#71
Cliff Hilty wrote:
Exactly my point, Pilot E makes a decision to go straight in and land. Excepting the fact that he will lose points to the slowest finisher but also not pushing a bad situation. and landing at a good airfeild. I would reward this not penalize it! Pilot D instead is hoping for a break in the storm and risks losing points to pilot E with the hope of a payoff by making it home and pushing pilot E's score down. Seems to me that its a competetive pilots decision to make. Wow! I am absolutely astounded that you could conclude that pilot E deserves more points than pilot D in the scenario that I presented in my previous post. Is there anyone else out there in RAS-land that agrees with Cliff? I just don't see the need to have a single landout eliminate you from having a chance to win a contest! You obviously think that it is unfair for the landout to be penalized so severely, but have you considered that reducing or eliminating the landout penalty might be unfair to the pilots who do whatever it takes to finish the task? And doing "whatever it takes" usually does not mean risk-taking, but the antithesis of risk-taking: get high stay high, go around the blue hole, take a few extra turns in the last thermal, keep a large altitude margin throughout the final glide, etc. How many contests have you been to that after the first or second day a few competitors have dropped out because of landouts and knowing that they will not have a chance to place even in the top three? I don't think that's any reason to change the scoring system; I'd say those competitors need to change their attitudes. They are obviously placing too much importance on the ego-trip of winning, and not placing enough importance on taking advantage of a golden opportunity to improve and refine their cross-country soaring skills. When a pilot falls out of contention early in a contest, that's a great time for him to start experimenting with changes in his racing strategy, such as reducing his aggressiveness in the selection of thermals, or increasing his aggressiveness in making off-course excursions to seek out the best lift. A pilot who is leading or in contention cannot afford to indulge in such experimentation; he should be conservative and keep on doing whatever he's been doing. Gary Ittner P7 "Have glider, will race" |
#72
I got to agree with Marc, on this one. We are seeing a lot of MAT tasks and
about 3 hours after the gate opens, the sky is full of gliders coming from all directions. They hit the 1 mile, 500 foot gate, pull up, slow up, get in the pattern and start acting like gentlemen again. I flew 4 contests (one a nationals) that used the 500 foot, 1 mile gate this year, I like it and its much safer. At Montague the pilots were asked to get the winds form AWOS at 10 miles out and then switch over to gate frequency and LISTEN for finishers in front of them. I knew who was finishing and where to look. Its a damned safe way to run things. Any head-on traffic is seperated by 2 miles. I remember a finish line at Minden nationals a few years back.I finished at 50 feet, pulled up and banked over for a landing on 30. As I was turning final at 200 feet, I saw 3 other ships, already on final for 30, so I slid over to 30 taxiway, just before touch-down, someone slid in, right in front of me, on MY taxiway. When we finish at 50 feet, we have given up most of our options, any conflict may become a disaster. JJ Sinclair |
#73
#74
We fly 20 contest days per year here in Arizona Marc and every single one of
them ends with a one mile cylinder. That means that I have finished over 40 times in our ASA series in the past 2 years with the cylinder that you described so I doubt that you have any more experience than I do with the system. The problem is that you may do your "non-adrenaline junky easy pullup" but most of the pilots that fly contests will NOT be doing that either at one mile, two miles or fifty miles. So the scenario that you described of having someone come under you and pull up has exactly equal potential in your cylinder finish. In fact I would go further and argue that it has MORE potential since some pilots may continue to push fast toward home (you know we dangerous, arrogant, hedonistic types) inside the cylinder then pull with you now wafting around in your extended approach. The rules say nothing about how you are to enter the pattern or when to pull up. But then silly me.....I'm sure that's going to be on the table soon too! This also gets back to the crowd pleasing end as well. Frankly it would suck to sit out in the heat all day only to have your pilot finish by entering the pattern. Might as well go down to the local community airport and watch the Pipers land. Casey Lenox KC Phoenix |
#75
My closest near-miss
resulted from a high finish (I like having a cushion, I haven't finished a contest below 500 feet AGL in 10 years) and a normal pattern, then having someone make a redline pass less than 100 feet below me just before my base to final turn. He made the 4 mile call without specifying a direction, and never saw me. Now, when I'm in the pattern, whether at a contest, or not, I'm watching the runway, the windsock, etc., not for adrenaline junkies on the deck. Marc You raise a good point; the situation you described (below) can be very dangerous. But the solution doesn't have to involve steering turnpoints (which won't help as much if the landing direction doesn't coincide with the finish direction) or throwing away the old finish line. The pilot you described was at fault for not specifying a direction if there was any doubt (the direction can vary even in ASTs if the final leg involves a deviation for terrain or weather). But if I hear someone four miles out when I'm in the pattern and I don't see them right away, I go into frantic "look" mode and call out my position (e.g., JB turning left base). This is on top of the normal lookout for other traffic in the pattern. I will also radio the other pilot(s), as I did last week at New Castle when three of us were finishing (as it turned out) less than ten seconds apart from two different directions and three different altitudes/energies. It took 30 seconds on the way in to establish beyond a doubt that we had each other in sight and there was sufficient separation. Otherwise one or more of us would have pulled up and finished high. As with everything else in soaring involving other pilots (e.g., gaggles), I don't take anything for granted, even with ASTs, steering turns, OR finish cylinders. I'm not saying you did, but it sounds like there was more than one way to avoid the problem you recounted. Another solution is the displaced (to one side) finish line used at Elmira. Rolling finishes are still OK but flying finishes are parallel to but 1/4 mile away from the runway. Chip Bearden |
#76
"Kilo Charlie" wrote...
The problem is that you may do your "non-adrenaline junky easy pullup" but most of the pilots that fly contests will NOT be doing that either at one mile, two miles or fifty miles. So the scenario that you described of having someone come under you and pull up has exactly equal potential in your cylinder finish. In fact I would go further and argue that it has MORE potential since some pilots may continue to push fast toward home (you know we dangerous, arrogant, hedonistic types) inside the cylinder then pull with you now wafting around in your extended approach. The rules say nothing about how you are to enter the pattern or when to pull up. But then silly me.....I'm sure that's going to be on the table soon too! We had a problem with this at the Tonopah regionals in 2001. The center of the 1 mile cylinder was at the exact center of the airport, which placed the edge of the cylinder within the airport boundaries. Also many people (myself include) did not trust their computers, or weren't clear on the fact that the finish occurred at the edge of the cylinder, so they wouldn't pull up until they reached the airport center. By the 2002 regionals up here, everyone had pretty much figured how the finish cylinders worked, the CDs were using 2 mile cylinders when appropriate, and the pilots were all pulling up at the edge of the cylinder. Works a lot better. Maybe you guys are just slow learners down there. This also gets back to the crowd pleasing end as well. Frankly it would suck to sit out in the heat all day only to have your pilot finish by entering the pattern. Might as well go down to the local community airport and watch the Pipers land. I don't have a crew very often, but when I do, my wife and daughter are happy to see me safely on the ground. They could care less about worm burning finishes... Marc |
#77
I'm with you Casey.
I have continued to do speed passes on all my cylinder finishes when practical. I believe this can be accomplished much more safely than a finish line that is 3000 feet wide, it can also be more dangerous if everyone does it from many directions. All the CD has to say is that all speed passes must be down the runway on one side or the other and the pull up must be at mid field. Pilots failing to do this can be penalized for unsafe flying, no more rules are necessary. This way, everyone, including me knows what to expect and where. Dale Kramer K1 "Kilo Charlie" wrote in message news:J8geb.4528$hp5.3072@fed1read04... We fly 20 contest days per year here in Arizona Marc and every single one of them ends with a one mile cylinder. That means that I have finished over 40 times in our ASA series in the past 2 years with the cylinder that you described so I doubt that you have any more experience than I do with the system. The problem is that you may do your "non-adrenaline junky easy pullup" but most of the pilots that fly contests will NOT be doing that either at one mile, two miles or fifty miles. So the scenario that you described of having someone come under you and pull up has exactly equal potential in your cylinder finish. In fact I would go further and argue that it has MORE potential since some pilots may continue to push fast toward home (you know we dangerous, arrogant, hedonistic types) inside the cylinder then pull with you now wafting around in your extended approach. The rules say nothing about how you are to enter the pattern or when to pull up. But then silly me.....I'm sure that's going to be on the table soon too! This also gets back to the crowd pleasing end as well. Frankly it would suck to sit out in the heat all day only to have your pilot finish by entering the pattern. Might as well go down to the local community airport and watch the Pipers land. Casey Lenox KC Phoenix |
#78
At 05:54 30 September 2003, Gary Ittner wrote:
You obviously think that it is unfair for the landout to be penalized so severely, but have you considered that reducing or eliminating the landout penalty might be unfair to the pilots who do whatever it takes to finish the task? And doing 'whatever it takes' usually does not mean risk-taking, but the antithesis of risk-taking Gary, Yes I think it is unfair to penalize the landout so severely. but doing 'whatever it takes' is exactly that 'What ever it takes takes' and inherently will be as much dangerous as it will be throttle back and go around. And nothing in the way of rules will change that. But the question then is. Is that unfair to those pilots? I don't think so! It still becomes a pilots choice to do either. They will still score more than those that don't think that way. However. consider this if making it back is as important as you seem to feel it is, in terms of competing, then why aren't the rules written so that NO score is given for a landout? Why? Because until recently it was almost impossible to score fairly for the distance AND time. With the flight loggers and computers available now this could become a reality. I realize that you will never be happy with that, and maybe nobody else will be either. And in that case it probably won't happen. But I for one would like to try it! I do agree with you about having the right attitude about learning after being out of contention in a contest. And learning from that experiance. No changes in scoring would change that. 'Attitude is everything' and 'Change is inevitable' One of these you can do something about the other you can't! Cliff Hilty Ventus B |
#79
#80
Marc...I hope that you don't feel that you're being picked on since your
posts always seem to be well thought out and to the point. I wanted to say that I agree with Chip again re the fact that it was the fault of the pilot that flew under you/near you. It is very bad policy to intentionally fly at redline (or any other speed for that matter) through the landing pattern, esp the base or final areas. This season we were actually asked to do this at the Region 9 contest.....they insisted (in spite of protests) that we finish to the west (90 degrees to the active runway), then pullup and turn hard left crossing the runway again and enter a left hand pattern. This resulted in landing pilots on downwind with the later finishers coming at at redline 90 degrees to their path and even worse with their back to them on base leg. Now THAT was dangerous! The point I want to make is that there was a lot of talk on the radio between finishers and landing pilots re position and altitude. I would not want to do it again but it did work out with everyone communicating well. Casey |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Can a Private Pilot tow gliders and get paid? | zatatime | Piloting | 3 | October 17th 04 01:35 AM |
FAA has temporarily withdrawn the proposed Sport Pilot rule | Larry Dighera | Piloting | 2 | March 27th 04 06:23 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
