#31
![]() "Hilton" wrote in message ink.net... Ron Garret wrote: The discussion about cutting power on final reminded me of something I've been puzzled about for some time now. If you fly final with some amount of power (which I gather most people do -- I always have) that seems to guarantee that if you lose your engine on final you will land short, and there's pretty much nothing you can do about it. Is that true? Or have I missed something? What should you do if you lose your engine just after turning base to final? Is that true? Have you missed something? Yes, lots! 0. Airspeed! Best place to land! (Rmember ABC) 1. Raise flaps 2. Prop low RPM 3. Raise gear 4. Then quickly run through obvious engine stuff - don't forget to pump the primer Of course, 1-4 apply if you think you're not going to make a runway. Hilton Also, lower nose if necessary to get best glide speed... |
#32
On Fri, 21 Jan 2005 22:40:33 -0700, "Jay Beckman"
wrote: "vincent p. norris" wrote in message .. . I typically pull the throttle all the way back to idle about 1/4 mile out, Cessna 172. I suggest that you should not be on final 1/4 mile out. Fly the pattern so you can make the runway from any point on downwind, base, or final, if the engine quits. vince norris Doesn't 500' AGL at 1/4 mile equal a 3 degree glideslope? (6076 / 4) / 500 = 3.038 Methinks you forgot to apply the appropriate trigonometric function. What you should have done is: glideslope angle = arctan(rise/run). In this case that would be: glideslope angle = arctan(500/1500) = 18.4 degrees. Pretty steep. ;-) Working it the other way, for a 3 degree glideslope, at 500 ft you'd still be 1.57 nm from the end of the runway. Unless you're flying a glider, you need power to hold a 3 degree glideslope. You don't think you'd hit pavement from 1/4 mile out at 500' AGL? Do you consider 1/4 mile out turning base to final a "bomber pattern." What I enjoy doing is flying downwind about 3/4 mile offset from the runway and if "cleared to land" during the downwind, I go to idle abeam the numbers and fly a circular arc to touchdown. No flaps (don't have any) in an Extra 300L. Drops like a rock. Holding 90 kts to the flare retains plenty of energy for the flare. I'd probably do it differently in a 172. ;-) Klein |
#33
![]() Cub Driver wrote: On Fri, 21 Jan 2005 00:56:22 -0800, Ron Garret wrote: If you fly final with some amount of power (which I gather most people do -- I always have) that seems to guarantee that if you lose your engine on final you will land short, and there's pretty much nothing you can do about it. Is that true? Yes, that's true, and it's why the Old Timers taught power-off landings, and it's why I fly them routinely. (To tell the truth, I also like the feeling of whooshing down without that engine blatting away. Perhaps I was a glider pilot in another life.) You've got it in one Dan ! Every landing in a glider/sailplane is a forced landing and circuit planning becomes nearly automatic. However with all the posters talk of glideslopes and rates of descent and other esoteric subjects remember there are two laws a pilot has to follow. 1) Fly the aeroplane 2) For anything else refer to 1 :-) |
#34
Recently, Larry Dighera posted:
On Fri, 21 Jan 2005 12:41:39 GMT, "Neil Gould" wrote in :: As I was taught, the point of flying safely is to always have a viable option. So, I fly tight patterns and make power-off landings as a rule. If I make it to the pattern, I can make it to a runway, engine or no. Truly? So when you're #5 in the pattern (which necessitates a looooong, extended downwind leg) you just fly the pattern at 2,000' then? Of course not, one has to use common sense, for example, fly the pattern slower rather than lower or hold altitude on that "looooong, extended downwind leg" rather than descend after crossing the usual abeam point and turn base within gliding range. If you don't guarantee that you can make the runway, who will? ;-) Neil |
#35
#36
In the Marines, I spent about two years flying an R5C (what the Air Force called a C-46). It was the size of WW II heavy bombers. We routinely flew finals of less than 1/4 mile. In a Cherokee or C-172, two or three hundred yards are plenty. vince norris |
#37
Not to pick nits... but... doesn't an idle engine put out some thrust? I
suspect (please don't hesitate to correct me if I'm full of it... it happens with surprising regularity) that if you're making any kind of a short field landing, you're going to be out of glide range when the engine quits. The best solution is to land at airports with a really nice safety zone before the runway. -Rob "Cub Driver" wrote in message ... On Fri, 21 Jan 2005 09:58:29 -0600, David Gunter wrote: So what do you do when you are on 1/4-mile final and you spot a coyote or two playing around in the middle of the runway? I'd put on power and go around. I didn't say I switched the engine off, only that I went to idle when abreast the landing spot. We have some (a few) coyotes in SE New Hampshire. When I first saw them, on the ice in the moonlight, I thought they were wolves, one blonde and one dark. Gorgeous animals. Took my breath away. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#38
On Sat, 22 Jan 2005 21:31:46 GMT, "Neil Gould"
wrote in :: Recently, Larry Dighera posted: On Fri, 21 Jan 2005 12:41:39 GMT, "Neil Gould" wrote in :: As I was taught, the point of flying safely is to always have a viable option. So, I fly tight patterns and make power-off landings as a rule. If I make it to the pattern, I can make it to a runway, engine or no. Truly? So when you're #5 in the pattern (which necessitates a looooong, extended downwind leg) you just fly the pattern at 2,000' then? Of course not, one has to use common sense, for example, fly the pattern slower rather than lower So your aircraft is slow enough to permit you to remain within gliding distance of the threshold at normal pattern altitude while four other aircraft head cross country several miles from the runway? Doubtful. or hold altitude on that "looooong, extended downwind leg" rather than descend after crossing the usual abeam point and turn base within gliding range. See above. If you don't guarantee that you can make the runway, who will? ;-) The power developed by your engine. At John Wayne airport (a Class C facility) it is not unusual to find yourself on downwind well outside the surface area during "rush hour" operations. It's not feasible to remain within power off gliding distance of the runway threshold at these times. An instrument approach imposes similar difficulty in maintaining power off gliding distance to the runway. I can understand how it can reduce exposure to landing short, but I don't find it often possible except at times of low traffic density. |
#39
Rob Montgomery wrote:
Not to pick nits... but... doesn't an idle engine put out some thrust? On the ground while taxiing, sure it does, just take your feet off the brakes and away you go. At flying speed however, it (perhaps surprisingly) causes drag. Hilton |
#40
On Sun, 23 Jan 2005 09:28:17 GMT, "Hilton"
wrote in . net:: Rob Montgomery wrote: Not to pick nits... but... doesn't an idle engine put out some thrust? On the ground while taxiing, sure it does, just take your feet off the brakes and away you go. At flying speed however, it (perhaps surprisingly) causes drag. Do you think that drag caused by an idling engine (and propeller) is increased or decreased when it is producing zero power instead of idle power? |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Night engine failure in Boston | Dan Luke | Piloting | 8 | February 13th 04 05:33 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
