Lycoming's views on best economy settings
Old June 29th 04, 06:55 PM
Default Lycoming's views on best economy settings
I was searching via Google for informational schematics, or even just
a written description, on Lycoming's fuel injection system because
it's different from Continental's.
I came across Lycoming's website in which a number of technical and
informational articles reside.
One of them
http://www.lycoming.textron.com/main.jsp?bodyPage=support/publications/keyReprints/operation/leaningEngines.html
discusses various mixture settings for their fuel injected engines.
Here is item no. 5 from that article, it's a description of how to
achieve "best power" and "best economy" when an EGT guage is
available:
5. The exhaust gas temperature (EGT) offers little improvement in
leaning the float-type carburetor over the procedures outlined above
because of imperfect mixture distribution. However, if the EGT probe
is installed, lean the mixture to 100oF on the rich side of peak EGT
for best power operation. For best economy cruise, operate at peak
EGT. If roughness is encountered, enrich the mixture slightly for
smooth engine operation. ***editorial note*** If you do this (richen
slightly from peak), the only place for the cylinderhead temperatures
to go is up. Slightly to the rich side of peak on the graph described
below is where the cylinderhead temps peak. So it would pay to be
careful how much you richen from the peak setting, if the engine is
running rough at that point. The Cessna 172 I rent has the EGT guage,
but no CHT guage. So you can richen from peak and drone happily along
not knowing that you are cooking the cylinderheads.
This particular section of the website includes a nice graph, which,
if you are familiar with John Deakin's "Mixture Magic" article, will
look very familiar. It should because all fixed spark engines will
show the exact same performance curves for things like EGT, CHT,
percent power and BSFC.
What was interesting to me is if you look at where peak EGT is
occuring and then go down to the BSFC curve is, you will see that you
have not yet reached the lowest BSFC. That doesn't occur until you've
leaned a bit further. But then you would be **LOP**. Notice it does
not take much additional leaning to get the lowest BSFC the engine is
capable of producing.
Here's the interesting part: At peak EGT, the cylinderhead temps are
already starting down from their peak, and the downward curve is
pretty steep once you get to peak EGT.
Just a tiny bit more leaning and the cylinderhead temps dive down
another full ten degrees, while the EGT has hardly gone down at all.
While this is going on, the percentage of power is dropping off too,
which is why economy cruise is slower than best power, of course.
Lycoming finishes the graph with the following statement: "Textron
Lycoming does not recommend operating on the lean side of peak EGT."
Yet as their own graph shows, best economy is ONLY achieved lean of
peak. What extremely interesting to me is that the difference between
peak and lean of peak where best economy occurs is only a matter of a
very few degrees EGT.
Remember, when you are cruising at 60% power, you cannot hurt the
engine no matter where you set the mixture control. You can't burn
valves or cook the cylinderheads or cause detonation, it just isn't
producing enough power to do that. Lycoming themselves recommends
that for maximum engine life, cruise power should be limited to 65%
and CHT's kept below 400 F. But since the instrument panel doesn't
include a CHT guage, the only way to avoid high temps is to be way
rich, or at peak EGT or below.
Why Lycoming recommends against LOP operation is a mystery. MUCH
cooler CHT's and less fuel being burned... what am I missing here?
Does the engine run roughly at this setting? Only those who try LOP
will know.
Corky Scott
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Naval Aviation 5 August 21st 04 01:50 AM
What's Wrong with Economics and how can it be Fixed What's Wrong with Economics and how can it be Fixe Military Aviation 3 August 21st 04 01:40 AM
Power settings for 182RG Andrew Gideon Piloting 19 March 3rd 04 08:41 PM
Cessna 404 Cruise settings Katia General Aviation 0 December 19th 03 06:04 PM
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble Small Blue Planet Toys Aviation Marketplace 0 July 11th 03 05:00 PM
