Prop Strikes
Old January 26th 05, 02:43 PM
Jay Honeck
We went through the prestart checklist, and I engaged the starter only
to hear a loud clunk as the first blade went by. He had left the tow
bar on the front gear leg.
I saw a guy do that once.
Hitting the tow bar may not damage the prop, but it sure would damage
whatever the tow bar hit. In the case I witnessed, the prop whipped the tow
bar into the adjacent hangar wall with surprising force. It was only luck
that kept it from hitting a car or bystander.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 26th 05, 02:57 PM
Paul kgyy
Upper Cowl separated on one side on my Arrow in flight - wind blew it
up on the windshield and since the other side remained attached, it
twisted and put about a 1/8 inch dent in the back of both blades.
Mechanic insisted I tear the whole #$&$ engine apart. One blade turned
out to be out of spec, couldn't find replacement 2blade prop, ta da ta
da da da. That's how it goes with airplanes. At least I know the
engine is nice & clean inside and the new 3 blade prop looks nice.
Old January 26th 05, 03:22 PM
John
In that same vein, with winter conditions, how about the frozen humps
from snow plows that are waiting to get the nose gear struts with
attendant prop strikes or linkage damage?
Owwww
Ol S&B
Old January 26th 05, 04:05 PM
Dan
I had a similar landing incident when the very experienced ag pilot in
the front seat "stuck" the aircraft with positive forward stick on
touchdown and put sand marks about 6" up the prop blade and bent the
blades. We didn't follow up with any take off though. He was using his
usual technique of forward stick with the Stearman he had been using
for spraying and this time it didn't work on the Champion Scout we were
flying. I was showing him the aircraft and it was his first flight in
it. There is more to the story and in retrospect it's humorous but
nontheless serious.
Ol S&B
Old January 26th 05, 04:22 PM
Larry Dighera
On Wed, 26 Jan 2005 14:43:35 GMT, "Jay Honeck"
wrote in q0OJd.29738$EG1.8340@attbi_s53::
We were fortunate. The tow bar remained attached to the gear leg. I
presume this meant that the cylinder failed to fire in the first 180
degrees of prop rotation.
Old January 26th 05, 04:31 PM
Peter R.
) wrote:
Anyone else here ever experience one? How did yours happen?
I have not experienced one personally, but a flight instructor and a
student from my flight school had landed at a nearby single strip
airport. Instead of back-taxiing down the runway, they opted to taxi on
the grass, which is actually an adjacent grass strip.
However, at the end of the grass strip they turned the aircraft around
to taxi onto the runway when the nose wheel dropped into a gopher hole.
The prop struck the soft ground but somehow neither student nor
instructor knew of the prop strike until they returned to our main
airport. Regardless of the softness of the ground, an engine tear-down
was needed.
Peter
Old January 26th 05, 04:51 PM
Sam O'Nella
You guys are freaking me out. I think I'll go buy an LA-4.
Old January 26th 05, 06:20 PM
Scott D.
On Tue, 25 Jan 2005 23:10:02 -0500, Peter R.
Not yet.
Two types of pilots, those that have and those that will??
Thats more true with retract pilots than with the tow bar!
Scott D
To email remove spamcatcher
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Metal Prop vs. Wood Prop Larry Smith Home Built 21 September 26th 03 07:45 PM
fatal bird strike StellaStar Piloting 9 July 13th 03 09:41 PM
