Cessna 150 Long Range Fuel Tank Install
Old May 15th 04, 07:51 PM
Ted Timmons
Default Cessna 150 Long Range Fuel Tank Install
I have a 1975 Cessna 150 Aerobat.
I want to replace the standard 26 gal (13 per side) fuel tanks
with the optional 38 gal (19 per side) long range fuel tanks.
Can anyone tell me where I can have this done and the approximate cost.
Old May 16th 04, 02:03 AM
Greg Hopp
"Ted Timmons"
Ted:
Go on over to the Yahoo! Groups, and join the Cessna150_152_group.
(It's free). There are several A&P's and lots of helpful folks who
all own Cessna's in that group and probably some who have the L/R
tanks already.
BTW, the National Fly-In for 150/152's is July 22-25 in Clinton, Iowa.
Everyone is welcome. http://www.cessna150-152club.com/
Greg H.
N4691X '67G
Old May 16th 04, 02:15 AM
Matthew P. Cummings
I don't know if the plane will retain it's aerobatic abilities since many
STC's remove that from the plane upon modification. However, if you want
the original design you'll have to find a pair of Cessna Wings to do it,
not easy. There are the Flint Wing Tip tanks out there, it's very very
expensive to do however.
Go to the Cessna 150 -152 group on egroups.com and search the archives and
you'll find it. I have a friend named Wayne in Tx that installed them on
his 150/150 and loves them, but rarely fills them because it's almost
impossible to fly legally with all the tanks full unless you're a real
lightweight pilot and flies solo, but if you are, they're good.
They work by a mechanical fuel transfer, i.e. you flip a switch after
flying so long and transfer the fuel from the tip to the mains. If you
pump to long it goes out the overflow tube.
Near as I remember him saying, it's several thousand to do the
modification.
Old May 16th 04, 09:06 PM
MichaelR
I've heard good reports about the O&N mods:
http://www.onaircraft.com/Aux%20Tanks.htm
"Ted Timmons" wrote in message
fuel tank plumbing pwm Home Built 18 January 27th 05 05:54 AM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 03:21 AM
Fuel Range Toks Desalu Home Built 2 November 14th 03 01:51 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 08:09 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
