#31
"The next time someone sneers at a wooden sailplane, remind them that it is
made of a unidirectional reinforced laminated composite material consisting of micro-tubular fibres embedded in a long chain polymer matrix and having a near infinite fatigue life." -Unknown- The wooden rotor blades on a Bell 47 helicopter (i.e. MASH) were "on condition" where as the metal blades are life time limited. |
#32
This is a troubling report. I've read both the French and English
version of the grounding order: the English version is an accurate translation. No mention of high time or turbulence. One finds oneself drawn to the conclusion that some sort of construction defect played a role. Tales of third party reports of insufficient resin are troubling and certainly deserve a more complete explanation, recognizing, of course, that liability is still being considered by lawyers. And recognizing too that there is such a thing as too much resin in composite aircraft construction: you don't just ladle on as much epoxy as gravity will hold in place if you are trying to find the best balance of strength and weight. But if a given factory is producing parts that fail in flight this certainly calls for more than hints of workmen drinking too much beer and inspectors abdicating their responsibility. Let's get serious with this, shall we? Does anyone have more than suspicions of beer drinking and third party negligence? |
#33
A classical composite is reinforced concrete. Steel reinforcing along with
concrete makes a composite structure. Concrete has fair compressive strength, 3-5,000 psi is generally used, with tensile strength of around 100-500 psi, miserable. When reinforcing steel, 40- 60,000 psi is added, and suffucient bond provided (like joining together two composite structures in a spar/skin joint), the steel takes the load in tension while the concrete takes the load in compression. (Steel rods in compression are OK only as short lengths before they buckle) This is a simple example: where a single bar of steel is in the bottom of a simple concrete beam and none is in the top. Loading produces tension in the bottom of the beam while compression is in the top. Each material then uses its best property to provide a composite structure superior to each individually. Bruce Patton (A civil engineer to pay for soaring) 96S, aka, JJ, " Tinman" |
#34
#35
As I write this, I am looking at a cross-section of an ASW-22 wing, taken from
a ship that has met with misfortune, It has styrofoam dams at the leading edge, on both sides of the upper spar cap and at the forward edge of the drag spar. These styrofoam dams were set just high enough to allow for a 10% excess of glue (epoxy resin, chopped fibers, micro-balloons) that were trawled in from the edge of one dam to the edge of the other dam. In this way, the construction crew was 100% sure that the proper amount of glue had been spread along the spar cap. When the upper skin was mated, all voids were filled and the excess 10% of resin was forced out each side into the styrofoam dams. The inside of this wing is a work of art. I would expect nothing less from all sailplane manufactures. JJ Sinclair |
#36
#37
"George William Peter Reinhart" wrote in message ...
Yep, Makes you wonder doesn't it? YUP. Where are the cut offs for High Time and "severe " turbulence that would make it not OK to fly? How about 1000 hours and/or 5 years. Currently flying a well aged Nimbus with over 1000 hours on it. No problem as long as you don't feel any "bumps" in the air. Or you could invest in a Ballistic Recovery Chute System. Should I be worried about my personal safety because of the airframe hours? YES Are there some days I just shouldn't fly because the "turbulence" might be "too high"? YES, DEFINATELY. Don't fly on days when the air is "bumpy". Cool winter mornings when the air is smooth should offer the safest "gliding" and don't bank in turns steeper than 45 Degrees. Tell your tow pilot to take off slowly. All advice carefully considered. Even advise which is recklessly given? Cheers! Guy Byars wrote in article ... I heard it was a high time glider in severe turbulence. And that makes it ok? |
#38
#39
Now I if you don't like the word "likely" when applied to this particular
process then you should not fly any composite glider because such assumptions, based on tests and real world experience, are used through the construction process. 100% inspection of every bonded joint is impossible given the constraints of manufacturing of gliders as it is done now. Perhaps these incidents will cause the LBA and manufactures to re-think the inspection standards. And likely raise the price of an already costly toy. Robert Mudd ************************************************** ********************************* W. Edwards Deming the father of statistical process control showed that a 100% inspection system will regularly miss 20% of the defects. The goal of manufacturing and design should be to develop a process which minimizes the likelyhood of defects, especially catastrophic defects. The DG website has a very detailed explanation of how a wing is constructed and I assume the technique is similar for all German designed gliders. Spar CAPS are formed with carbon fibre rovings and are inspected in minute detail for voids and any cap which fails inspection is immediately cut in half to preclude its inadvertant use. As the upper and lower wing skins are moulded, the spar caps are glued in place so that they are well bonded to the skin. So far so good, the top and bottom of an I-beam shaped spar are well built and in place. Next the shear web, which is also well built and inspected is glued into the bottom part of the spar cap. Gravity holds the glue in place and the surface is well lighted and clean so the craftsmen and inspectors can see what is happening. The wing spar is now an upside down T shape. Later on in the process the top surface of the wing is glued to the bottom half forming both a wing and a complete spar. It can be SEEN that the exterior surfaces of the wing are well mated because epoxy oozes out of the joints. It can only be ASSUMED that the upper spar cap is well bonded to the shear web because the glue joints cannot be seen. Assuming you have a good spar because of German craftmanship works because German craftsmen are quite good, but it is not a well designed manufacturing process. Building a complete spar outside of the wing and then bonding it to the upper and lower surfaces strikes me as a process much less likely to lead to a catastrophic failure. In the case of the Duo Discus and probably the Discus CS, failure of the spar is more of a process defect than an inspection defect. The price of these costly toys may indeed go up but something bad has just happened to the value of Shemp Hirth products. |
#40
"I assume the technique is similar for all German designed gliders."
Very bad assumption. Not even the same for all products from each mfg. |
| 18m Discus | Burt Compton | Soaring | 2 | September 8th 03 11:52 AM |
| Discus Wing question | John Galloway | Soaring | 6 | August 23rd 03 08:52 AM |
| DUO DISCUS GROUNDED AS OF 31 JULY 2003 | Eric van Geetsum | Soaring | 20 | August 18th 03 10:23 PM |
| Duo Discus Tech note | Thomas Knauff | Soaring | 25 | August 9th 03 11:10 PM |
| "France downplays jet swap with Russia" | Mike | Military Aviation | 8 | July 21st 03 06:46 AM |
