Engine failure on final
Old January 21st 05, 08:56 AM
Ron Garret
Default Engine failure on final
The discussion about cutting power on final reminded me of something
I've been puzzled about for some time now.
If you fly final with some amount of power (which I gather most people
do -- I always have) that seems to guarantee that if you lose your
engine on final you will land short, and there's pretty much nothing you
can do about it. Is that true? Or have I missed something? What
should you do if you lose your engine just after turning base to final?
rg
Old January 21st 05, 09:16 AM
Happy Dog
"Ron Garret"
Unless you do every landing power off with room to spare, yes. Or, aim for
the mid point of a 2500' plus field. There are ways to do it. But, almost
nobody does. Base turn should be doable power off in most cases in a 172 or
similar glider.
Land short. That's why the slow idle check during the run-up is important.
moo
Old January 21st 05, 08:30 PM
Julian Scarfe
"Happy Dog" wrote in message
The flip-side of doing every landing power-off, particularly when training
in the pattern, is that you *may* be putting enough extra stress on the
engine to make it *more* likely that the engine will fail in a difficult
position. Hence you may be increasing the overall risk by that pattern of
behaviour.
With typical trainers, it seems unlikely that it would have much long-term
effect. But with larger engines that require more delicate handling, I'd be
very reluctant to fly power-off landings on a regular basis. The effect may
be small but so is, as Michael said, the chance of a catastrophic engine
failure during the period when your glideslope makes a difference.
I'm surprised that the only two accidents that have been cited involve IFR
flights on an approach. They may not have had a choice of glideslope.
Julian Scarfe
Old January 21st 05, 10:43 AM
Cub Driver
On Fri, 21 Jan 2005 00:56:22 -0800, Ron Garret
Yes, that's true, and it's why the Old Timers taught power-off
landings, and it's why I fly them routinely.
(To tell the truth, I also like the feeling of whooshing down without
that engine blatting away. Perhaps I was a glider pilot in another
life.)
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
Old January 21st 05, 03:58 PM
David Gunter
So what do you do when you are on 1/4-mile final and you spot a coyote
or two playing around in the middle of the runway? This has happened to
me repeatedly in Santa Fe and just serves to remind me that I want some
backup power just in case the landing isn't assured. Perhaps you don't
see this where you fly "routinely" but it could always be something else.
I typically pull the throttle all the way back to idle about 1/4 mile
out, Cessna 172.
-david
David Gunter
Santa Fe, NM
you can do about it. Is that true?
life.)
Warbird's Forum:
Old January 21st 05, 07:22 PM
Scott D.
On Fri, 21 Jan 2005 09:58:29 -0600, David Gunter
This has happened to me repeatedly in Santa Fe
I have only flown into SAF three times and that has been in the last 4
months and EVERY time I flew in there, there were always coyotes on
the runway or taxiway. Seems like they would try and do something
about that.
Scott D
To email remove spamcatcher
Old January 22nd 05, 03:40 AM
vincent p. norris
out, Cessna 172.
I suggest that you should not be on final 1/4 mile out. Fly the
pattern so you can make the runway from any point on downwind, base,
or final, if the engine quits.
vince norris
Old January 22nd 05, 05:37 AM
G.R. Patterson III
That would be short final distance. At normal approach speeds and descent rates,
you should be about 200' AGL at 1/4 mile out.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old January 24th 05, 01:57 PM
Brian
Let's see: 1/4 @ 200 ft that would be:
1/4 mile = 6040/4 = 1510 ft
1510/200 = 7.55 L/D required.
OK maybe flaps up and best L/D Speed a C-172 might have 7.5 L/D ratio.
Of course that assumes no head wind.
I think I would prefer to be a little bit higher that that in most
cases .
Brian
CFIIG/ASEL
Old January 22nd 05, 05:40 AM
Jay Beckman
"vincent p. norris" wrote in message
out, Cessna 172.
vince norris
Doesn't 500' AGL at 1/4 mile equal a 3 degree glideslope?
(6076 / 4) / 500 = 3.038
You don't think you'd hit pavement from 1/4 mile out at 500' AGL?
Do you consider 1/4 mile out turning base to final a "bomber pattern."
Jay Beckman
PP-ASEL
Chandler, AZ
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 06:23 PM
Diesel engine Bryan Home Built 41 May 1st 04 07:23 PM
Night engine failure in Boston Dan Luke Piloting 8 February 13th 04 05:33 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
