Destruction due to turbulence when below Va - how?
Old July 21st 04, 03:27 PM
Roger Long
Default Destruction due to turbulence when below Va - how?
It's not complete protection, it just loads the odds a bit more in your
favor.
The aircraft is as likely to be broken by a panicked response by the pilot
or a botched attempt to recover from an unusual attitude and being at Va
will reduce that probability significantly.
Roger Long
"Peter" wrote in message
I think I understand the reasoning behind Va, the max maneuvering
speed, being that the wing will stall (and thus dispose of the
loading) before it breaks. This is why Va falls as the weight falls,
because at any given IAS a higher weight takes the aircraft closer to
stall already.
So, how is it possible to have aircraft destruction due to weather,
e.g. flying into a strong updraught in a CB, if flying below Va?
A DOWNdraught would do it more easily because most aircraft designs
have a lower design limit for negative G.
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Old July 21st 04, 05:12 PM
Icebound
stall already.
Flying into an updraught (updraft) in a CB can cause destruction for other
reasons that just the consideration of Va.
The windshear may put the aircraft into an unusual attitude from which
recovery may be impossible before, say, Vne is exceeded.
Old July 21st 04, 05:08 PM
john smith
stall already.
Find a copy of "FLYING THE BEECH BONANZA", by John C Eckalbar.
There is a section in the book expressly dealing with this topic.
Old July 21st 04, 05:41 PM
Mike Rapoport
Turbulence is gusts which change the airspeed. I recall reading one account
of a thunderstorm accident where the plane encountered a 80kt vertical gust.
In the Sierra Wave Project loads of +16G and -20G were encountered in a
rotor cloud at below Va..
I think it should be understood that these are extreme examples i.e. flying
into the worst part of the worst thunderstorm at the worst time. A one in a
million event. The usual breakup story is loss of control followed by an
overspeed were the pilot pulls the wings off in the recovery.
MU-2
stall already.
Peter.
Old July 21st 04, 06:15 PM
William W. Plummer
MU-2
stall already.
Peter.
Is it the tail or the wings that get snapped off. Hauling back on the
yoke loads up the elevator. The wings are near the center of gravity so
they don't get stressed as much.
Old July 21st 04, 07:13 PM
Orval Fairbairn
In article MwxLc.67$eM2.51@attbi_s51,
MU-2
stall already.
Peter.
Sometimes it is aircraft components -- engine mounts, baggage
compartments, etc. that fail.
Old July 22nd 04, 01:33 AM
Mike Rapoport
"William W. Plummer" wrote in message
news:MwxLc.67$eM2.51@attbi_s51...
account
gust.
flying
in a
an
MU-2
stall already.
Peter.
Y.
I guess I don't understand what you are trying to say. If you pull back on
the yoke, the wing supports the weight of the airplane plus the load on the
tail multiplied by the load factor.
MU-2
Old July 22nd 04, 03:23 AM
Capt.Doug
"William W. Plummer" wrote in message Is it the tail or the wings that
It depends on the structure. The T-28 Trojan was used by the South
Vietnamese in their conflict for ground attack roles. The pilots were
pulling the wings off much too often and the engineers couldn't understand
because those wings should support a battleship. It turns out that the
horizontal stabilizer was actually the first component to fail. After it
failed, the plane would pitch over with enough force to break the wings off.
This happens in less than a second. Once the engineers understood the
problem and strenghtened the horizontal stabilizer, the problem went away.
Other planes break apart in different ways. The T-34 has been in the news
quite a bit lately because of wings falling off. It appears that the tail
isn't breaking. The cause is attributed to metal fatigue from repeated large
stresses. A C-130 water bomber was videotaped as the wings came off. The
cause has been determined to be undetected cracks in the bottom wing skins
that were hidden by doublers. An airworthiness directive was recently aimed
at the Cessna 400 series because of a wing seperation. It turns out that the
causal factors of the seperation were damage during building by the
manufacturer and repeated overstressing during years of abuse in Alaska.
D.
Old July 22nd 04, 03:31 AM
john smith
T-28 breaking point occurs at 428 kts. (As related to me by a retired
North American engineer many years ago.)
Old July 22nd 04, 02:10 PM
William W. Plummer
D.
Metal fatigue, cracks and construction defects are not caused by
turbulence although turbulence may be the straw that breaks the camel's
back when those problems exist.
IIRC the Convair Electra was the first plane that metal fatigue was
determined to be the cause of its wings coming off. And, it took
years. What caused the fatigue? Gyroscopic motion of the wings.
Weapons of Mass Destruction running with scissors Instrument Flight Rules 23 April 24th 04 02:00 PM
My First Time In Severe Turbulence (Long) David B. Cole Instrument Flight Rules 6 March 10th 04 10:21 PM
Budgets of Mass Destruction B2431 Military Aviation 4 February 4th 04 04:38 AM
please stop bashing France Grantland Military Aviation 233 October 29th 03 01:23 AM
How much turbulence is too much? Marty Ross Instrument Flight Rules 8 August 21st 03 05:30 PM
