Did I misunderstand my reading on the subject, or should the Manifold
Pressure on an engine that's off be the local atmospheric pressure? I've just noticed that this is not the case in my little R182. - Andrew |
Should be the same value if the engine is not operating and the gauge is
correctly calibrated. I would suspect the gauge is out of calibration. Dave Andrew Gideon wrote: Did I misunderstand my reading on the subject, or should the Manifold Pressure on an engine that's off be the local atmospheric pressure? I've just noticed that this is not the case in my little R182. - Andrew |
Let me amend my answer to be "same value if the engine is not operating,
the gague is correctly calibrated and you are AT SEA LEVEL". Remember that local altimeter settings are corrected for sea level when you are at a locale that is at elevation. 29.92" setting in Denver is a "corrected reading" for what the pressure would be if you were at sea level. So, ballpark.. the value is 1" per thousand (without digging out reference material) pressure change/altitude. Denver on a standard day (setting 29.92") should have a manifold pressure gauge reading (5000 ft/5" less) just under 25" when the engine is off. Sorry for my initial error. I'm sure if there are others, they will be quickly pointed out. Dave Dave S wrote: Should be the same value if the engine is not operating and the gauge is correctly calibrated. I would suspect the gauge is out of calibration. Dave Andrew Gideon wrote: Did I misunderstand my reading on the subject, or should the Manifold Pressure on an engine that's off be the local atmospheric pressure? I've just noticed that this is not the case in my little R182. - Andrew |
Where are you?
"Andrew Gideon" wrote in message online.com... Did I misunderstand my reading on the subject, or should the Manifold Pressure on an engine that's off be the local atmospheric pressure? I've just noticed that this is not the case in my little R182. - Andrew |
John Gaquin wrote:
Where are you? I assume you're answered by: Less than 200' above sea level. - Andrew |
at less than 200ft MSL, then the MP indicator with the engine at rest (and
sitting on the ground) should read the approximate value of the barometric pressure or about 30in Out here (2200MSL) the MP indicator would read about 2 inches or more lower or about 28in (or closer to 27.5in) MP before engine start BT "Andrew Gideon" wrote in message online.com... John Gaquin wrote: Where are you? I assume you're answered by: Less than 200' above sea level. - Andrew |
Andrew,
I've just noticed that this is not the case in my little R182. Should be. Otherwise, your MP gauge might need repair. Ours is indicating about 0.5 inches too much, so we correct our settings for that. -- Thomas Borchert (EDDH) |
Andrew Gideon wrote in message gonline.com...
Did I misunderstand my reading on the subject, or should the Manifold Pressure on an engine that's off be the local atmospheric pressure? I've just noticed that this is not the case in my little R182. It should be the same as ambient pressure, but not necessarily the same a altimeter setting. Altimeter setting is not pressue but some made up number that makes the altimeter read correctly (that's actually the definition!). -Robert |
Robert,
it should read the same pressure as the altimeter in the Kollsmann window when the altimeter is set to zero feet, right? -- Thomas Borchert (EDDH) |
On Wed, 18 Aug 2004 17:57:19 +0200, Thomas Borchert
wrote: Robert, it should read the same pressure as the altimeter in the Kollsmann window when the altimeter is set to zero feet, right? ......altimeter set to ***airfield elevation***, correct?? The old QFE vs QNH settings thing... GNP, Socata TB-9 SX-ADE, LGTG, Greece, (grounded due to Olympics in progress, next flight 29 September) |
Special prop to increase manifold pressure | Fly | Owning | 7 | December 2nd 04 07:23 PM |
Cabin Pressure Altitude | Greg Esres | Piloting | 4 | March 24th 04 08:35 PM |
Manifold pressure gauge problem | Dave Russell | Aerobatics | 3 | January 29th 04 03:46 AM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
Pressure Differential in heat Exchangers | Bruce A. Frank | Home Built | 4 | July 3rd 03 05:18 AM |
