Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Spar Dimensions for J-3 and/or Aeronca Champ
Old March 22nd 04, 01:34 AM
Default Spar Dimensions for J-3 and/or Aeronca Champ
We've got some Fly Baby builders who are considering building the Hevle
Classic tandem Fly Baby. We're trying to work out what would be a good
thickness for the spruce spar. My thought was that comparing it to that of
a production plane would be a good start.
So, can anyone tell me the thickness, height, and length of the wooden
spars for the J-3 and the Aeronca Champ?
www.BowersFlyBaby.com
Old March 22nd 04, 01:02 PM
jls
of
Ron, the wood spar dimensions for the BC12D model Taylorcraft are as
follows:
The front spruce spar measures ¾ inch thick by 5-11/16 inches tall
The rear spruce spar is 5/8 inch thick and 4-3/8 inches tall.
So far, no AD's on the Taylorcraft's spars, knock on wood.
For wood specifications Grain, knots and moisture content refer to following
FAA website
To look in the Advisory Circular 43.13 found at:
http://www.airweb.faa.gov/Regulatory...visoryCircular
..nsf/0/CCFE0D58D41D2C8086256A55006C6B67?OpenDocument&High light=wood
Old March 22nd 04, 03:07 PM
follows:
Thanks much, this helps. The single-seat Fly Baby spars are almost exactly
the same, except the aft spar is 3/4" like the front. No one is sure how
much margin is in the spar itself, though an entire wing was static-tested
to 6Gs in Finland. The gross for the two-seat Fly Baby is about 500 lbs
higher; the need to upgrade the bracing wires was obvious, but the issue
about the spar thickness wasn't.
Thanks again....
basic spar construction Dave Schneider Home Built 29 December 30th 04 02:07 PM
cvjetkovic ca-65 skyfly- plywood spar? patrick mitchel Home Built 3 October 16th 04 05:26 PM
Marske spar workshop Marske Flying Wings Restoration 0 October 14th 03 04:54 PM
Marske spar workshop Marske Flying Wings Home Built 0 October 14th 03 04:53 PM
Carbon Spar design and construction workshop Marske Flying Wings Home Built 0 September 18th 03 05:47 PM
