high air density) Their contention appears to be that flaps and
gear help break up the vortex pattern. The clean configuration at slow
speeds results in the highest AOA, supposedly the primary culprit.
Old July 14th 04, 01:02 AM
BTIZ
Thank you.. roger on the slow and high weight.. which equals high AOA which
create stronger vortices... fist time I've heard about gear and flaps
breaking up vortices..
as I said MY original response.. I'd have to go back and find the article I
read it from
BT
"Icebound" wrote in message
gers.com...
and
weight,
Old July 14th 04, 04:49 AM
Icebound
newsK_Ic.259$gQ2.161@okepread03...
...snip...
I
read it from
Since the post, I did a little googling, and found the FAA AIM has basically
the same quote:
http://www.faa.gov/ATpubs/AIM/Chap7/aim0703.html
7-3-3. Vortex Strength
a. ...snip... The greatest vortex strength occurs when the generating
aircraft is HEAVY, CLEAN, and SLOW.
(this time the emphasis is theirs)
Old July 13th 04, 03:04 PM
Ace Pilot
According to the latest edition of the Aeronautical Information Manual
(effective 19 February 2004), paragraph 7-3-3:
"The greatest vortex strength occurs when the generating aircraft is
HEAVY, CLEAN, and SLOW." [emphasis present in original document]
A clean aircraft generates stronger wake vortices than does one
configured for landing.
Old July 13th 04, 04:13 PM
CV
Not necessarily. When it is landing it will be SLOW, which is
much more important than the minimal effect of how it happens
to be configured.
CV
caution - wake turbulence John Harlow Piloting 1 June 4th 04 04:40 PM
My First Time In Severe Turbulence (Long) David B. Cole Instrument Flight Rules 6 March 10th 04 10:21 PM
Wake turbulence avoidance and ATC Peter R. Piloting 24 December 20th 03 11:40 AM
How much turbulence is too much? Marty Ross Instrument Flight Rules 8 August 21st 03 05:30 PM
