Weight
Old September 21st 04, 08:43 PM
LJ & Nancy Blodgett
Default Weight
what's the process to change the up weight on a Kitfox 7 to the Sport
weight of 1320#.Thanks LJ
Old September 21st 04, 10:32 PM
Del Rawlins
On Tue, 21 Sep 2004 12:43:59 -0700, LJ & Nancy Blodgett
Enter a gross weight of 1320# on the form when you register it.
Del Rawlins--
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Remove _kills_spammers_ to reply
Old September 22nd 04, 05:36 PM
Hatz Lyman C
Unfortunately you cannot lower a Gross weight to meet Sport Plane Standards
once an aircraft has been certified at a higher gross weight. Has your plane
already been certified (not the same as registered).
Lyman
Old September 22nd 04, 06:04 PM
LJ & Nancy Blodgett
Thank Del. The plane is all ready registered at 1550#,I want to lower
it to 1320# for a sport plane.It is one of the 15 planes we built as a
group. Thanks for any help. LJ
Del Rawlins--
Old September 22nd 04, 06:42 PM
Rich S.
"Hatz Lyman C" wrote in message
Standards
plane
Lyman
May I ask for your reference? Specifically for a reference that pertains to
an aircraft in the Experimental - Amateur Built category, not a production,
Type-Certificated design.
Rich S.
Old September 22nd 04, 07:50 PM
LJ & Nancy Blodgett
It has been fying and has about 80 hour now.It is registered.certified,I
don't understand.What would that intail(sp)? LJ
Lyman
Old September 22nd 04, 08:51 PM
Cy Galley
Here is my take that might work.
Ask that the listed gross weight is reduced. Why? because during the testing
phase, the plane didn't perform as expected. You felt unsafe at your tested
gross weight. For safety, please lower the gross weight to 1329.
Isn't the testing phase designed for checking out the plane's parameters so
it can be safely flown? If it isn't, why have a testing phase at all.
My Bellanca has a red line of 216 MPH. Why such a weird number? It is 90%
of the demonstrated test speed of 240 MPH. (240-24). For safety the CAA
dropped off 10%. You should be able to do the same from your testing
program.
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
"LJ & Nancy Blodgett" wrote in message
Todd,I don't know that it has been certified? It has been registered and
the 40 hours flowen off.If at all possible I would like to change the
weight,as the plane dose meet the Light Sport Plane in every way.
Todd Pattist wrote:
Standards once an aircraft has been certified at a higher gross weight.
to
production,
He's referring to the "since its original certification"
language below:
§1.1 General definitions.
Light-sport aircraft means an aircraft, other than a
helicopter or powered-lift that, since its original
certification, has continued to meet the following:
(1) A maximum takeoff weight of not more than--
(ii) 1,320 pounds (600 kilograms) ...
Todd Pattist
(Remove DONTSPAMME from address to email reply.)
___
Make a commitment to learn something from every flight.
Share what you learn.
Old September 22nd 04, 09:24 PM
LJ & Nancy Blodgett
language below:
(1) A maximum takeoff weight of not more than––
Todd Pattist
___
Old September 22nd 04, 09:25 PM
Rich S.
"Cy Galley" wrote in message
news:aJk4d.91311$D%.90322@attbi_s51...
testing
tested
so
program.
Cy...........
I feel somewhat the same about the "specified" gross weight of an
Experimental - Amateur Built aircraft. I'm not even sure the gross weight is
recorded with the FAA. I'm sure that the other parameters are not, such as
stall spped, max speed (Vh), propeller type, cabin pressurization - even
retractable gear.
Then too, there is the proviso that one may make changes - even major
changes - to an airplane of this class.
I will agree that the new regs do say in order to be certified as a LSA, the
aircraft must have, since it's original certification, continued to meet the
limitations. But in this case, we are not alking about changing the
certification of the aircraft. We are simply trying to meet the intent of
this statement:
"Aircraft with a standard airworthiness certificate that meet above
specifications may be flown by sport pilots. However, that airworthiness
certification category will not be changed to a light-sport aircraft.
Holders of a sport pilot certificate may fly an aircraft with a standard
airworthiness certificate if it meets the definition of a light-sport
aircraft."
It is a small point perhaps and one that may be better left unquestioned. It
is my feeling that the particular wording was adopted at the behest of the
existing and hopeful LSA aircraft manufacturers in order to sell more new
airplanes. I have no basis for this opinion except an assumption of avarice.
Letting the people who stand to make a buck set the rules of the game
doesn't seem kosher.
I suppose there is always the option of abandoning the certification of an
airplane and then going through the process again with a lower gross on the
data plate. Oh, BTW I would ask for 1319# - not 1329" )
Rich S.
Old September 23rd 04, 01:10 AM
Rich S.
Who do I ask? I do think your on the right track.Sence I have the repair
permit and I can change any thing as lone as it's loged,wy not the gross
weight?The one's at the airport say,why not,but so far,no real answer.SO
who DO I ask. LJ
Unless the language of the rules is changed, there may currently be a
conflict between the Sport Pilot regulations and the regs affecting
Experimental/Amateur built. I don't know. It may be better to NOT ask.
Rich "Just my take on it" S.
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight of a Harley Evo / Twin-cam 88 for aircraft? Wright1902Glider Home Built 3 June 4th 04 01:56 PM
Pitts S-1 weight and balance wallyairplanefan Aerobatics 2 March 6th 04 04:09 AM
Weight of snow on wings Michael Horowitz Home Built 10 January 4th 04 10:58 PM
Weight of Lycoming O290 Ray Toews Home Built 1 December 21st 03 11:56 PM
