#21
![]() Ron Garret wrote: What should you do if you lose your engine just after turning base to final? That's going to depend on the type of landing I was planning to make. With a normal landing, I won't have power on at that point, so let's assume I'm dragging it in for a short field landing. Or maybe I just screwed up and I have power on 'cause I'm a little low. If I've got flaps down, up they come. I will lower or raise the nose as necessary to hit 83 mph (best glide). I'll reduce that speed when I flare. Then I will hit the cheapest and softest thing out there as slowly as I can. George Patterson The desire for safety stands against every great and noble enterprise. |
I typically pull the throttle all the way back to idle about 1/4 mile
out, Cessna 172. I suggest that you should not be on final 1/4 mile out. Fly the pattern so you can make the runway from any point on downwind, base, or final, if the engine quits. vince norris |
![]() "vincent p. norris" wrote: I suggest that you should not be on final 1/4 mile out. That would be short final distance. At normal approach speeds and descent rates, you should be about 200' AGL at 1/4 mile out. George Patterson The desire for safety stands against every great and noble enterprise. |
#24
"vincent p. norris" wrote in message
... I typically pull the throttle all the way back to idle about 1/4 mile out, Cessna 172. I suggest that you should not be on final 1/4 mile out. Fly the pattern so you can make the runway from any point on downwind, base, or final, if the engine quits. vince norris Doesn't 500' AGL at 1/4 mile equal a 3 degree glideslope? (6076 / 4) / 500 = 3.038 You don't think you'd hit pavement from 1/4 mile out at 500' AGL? Do you consider 1/4 mile out turning base to final a "bomber pattern." Jay Beckman PP-ASEL Chandler, AZ |
#25
Ron Garret wrote:
The discussion about cutting power on final reminded me of something I've been puzzled about for some time now. If you fly final with some amount of power (which I gather most people do -- I always have) that seems to guarantee that if you lose your engine on final you will land short, and there's pretty much nothing you can do about it. Is that true? Or have I missed something? What should you do if you lose your engine just after turning base to final? Is that true? Have you missed something? Yes, lots! 0. Airspeed! Best place to land! (Rmember ABC) 1. Raise flaps 2. Prop low RPM 3. Raise gear 4. Then quickly run through obvious engine stuff - don't forget to pump the primer Of course, 1-4 apply if you think you're not going to make a runway. Hilton |
#26
Yes, that's true, and it's why the Old Timers taught power-off
landings, and it's why I fly them routinely. (To tell the truth, I also like the feeling of whooshing down without that engine blatting away. Perhaps I was a glider pilot in another life.) -- all the best, Dan Ford Dan, when I was flying those Cubs at your place.. I was taught that in winter it is best to keep some power up.. letting it idle would cool those cylinders and the spark could go out.. but a J-3 should never fly a pattern outside of power off glide anyway. I've seen the spark go out when idling on the ground in cold weather. BT |
#27
On Fri, 21 Jan 2005 09:58:29 -0600, David Gunter
wrote: So what do you do when you are on 1/4-mile final and you spot a coyote or two playing around in the middle of the runway? I'd put on power and go around. I didn't say I switched the engine off, only that I went to idle when abreast the landing spot. We have some (a few) coyotes in SE New Hampshire. When I first saw them, on the ice in the moonlight, I thought they were wolves, one blonde and one dark. Gorgeous animals. Took my breath away. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#28
On Fri, 21 Jan 2005 22:02:10 -0800, "BTIZ"
wrote: Dan, when I was flying those Cubs at your place.. I was taught that in winter it is best to keep some power up.. letting it idle would cool those cylinders and the spark could go out.. but a J-3 should never fly a pattern outside of power off glide anyway. I've seen the spark go out when idling on the ground in cold weather. When 80 octane became impossible to get, the airport got STCs for the Cubs and brought in mogas from a supplier in Maine (no MBTE or alcohol). By coincidence or not, we experienced a rash of engine quitting in cold weather. Generally of course this was on the ground, but even that can be awkward if it's at another airport--nobody wants to be involved with propping a Cub any longer. But it happened to an instructor while doing stall training with a student, very bad. (He started the engine again by diving the Cub.) So the rule came in: we can't rent the planes unless the thermometer is over 20 degrees. (They also pulled the STCs and placarded the Cubs for 100LL only. There's one school of thought that holds that this was less because of engines quitting than because one instructor didn't like the smell of mogas.) Anyhow, it's very unlikely that an engine will quit in the pattern, until you flare. That's my conclusion from that winter's flying. (That is: quit because it's at idle and not at 1500 rpm.) -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#29
On 21 Jan 2005 11:46:20 -0800, "Michael"
wrote: Many instructors teach power-off patterns (idle abeam the numbers). I teach it too, but not as a normal procedure. It's simply not practical most of the time (due to traffic). This of course is the whole point. Power-off landings are the sensible thing to do, but traffic at some airports makes them unwise. I don't know if it's "most of the time"; certainly it's very seldom that I encounter heavy traffic. I almost always fly power-off from the time I am abreast my landing spot, and that's fine at the airports I inhabit. I am almost never in the pattern with another aircraft--and if there is, it's usually another Cub. If there is a plane on the runway when I am in the pattern, I reckon it a busy day; if two, a very busy day. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#30
![]() "Jay Beckman" wrote in message news:jHlId.4912$hu.3754@fed1read01... "vincent p. norris" wrote in message ... I typically pull the throttle all the way back to idle about 1/4 mile out, Cessna 172. I suggest that you should not be on final 1/4 mile out. Fly the pattern so you can make the runway from any point on downwind, base, or final, if the engine quits. vince norris Doesn't 500' AGL at 1/4 mile equal a 3 degree glideslope? (6076 / 4) / 500 = 3.038 You don't think you'd hit pavement from 1/4 mile out at 500' AGL? Do you consider 1/4 mile out turning base to final a "bomber pattern." Jay Beckman PP-ASEL Chandler, AZ You can make the runway on a 3° glideslope when deadstick? |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Night engine failure in Boston | Dan Luke | Piloting | 8 | February 13th 04 05:33 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
