How Many Nations Follow the FAA?
Old December 5th 04, 04:59 AM
Charles Talleyrand
Default How Many Nations Follow the FAA?
In the US we have a set of aviation regulations all made up by the FAA.
In Canada they have a different set of rules all made up by Transport
Canada. They don't blindly follow the American FAA system.
When in Belize I walked through the capital to the general aviation airport
and talked to a pilot. It turns out that Belize uses the FAA regulations.
Pilots in Belize actually refer to "Part 91" which is amazing since that's a
rule made by the American government and the Belize government just tells
they "Do everything you would have to if you were in America".
I also notice that the South African set of rules for general aviation is
called "part 91".
So, how many nations don't make their own aviation rule but instead simply
require the locals to follow the American FAA rules?
And as a follow-up, do any non-European nations require one to follow the
European rules?
Old December 5th 04, 05:18 AM
MC
called "part 91".
Australia has started rewriting its' rules to 'harmonize' them with
the FAA and JAA systems.
Old December 5th 04, 06:42 AM
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
called "part 91".
How does this fit in and live with ICAO and the standards they
lay out?
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.sbcglobal.net/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.6 (GNU/Linux)
iD8DBQFBsq3hyBkZmuMZ8L8RAiTIAJ9DBEhIPNZP7hWBcfhbML 2FuWzFBgCg8oP7
IO3XnD88+So404b7Kb8QF4g=
=Fl/i
-----END PGP SIGNATURE-----
Old December 5th 04, 02:36 PM
James
airport
regulations.
that's a
called "part 91".
simply
Australia just "rolled back" quite a few of the changes, mainly due to
opposition from air traffic control unions, who might lose some jobs.
They were trotting out safety, that with much emptier skies, which do
not have that much radar coverage that a US style system would not work.
Also some airline pilots did not like the changes as they might have to
look out the window for VFR planes. There was actually talk (from
airline pilots) of establishing "Professional Airspace." where those
pesky general aviation people would not be able to fly. For more
infomation about this debate do a google search on google.com.au and
select the search option of Australia only, and search for New Airspace
system.
James.
Old December 5th 04, 02:30 PM
Blueskies
"Charles Talleyrand" wrote in message ...
snip
European rules?
The FAA is rewriting some regs to fall in line with the JAA, believe it or not. Way back when, the European regs used to
follow the FAA regs pretty closely, but now they are starting to set the standards and impose them on US operators...
Old December 5th 04, 07:39 PM
Matt Whiting
snip
European rules?
It will be pretty funny when they each look like the other's regulations
USED to be and are still different from each other. :-)
Matt
Old December 5th 04, 03:28 PM
Bill Denton
How does the ICAO fit into all of this?
I was under the impression that they were a multi-national organization that
dealt with "coordinating" aviation activities among nations.
From what I understand, the ICAO puts forth a set of rules from which
individual nations could extract subsets, or create supersets of, with the
essential idea being to create a "core" set of rules that all signatory
nations would abide by.
Among many things I don't know is what the scope and depth of these rules
is. I know they cover stuff like runway designs and things like that, but do
they also cover such things as required aircraft equipment, pilot training,
and similar issues. And do they go down to the "Section 1.2.3.4.5" level?
Also, do they apply only to commercial aviation, or is all GA covered?
If anyone has any additional info, TIA!
airport
a
called "part 91".
European rules?
Old December 6th 04, 10:23 PM
Blueskies
"Bill Denton" wrote in message ...
I recently saw an article that described changes to the FARs for SIC pilots; required that they have a SIC type rating
or similar to fly in ICAO countries, Needed to be done ASAP, or the flight crews were going to be cited.
Old December 12th 04, 04:17 AM
The ICAO requirements for a Comercial are what the FAA now uses.
Explain to me the logic of requiring the comercial to be done in a
complex aircraft when most of GA training is done in fixed gear. All
any one needed was an endorsement for complex... But now the test must
be in a complex.
Then, explain why you need 3 landings on the 250NM straight, 300NM
total. By the time you are working on a comercial you should know how
to land, right? ICAO says you have to have the 3 landings and this must
be SOLO.
Wanna ask the FAA why? Have fun, because they will quote you ICAO.
So yes, the ICAO even specifies training.
Later.
Steve.T
Old December 5th 04, 08:05 PM
Thomas Borchert
Charles,
do a google search on ICAO.
Thomas Borchert (EDDH)
Moore Plays The Nation's Liberals For Fools W. D. Allen Sr. Military Aviation 3 June 30th 04 12:41 PM
LEFT WINGERS IN FOR BIG SURPISE - STROKES TO FOLLOW ELECTION Jarg Military Aviation 3 April 20th 04 06:37 PM
No End to War Grantland Military Aviation 0 March 26th 04 04:20 AM
Follow up Alright, All You Dashing, Swaggering Bush Pilots wmbjk Home Built 135 September 8th 03 06:09 AM
Follow up on fuel drains Mike Noel Owning 2 August 27th 03 01:51 PM
