#41
"Larry Dighera" wrote in message
... Do you think that drag caused by an idling engine (and propeller) is increased or decreased when it is producing zero power instead of idle power? It's an interesting question. http://naca.larc.nasa.gov/reports/1934/naca-report-464/ includes comparison of a stopped prop, feathered prop, windmilling prop, windmilling prop attached to a dead engine, and a prop driven by an idling engine. At low speeds, the idling engine produces thrust, while at higher speeds (75 mph in the case of the experiment) it is almost indistinguishable from the prop driving a dead engine. Julian Scarfe |
#42
Recently, Larry Dighera posted:
On Sat, 22 Jan 2005 21:31:46 GMT, "Neil Gould" wrote in As I was taught, the point of flying safely is to always have a viable option. So, I fly tight patterns and make power-off landings as a rule. If I make it to the pattern, I can make it to a runway, engine or no. Truly? So when you're #5 in the pattern (which necessitates a looooong, extended downwind leg) you just fly the pattern at 2,000' then? Of course not, one has to use common sense, for example, fly the pattern slower rather than lower So your aircraft is slow enough to permit you to remain within gliding distance of the threshold at normal pattern altitude while four other aircraft head cross country several miles from the runway? Doubtful. Larry... be reasonable! Few are likely to assess the situation and insist that they fly the pattern in an irresponsible manner (although, I've been in the pattern with some of those "few", as well). There are times when I find myself behind some folks in a Cessna flying a base leg 2 or 3 miles out, and in such a situation, I don't cut them off. ;-) I'm only pointing out that there are usually other options than just flying long downwind patterns and relying on engine power to save your bacon, and being practiced with those options is a Good Thing. And, I realize that if you're flying into busy air space, you don't have the option to practice. ;-) Neil |
#43
On Sat, 22 Jan 2005 11:28:26 -0700, Klein wrote:
I go to idle abeam the numbers and fly a circular arc to touchdown. No flaps (don't have any) in an Extra 300L. Drops like a rock. Holding 90 kts to the flare retains plenty of energy for the flare. I'd probably do it differently in a 172. ;-) I'd love to try this, but I fear I couldn't see the runway in the arc. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#44
On Sat, 22 Jan 2005 21:28:09 -0500, "Rob Montgomery"
wrote: Not to pick nits... but... doesn't an idle engine put out some thrust? I asked my friend/CFI about this. He reckoned that it netted out to about zero, and that I probably wouldn't notice the difference. The only time the plane ever moved when the engine was at idle was on glare ice. Then it taxied so fast that the only way I could negotiate the turns (race-track oval plowed out) was to switch to right magneto, the one that shows the greater drop. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#45
and that will often mean flying a little faster than that since you are
probably gliding upwind to a point on the ground, after discounting the fact that you are probably far below gross. If you don't have a feel for that speed, err on the high side if there is a wind. Blueskies wrote: Also, lower nose if necessary to get best glide speed... |
#46
Cub Driver wrote: I asked my friend/CFI about this. He reckoned that it netted out to about zero, and that I probably wouldn't notice the difference. There is thrust at idle, and it's enough to make a difference. Have you CFI go up and make a true dead stick landing, he'll change his story. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
#47
In article . net,
"Hilton" wrote: On the ground while taxiing, sure it does, just take your feet off the brakes and away you go. At flying speed however, it (perhaps surprisingly) causes drag. But not as much drag as a windmilling propellor. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
#48
Nobody has mentioned that one of the reasons to avoid aiming for the numbers
and to plan your touchdown point to be at the 1/3 point of a std 3000' training rwy is to allow a margin for an engine failure on short final. When doing a round base to touchdown approach this will also allow you to see the runway sooner. In the real world you may be connecting a round approach with a short field landing and will have to identify the features of the extended centerline to navigate by. Caution, there are many opportunities for CFIT. Combining this approach with a constant slip allows you to control your decent rate. I found it useful to practice this maneuver with some power on to provide better engine temperature management. If you do this you will be set up just right for soft field practice, and will avoid the inevitable small stumble that often happens when you advance the throttle on a cold idling engine. At a busy training airport this maneuver, combined with a request to ATC for simulated engine failure exercise(when making downwind call) will allow you to pass a slow or underpowered&heavier aircraft or one that seems to be on a xc circuit. ATC is not allowed to suggest this to you but they will know exactly what you are doing. I have spent many practice hours doing this exercise on every circuit, if ATC is not able they will deny your request or sometimes give you a spacing or call your base if there is another ac that has not yet cleared the rwy. Aircraft with tandem seating are nice for this approach because they look the same right or left. Aircraft without flaps really like this approach especially in real engine out practice as it gives you great control of decent. You can't do it for real if you don't practice when its not.. Caution YMMV as always, seek qualified instruction, a high time taildragger instructor is a good bet, avoid 231 hr. wonders. Blue skies to all "Cub Driver" wrote in message ... On Sat, 22 Jan 2005 11:28:26 -0700, Klein wrote: I go to idle abeam the numbers and fly a circular arc to touchdown. No flaps (don't have any) in an Extra 300L. Drops like a rock. Holding 90 kts to the flare retains plenty of energy for the flare. I'd probably do it differently in a 172. ;-) I'd love to try this, but I fear I couldn't see the runway in the arc. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#49
Now hang on. The types of aircraft most of us fly will never have a
'windmilling' prop. The engine quits the prop stops ! and an idling engine will add to the 'gliding' distance |
#50
![]() "george" wrote in message oups.com... Now hang on. The types of aircraft most of us fly will never have a 'windmilling' prop. The engine quits the prop stops ! and an idling engine will add to the 'gliding' distance Been there and you are wrong. Maybe dead wrong. The engine stops, the prop windmills and the drag goes way up. In boats (sail) the rule of thumb is a windmilling prop is equal in drag to a flat disc the same diameter as the prop. Stop the prop and the boat speeds up. Don't suppose a fixed pitch airplane prop is any different. |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Night engine failure in Boston | Dan Luke | Piloting | 8 | February 13th 04 05:33 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
