How Many Nations Follow the FAA?
Old December 6th 04, 08:18 PM
Chris
"G.R. Patterson III" wrote in message
Thomas Borchert wrote:
do a google search on ICAO.
The vast majority of the hits will be for an accountants' organization.
Search
for the full name.
No need Google puts the right ICAO at the top
Old December 6th 04, 10:23 PM
Blueskies
"Bill Denton" wrote in message ...
How does the ICAO fit into all of this?
I was under the impression that they were a multi-national organization that
dealt with "coordinating" aviation activities among nations.
From what I understand, the ICAO puts forth a set of rules from which
individual nations could extract subsets, or create supersets of, with the
essential idea being to create a "core" set of rules that all signatory
nations would abide by.
Among many things I don't know is what the scope and depth of these rules
is. I know they cover stuff like runway designs and things like that, but do
they also cover such things as required aircraft equipment, pilot training,
and similar issues. And do they go down to the "Section 1.2.3.4.5" level?
Also, do they apply only to commercial aviation, or is all GA covered?
If anyone has any additional info, TIA!
I recently saw an article that described changes to the FARs for SIC pilots; required that they have a SIC type rating
or similar to fly in ICAO countries, Needed to be done ASAP, or the flight crews were going to be cited.
Old December 9th 04, 05:45 AM
Brian Burger
On Sat, 4 Dec 2004, Charles Talleyrand wrote:
In the US we have a set of aviation regulations all made up by the FAA.
In Canada they have a different set of rules all made up by Transport
Canada. They don't blindly follow the American FAA system.
No, but Transport Canada will consult w/ the FAA, and FAA ADs & similar
seem to be applied by TC as well.
There was a short article in the recent TC "Air Safety Letter" about
Canadian pilots busting the Washington, DC TFR - those lucky folks have
not one, but TWO regulatory agencies on their case for those busts...
When in Belize I walked through the capital to the general aviation airport
and talked to a pilot. It turns out that Belize uses the FAA regulations.
That makes sense, for a small country. Belize's Air Regs probably say
something like, "Follow the FAA Regs, except in certain cases as laid out
below..." or similar.
Brian
www.warbard.ca/avgas/index.html
Old December 9th 04, 09:08 PM
Kyler Laird
Brian Burger writes:
'seems like it would make even more sense to follow ICAO.
--kyler
Old December 9th 04, 09:29 PM
Stefan
The ICAO publishes general rules but these are not directly applicable laws.
Stefan
Old December 11th 04, 10:08 PM
Kyler Laird
Stefan writes:
But at least they could follow the laws of a nation which follows ICAO.
--kyler
Old December 12th 04, 04:17 AM
The ICAO requirements for a Comercial are what the FAA now uses.
Explain to me the logic of requiring the comercial to be done in a
complex aircraft when most of GA training is done in fixed gear. All
any one needed was an endorsement for complex... But now the test must
be in a complex.
Then, explain why you need 3 landings on the 250NM straight, 300NM
total. By the time you are working on a comercial you should know how
to land, right? ICAO says you have to have the 3 landings and this must
be SOLO.
Wanna ask the FAA why? Have fun, because they will quote you ICAO.
So yes, the ICAO even specifies training.
Later.
Steve.T
Oil Leak on top of the engine -- follow up Jay Honeck Owning 6 February 13th 05 01:50 PM
How Many Nations Follow the FAA? Charles Talleyrand Owning 15 December 12th 04 04:17 AM
Moore Plays The Nation's Liberals For Fools W. D. Allen Sr. Military Aviation 3 June 30th 04 12:41 PM
LEFT WINGERS IN FOR BIG SURPISE - STROKES TO FOLLOW ELECTION Jarg Military Aviation 3 April 20th 04 06:37 PM
Dead stick landings - follow up question John Piloting 3 July 31st 03 10:51 AM
