How does a Prop Governor work?
Old September 4th 04, 06:45 PM
Felix
Default How does a Prop Governor work?
Hi,
I was wondering if anyone can explain exactly how a prop governor
works for a constant speed prop system? All I know is that the engine
Oil pushes a piston in the prop hub that twists the prop to the
appropriate angle.
Thanks,
Felix
Old September 4th 04, 06:57 PM
Eduardo Kaftanski
Felix wrote:
Hi,
appropriate angle.
most governors work the same way... rotation moves a set of weights
that move a valve that lets oil through.
in case of a single engine plane prop, the governor lets more oil through
as the RPMS go up to rotate the blades and increase pitch.
Eduardo Kaftanski |
| Freedom's just another word
http://e.nn.cl | for nothing left to loose.
Old September 4th 04, 06:58 PM
'Vejita' S. Cousin
appropriate angle.
Go to http://www.avweb.com/news/columns/182146-1.html and take a look
at the Engine-Related Columns (scroll down some they are on the right hand
side). Esp these four:
Pelican's Perch #15: Manifold Pressure Sucks!
Pelican's Perch #16: Those Marvelous Props
Pelican's Perch #18: Mixture Magic
Pelican's Perch #19: Putting It All Together
They pretty much cover the subject of how engines, the throttle/MP, props,
and mixture work. I found them very helpful when I was a student.
Old September 4th 04, 11:44 PM
On 4 Sep 2004 10:45:41 -0700, (Felix) wrote:
http://www.thaitechnics.com/propeller/prop_control.html
Good governor description, the propeller designs shown are kind of
dated. Most modern props use either a spring assembly or a air-charged
piston/spring combination to oppose the "governed" oil pressure
deliverd to the propeller.
TC
Hi,
appropriate angle.
Thanks,
Felix
Old September 5th 04, 12:26 AM
Doug Vetter
Felix wrote:
Hi,
appropriate angle.
Thanks,
Felix
The other links mentioned in this thread will tell you the whole story.
If you want a closeup of what the weights look like and a brief
explanation of how they fit into the grand scheme, take a look at ours...
Go to my site and click through
Aviation - Articles - Maintenance - Annual 2003 Part 3
and scroll down to the bottom.
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
