Tube Cluster Weld Question
Old January 15th 04, 12:56 AM
Dick
Default Tube Cluster Weld Question
Other than a weight consideration, what concern is there with replacing a
typical fuselage tube cluster (all legs in the same geometric plane) with a
half circle plate where the slotted end legs are slide onto and then welded?
Kind of like a bridge with it's clip angles on I-beams. Then the diagonals
and other bridge members are riveted/bolted onto the clip angles.. Or
similiar to those wooden semi-circular gussets used to sandwich a wooden
fuselage member joint.
It appears to me that the linear inches of weld could be greater than those
fishmouthed connections so tedious to make.
Thanks, Dick
Pitts Special Steel Tube Fuse Mod. Martin Morgan Home Built 0 November 24th 03 12:08 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 02:51 AM
Welding techniques for 4130? Building The Perfect Beast Home Built 29 September 4th 03 09:52 PM
Hinges under stress - mechanical engineering type question Corrie Home Built 21 August 6th 03 09:49 AM
