Discus CS grounded in France
Old September 9th 03, 12:01 AM
Marc Till
Default Discus CS grounded in France
French aviation authorities (DGAC) have just grounded the Discus CS,
because of an in-flight wing failure :
http://195.68.62.11/GSAC/ad_cns.nsf/...iques?OpenView
Apparently, it is not the case in Germany (nothing on the Schempp-Hirth
or LBA websites)
Has anyone got more news ?
Cheers
Marc TILL
Orsay, France
http://perso.club-internet.fr/mtill/
http://www.planeur-chartres.org/
Old September 9th 03, 03:50 AM
Guy Byars
I heard it was a high time glider in severe turbulence.
And that makes it ok?
Old September 9th 03, 01:13 PM
George William Peter Reinhart
Yep,
Makes you wonder doesn't it?
Where are the cut offs for High Time and "severe " turbulence that would
make it not OK to fly?
Currently flying a well aged Nimbus with over 1000 hours on it.
Should I be worried about my personal safety because of the airframe hours?
Are there some days I just shouldn't fly because the "turbulence" might be
"too high"?
All advice carefully considered.
Cheers!
Guy Byars wrote in article
Old September 9th 03, 03:04 PM
Mark Zivley
The wording in the english version of the French document says that
there was separation of the wing in normal operation with some
indication of a possible manufacturing defect.
Now, this may turn out to not be true, but if it is true this won't be good.
Tom Knauff
"Marc Till" ] wrote in message
or LBA websites)
Cheers
Marc TILL
Orsay, France
Old September 9th 03, 04:29 PM
Chris OCallaghan
Per the French Airworthiness Directive, "separation of the wing during
normal operating conditions, possibly the result of a manufacturing
defect."
Marc Till ] wrote in message ...
or LBA websites)
Cheers
Marc TILL
Orsay, France
Old September 9th 03, 10:43 PM
Guy Byars
I better check the spar splices in the 1-20 wing again! With a red line of
75mph, you can't be too careful.
Same happens as with a wooden glider.......
SF.
Old September 9th 03, 11:16 PM
Jim Vincent
JJ knows that...after all, wood and fiberglass are both composite aircraft;-)
Jim Vincent
CFIG
N483SZ
Old September 10th 03, 02:34 AM
Ian,
I've got a copy of the same articles.
I used to think my Mooney was a pretty high time at 7200 hours until I
parked it next to the sister ship with 4200+ hours.
There is still the "turbulence" though, so I'm wondering if I should fly
only on days when there is no lift.
Cheers! (and still trolling)
tango4 wrote in article
I have a copy of Technical Soaring, the July 2002 vol 26 number 2 that
discusses lifetime predictions of compostie aircraft. The general
conclusions seem to be that "lifetimes far in excess of the current 12000
hours" and "a lifespan of 50000 ( yes fifty thousand ) hours with a high
level of safety" so your 1000 hour Nimbus is hardly out of the running in
period!
Ian
"George William Peter Reinhart" wrote in message
Yep,
would
hours?
be
"too high"?
Cheers!
Old September 10th 03, 06:04 AM
tango4
Ahhh, now that is a completely different question. The material will last a
long, long time but if they haven't put any in the structure then all bets
are off!
Ian
"JJ Sinclair" wrote in message
Ian wrote a lifespan of 50000 ( yes
fifty
period!
But what if they didn't use enough glue?
JJ Sinclair
18m Discus Burt Compton Soaring 2 September 8th 03 11:52 AM
Discus Wing question John Galloway Soaring 6 August 23rd 03 08:52 AM
DUO DISCUS GROUNDED AS OF 31 JULY 2003 Eric van Geetsum Soaring 20 August 18th 03 10:23 PM
Duo Discus Tech note Thomas Knauff Soaring 25 August 9th 03 11:10 PM
"France downplays jet swap with Russia" Mike Military Aviation 8 July 21st 03 06:46 AM
