Cessna 172 Fuel Flowmeter?
Old January 23rd 05, 11:47 PM
CVBreard
Default Cessna 172 Fuel Flowmeter?
Is the fuel flowmeter in the newer Cessna 172s (and others?) a true flow meter
(as in a small turbine meter generating pulses, etc.), or is it a pressure
gauge or pressure transmitter measuring the fuel pressure in (whatever)?
I got the you-know-what scared out of me while in flight and this *&^#@ thing
read ZERO, though everything else (RPM, EGT) was normal. It was OK before
take-off. It finally came off zero, but read low.
Hmmm?
Old January 24th 05, 02:49 AM
Bob Gardner
AFAIK, all "fuel flow" gauges in light aircraft read pressure, although they
are calibrated as flow meters. Good symptom of a clogged injector is high
fuel flow...not exactly intuitive.
Now when you get to Shadin and their equivalents, you are looking at
honest-to-goodness fuel flow. Again, AFAIK.
Bob Gardner
"CVBreard" wrote in message
meter
thing
Hmmm?
Old January 24th 05, 03:29 AM
Scott Skylane
Hmmm?
According to the Cessna factory parts book, the original equipment gauge
is fed by a pressure transducer.
Happy Flying!
Scott Skylane
Old January 25th 05, 01:52 PM
CVBreard
Which is measuring the pressure of ______________?
Old January 25th 05, 02:20 PM
Rod Madsen
Probably differential pressure across an orifice. These transducers are now
very inexpensive, except in the aviation market.
Rod
Old January 25th 05, 09:41 PM
Sport Pilot
That is a valid and accurate way of measuring flow, almost as accurate
as a turbine meter and has less to go wrong. The same method is used
to meter large water flows from water plants and into large plants.
Old January 25th 05, 10:51 PM
CVBreard
Measuring the pressure in ________?
Old January 26th 05, 07:00 AM
Scott Skylane
Fuel, at the flow divider on top of the engine. This is called metered
pressure, as it is the fuel pressure downstream of the servo unit, just
before it enters the injector nozzles. As you stated, in this case, a
plugged injector, that results in a loss of total fuel flow into the
engine, will register as a fuel flow(pressure) *increase*.
Happy Flying!
Scott Skylane
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
Cessna 150 Long Range Fuel Tank Install Ted Timmons Owning 3 May 16th 04 08:06 PM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 05:56 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
