L-nav Settings Ventus 2ct-18
Old July 17th 03, 04:45 PM
Oliver Peters
Default L-nav Settings Ventus 2ct-18
Hi,
As there is no polar for the V2ct, does anyone have
any settings that they have used, that work well, for
an L-nav set up for a Ventus 2ct 18m?
L/d V2 etc
Many thanks OP
Old July 17th 03, 06:03 PM
Francis Svobodny
L/D = 47 at speed 105 km/h and speed 180km/h for polar point at -2m/s (at
empty weight and wings clean)
In any case, when you set MC= 1.4m/s with correct wind you will maintain
your glide path steady (L/D around 40) with speed beetween 110 and 150
km/h...
In addition, I use a security height of 200m.
I have used those settings with my Ventus 2c for 4 years and now with my
Ventus 2cm. They work very well.
"Oliver Peters" a écrit dans le
message de news: ...
Hi,
L/d V2 etc
Many thanks OP
Old July 18th 03, 12:27 AM
Mike Borgelt
On Thu, 17 Jul 2003 18:03:44 +0200, "Francis Svobodny"
km/h...
The V2CM has a considerably higher weight than the V2C. What empty
weights do you have for both?
Mike Borgelt
Old July 18th 03, 01:49 AM
Oliver Peters
The glider i had in mind is in fact an Ventus2ct. So
one would assume that the data given for that of the
V2c and the V2cm would not be that far out, am i correct?
Many thanks OP
Old July 18th 03, 05:14 AM
Mike Borgelt
On 17 Jul 2003 23:49:42 GMT, Oliver Peters
Many thanks OP
TheVentus 2C I'm familiar with had an empty weight of 272 Kg, the
V2CM I know have empty weights of around 360Kg . A not inconsiderable
difference. Even if the 2Ct is in the middle the other two vary by at
least 40 Kg from it.
Mike Borgelt
FS 2004 with multiple monitors - how to save settings? Horst Walter Simulators 5 December 8th 04 02:29 PM
Lycoming's views on best economy settings [email protected] Piloting 37 July 8th 04 05:00 PM
Piper Power Settings? Journeyman Piloting 8 April 28th 04 06:14 PM
Power settings for 182RG Andrew Gideon Piloting 19 March 3rd 04 08:41 PM
Cessna 404 Cruise settings Katia General Aviation 0 December 19th 03 06:04 PM
