Is JB Weld electrically conductive?
Old July 9th 04, 11:11 PM
Scott
Default Is JB Weld electrically conductive?
Well, IS IT (after it cures, that is)???
Scott
http://corbenflyer.tripod.com
Building RV-4
Gotta Fly or Gonna Die
Old July 10th 04, 04:31 PM
Clay
Scott wrote in message ...
Scott
Building RV-4
I can not speak for JB WELD but I do know, for a fact, that BELZONA
(1111) Super Metal is not conductive. It also will not rot, shrink,
rust, or corrode.
No solvents in Super Metal and does not stink like JB Weld. Excellent
compressive and shear-adheision strength.
It will stand up avgas, mogas, or jet fuel.
It does not run off like JB WELD. I have built Belzona 1"thick on
horizontal and verticle surfaces and it stays put. Amazing stuff, to
say the least!
Old July 10th 04, 06:04 PM
Rich S.
"Scott" wrote in message
Doesn't appear to be. I tried measuring the resistance of a recent repair
using an autoranging ohmmeter. Even with the probes almost touching each
other, it read infinity.
Rich S.
Old July 10th 04, 07:36 PM
Jerry Springer
Scott
Building RV-4
rust, or corrode.
say the least!
Are you using the same JB Weld I do? I have never found it to stink or run off.
Of course I do not stick my nose right in it to see if it smells. :-)
Jerry
Old July 11th 04, 01:25 PM
Scott
Rich,
Thanks for the "field test"!!! I did find on the European JB website
that it is not conductive after set up. Dang, I need something that IS
conductive (well, not really, but it would be nice)...
Scott
Rich S.
Old July 11th 04, 04:25 PM
Rich S.
Rich,
Add a pinch of powdered Magnesium, some gunpowder, litharge and glycerin.
Rich "plugging my ears" S.
Old July 11th 04, 04:37 PM
Clay
I do not have to stick my nose in JB Weld. I find the odor offensive.
But that may just be me.
I have used a couple of varieties of JB Weld and it will work in some
situations however, if you check the product specification sheets
Belzona is much stronger mechanical properties.
Caterpiller corporation specifies Belzona for repairs in their engine
blocks.
Jerry Springer wrote in message link.net...
Scott
Building RV-4
rust, or corrode.
say the least!
Jerry
Old July 11th 04, 07:31 PM
Anthony
"Clay" wrote in message
om...
blocks.
It sounds interesting where can I find some?
Tony
Old July 11th 04, 08:07 PM
Rich S.
"B2431" wrote in message
Rich, I'd venture to say he'd like to have it conduct more than once.
Oh. The Fourth of July is over for this year I guess.
Rich "Explosive ways to lose 13 lbs. of ugly fat." S.
JB Weld or Hi Temp RTV silicone oil crack fix. Paul Lee Home Built 7 July 12th 04 03:12 PM
Learning to weld with a non-aircraft project Ed Home Built 36 March 31st 04 04:06 AM
What is best "JB Weld" type epoxy putty? [email protected] Home Built 4 March 8th 04 07:45 AM
Tube Cluster Weld Question Dick Home Built 6 January 17th 04 12:10 AM
