Cabin Pressure Altitude
Old March 23rd 04, 06:12 AM
Greg Esres
Default Cabin Pressure Altitude
14 CFR 121.327 says that "cabin pressure altitude" and "flight
altitude" mean the same thing for unpressurized cabins.
Now, even though Part 91 doesn't have the same statement, I think it
reasonable that the same definition applies to 91.211 Supplemental
Oxygen:
---------------snip-------------
At cabin pressure altitudes above 12,500 feet (MSL) up to and
including 14,000 feet (MSL)
What this means is that the oxygen requirements kick in based on MSL
altitudes, not pressure altitudes as is commonly thought, at least for
those of us with unpressurized cabins.
§ 121.327 Supplemental oxygen: Reciprocating engine powered airplanes.
(d) For the purposes of this subpart "cabin pressure altitude" means
the pressure altitude corresponding with the pressure in the cabin of
the airplane, and "flight altitude" means the altitude above sea level
at which the airplane is operated. For airplanes without pressurized
cabins, "cabin pressure altitude" and "flight altitude" mean the same
thing.
Old March 24th 04, 12:35 AM
BTIZ
Run that by me again??
I read it to say "cabin pressure altitudes equivalent to 12500-14000MSL"
I can fly pressurized at FL200 without O2, but if the cabin pressurization
has a problem and "leaks" up to 12,500 (MSL equivalent) or higher, I best
have supplemental O2 handy
And if I am small GA aircraft with no pressurization capability, then the
MSL altitude I'm flying at is the cabin altitude.
BT
"Greg Esres" wrote in message
Oxygen:
thing.
Old March 24th 04, 12:59 AM
Greg Esres
12500-14000MSL
Yes. But this reg has been frequently read to mean 12,500 pressure
altitude. There was a discussion here a while back about why the
"MSL" appeared in the reg; some thought it was a bit of a red herring.
Opinion was divided over whether "pressure altitude" was meant or
"MSL".
For some reason, it now appears quite clear to me the reg means MSL.
Old March 24th 04, 01:19 AM
BTIZ
ah ha... I must have missed that thread...
BT
12500-14000MSL
"MSL".
Old March 24th 04, 08:35 PM
Robert M. Gary
Greg Esres wrote in message . ..
12500-14000MSL
"MSL".
I didn't see that thread, the regs have always seemed pretty clear to
be MSL to me. However, your body reacts to pressure altitude (not
density in this case).
-Robert
Punctured pressure cabin. M. J. Powell Military Aviation 103 January 5th 04 06:16 AM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
GPS Altitude with WAAS Phil Verghese Piloting 38 October 5th 03 12:39 AM
Greatest Altitude without pressure cabin/suit W. D. Allen Sr. Military Aviation 12 July 26th 03 04:42 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
