#11
Capt.Doug wrote:
It depends on the structure. The T-28 Trojan was used by the South Vietnamese in their conflict for ground attack roles. The pilots were pulling the wings off much too often and the engineers couldn't understand because those wings should support a battleship. It turns out that the horizontal stabilizer was actually the first component to fail. After it failed, the plane would pitch over with enough force to break the wings off. This happens in less than a second. Once the engineers understood the problem and strenghtened the horizontal stabilizer, the problem went away. T-28 breaking point occurs at 428 kts. (As related to me by a retired North American engineer many years ago.) |
![]() Tony Cox wrote: "Peter" wrote in message ... I think I understand the reasoning behind Va, the max maneuvering speed, being that the wing will stall (and thus dispose of the loading) before it breaks. This is why Va falls as the weight falls, because at any given IAS a higher weight takes the aircraft closer to stall already. There was a long thread in January, "Va and turbulent air penetration speed" which you ought to be able to find on Google. Can I suggest that avoiding turbulent air is simply the most pragmatic approach? It's broken enough airliners for starters ! Graham |
Capt.Doug wrote:
"William W. Plummer" wrote in message Is it the tail or the wings that get snapped off. Hauling back on the yoke loads up the elevator. The wings are near the center of gravity so they don't get stressed as much. It depends on the structure. The T-28 Trojan was used by the South Vietnamese in their conflict for ground attack roles. The pilots were pulling the wings off much too often and the engineers couldn't understand because those wings should support a battleship. It turns out that the horizontal stabilizer was actually the first component to fail. After it failed, the plane would pitch over with enough force to break the wings off. This happens in less than a second. Once the engineers understood the problem and strenghtened the horizontal stabilizer, the problem went away. Other planes break apart in different ways. The T-34 has been in the news quite a bit lately because of wings falling off. It appears that the tail isn't breaking. The cause is attributed to metal fatigue from repeated large stresses. A C-130 water bomber was videotaped as the wings came off. The cause has been determined to be undetected cracks in the bottom wing skins that were hidden by doublers. An airworthiness directive was recently aimed at the Cessna 400 series because of a wing seperation. It turns out that the causal factors of the seperation were damage during building by the manufacturer and repeated overstressing during years of abuse in Alaska. D. Metal fatigue, cracks and construction defects are not caused by turbulence although turbulence may be the straw that breaks the camel's back when those problems exist. IIRC the Convair Electra was the first plane that metal fatigue was determined to be the cause of its wings coming off. And, it took years. What caused the fatigue? Gyroscopic motion of the wings. |
Howdy!
In article 01PLc.162096$XM6.47385@attbi_s53, William W. Plummer wrote: Capt.Doug wrote: [snip] Other planes break apart in different ways. The T-34 has been in the news quite a bit lately because of wings falling off. It appears that the tail isn't breaking. The cause is attributed to metal fatigue from repeated large No. I've seen discussion that suggests the problem is operator error. Rolling pullups can, apparently, generate excessive g-loads with remarkable ease. [snip] Metal fatigue, cracks and construction defects are not caused by turbulence although turbulence may be the straw that breaks the camel's back when those problems exist. IIRC the Convair Electra was the first plane that metal fatigue was determined to be the cause of its wings coming off. And, it took years. What caused the fatigue? Gyroscopic motion of the wings. Not quite. Damage to engine mounts would lead to whirl mode oscillation of the engines, which would resonate with the wing, inducing flutter, leading to wing coming off. yours, Michael -- Michael and MJ Houghton | Herveus d'Ormonde and Megan O'Donnelly | White Wolf and the Phoenix Bowie, MD, USA | Tablet and Inkle bands, and other stuff | http://www.radix.net/~herveus/ |
Metal fatigue, cracks and construction defects are not caused by turbulence although turbulence may be the straw that breaks the camel's back when those problems exist. IIRC the Convair Electra was the first plane that metal fatigue was determined to be the cause of its wings coming off. And, it took years. What caused the fatigue? Gyroscopic motion of the wings. Turbulence most certainly is the cause of fatigue in the wing structure of aircraft. I would suggest that you read FAR Part 25 to understand how the nature of the Standard Atmosphere and the cruise speed is used in designing a "fatigue life" in transport category aircraft. "Convair Electra"??? No way...my Electra time was flown in a Lockheed Electra..L-188 and it's US Navy derivitive the P-3 Orion. The civilian L-188s failed early in their service life, Braniff's Flight 542 crashed in 1959, only two months after it's delivery from Lockheed. The Northwest Flight 710 crashed in 1960 after only one year in service. It was not "gyroscopic motion of the wings" nor "fatigue"....... "On May 12, 1960, Lockeed President Bob Gross announced that both airliners broke-up due to an undampened propeller whirl mode that produced destructive flutter of the wing." This from the "Great Airliners Series, Volume Five, Lockheed 188 Electra" by David G. Powers. You disappoint me William. Bob Moore Air Florida L-188 1973 VP-46 P-3B 1965-67 |
Destruction due to turbulence when below Va - how? | Roger Long | General Aviation | 15 | July 22nd 04 04:42 PM |
Destruction due to turbulence when below Va - how? | Roger Long | Piloting | 0 | July 21st 04 03:27 PM |
My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 10:21 PM |
Wake turbulence avoidance and ATC | Peter R. | Piloting | 24 | December 20th 03 11:40 AM |
How much turbulence is too much? | Marty Ross | Instrument Flight Rules | 8 | August 21st 03 05:30 PM |
