500 foot rule and pilot opinion poll
Old September 16th 03, 05:59 PM
John Cochrane
Default 500 foot rule and pilot opinion poll
Fellow US pilots:
This year's SRA pilot poll will be on line in a few days. It contains
a question on the 500 foot rule. I urge you to read it, think about
it, and vote. In particular, this is a rule that benefits newer, less
experienced pilots. It doesn't matter much to the top 5 national and
world group, many of whom hate the idea. If you like this idea for
your contests, you have to voice your opinion.
Here is the proposal: before the finish, you have to be above 500 feet
AGL in a donut from 2 miles out to one mile out. If you don't make
this altitude limit, you will be scored for distance points when you
land at the airport. When the actual finish is a line, you may then
dive down and cross the line at the usual altitude.
Why? Sooner or later, you will find yourself in that awful situation,
5-7 miles out at MacCready 0 plus 50 feet. Or maybe minus 50 feet.
You're passing over the last good field, and the last chance to
properly evaluate a field, do a pattern, look for wires, etc. From
here on in, if you don't make it, it's straight in to whatever you
find. Common sense says "stop, look for a thermal, and land in this
good field." But the contest is on the line; 400 points and more call
you to try to pop it in over the fence. This is not fun. It's not
safe. And it's entirely a creation of the rules.
The proposal removes the agonizing points vs. life decision. If you
don't make it with a 500 foot margin, you don't get speed points. Make
your decisions based only on safety. If it's safer to squeak it in to
the airport, do so. If it's safer to land in the good field 5 miles
out, do that. Forget the race.
This proposal is tantamount to moving the airport up 500 feet. The
race is entirely unaffected. A race with the airport located 500 feet
above the surrounding terrain is just as valid, just as fun, and just
as challenging.
The rule is only suggested for regionals, and perhaps only sports
class. It will have to have substantial support from pilots before it
makes it to nationals.
For more details, including accident statistics, see my article "Safer
Finishes" in the October 2002 Soaring. It's also online at my website,
http://gsbwww.uchicago.edu/fac/john....rs/#For_glider
I will also keep updated versions of this message on the website – I'm
sure to hear more objections that I can answer in the FAQ
FAQ:
1. We should leave this to pilot judgment.
We'll never substitute for pilot judgment, and handling the Mc 0 + 50
feet situation will still take lots of judgment.
There is plenty of precedent for rules that remove from "pilot
judgment" decisions that pit safety vs. competitive advantage. We used
to leave gross weight to pilot judgment. Now we impose weight limits,
and drag scales around to contests. We used to leave the question
whether you can relight after a landout to pilot judgment. Now we ban
the practice. We ban cloud flying instruments. And so forth.
Making a low final glide is a maneuver that requires extensive
experience and judgment. While there is a good case that national
level pilots can be expected to have this judgment, this is not the
case for regionals, and especially sports-class regionals, which are
explicitly aimed at newer, less experienced pilots.
2. I love the low pass finish. Don't take all the fun away
This proposal does not eliminate the fun low pass. The actual finish
can still take place over a line, at the usual altitude.
Many pilots think they will end up too high for a proper low finish,
but that is a mistake. If you pass one mile out at 500 feet and 80
kts, you will pass the finish at 50 feet well below redline. It takes
more than 500 feet just to gain the extra speed. Try it – I have.
3. This will lead to unintended consequences that are even worse.
a) Pulling up over the line.
Several pilots complained that a 500 foot finish would lead to pilots
racing in at 200 feet and then popping over the line. Good point.
That's why the proposal is now that you must be over 500 feet for the
whole distance between mile 1 and mile 2. (It is treated like special
use airspace). Now the optimal thing to do is stay above 500 feet the
whole way.
b) Traffic problems.
Perhaps people thermaling at 400 feet just outside the line will
interefere with finishing traffic. Not likely, as this does not happen
now, and all we've done is move the whole business up 500 feet. But
moving from a circle to a donut will further separate finishers from
thermalers, as it eliminates finishers below 500 feet counting on
popping up at the last moment.
c) Heads-down
Experience with the current 500 foot finish in sports class has not
revealed a big heads-down problem. Set your GPS to finish over the
airport at 500 feet. That gives you a 150 foot or so margin over the
donut.
4. This isn't the number one problem.
It isn't. Off field landings and terrain impact are still the number
one problems. Crashes near the airport and from low energy finish are
in the US a distant third.
Sailplane safety does not consist of only attacking the number one
problem. You each problem as a solution comes. Midairs are not the
number one problem, yet we all wear parachutes and look around, and
avoiding midairs is a central concern of all rule making. Assembly
errors are not the number one problem, yet we all do checks and the
rules now require them. If we can improve the #99 problem, at no cost
to the validity or fun of the race, soaring gets a little bit safer.
5. OK, I see that a high finish is a good idea, but losing all speed
points seems awfully harsh. Can't we just tack on a 5 minute penalty
or something?
The key is not the finish, the key is how this looks 5 miles out when
the pilot is passing the last good field. The whole point is to remove
"but if I squeak it in, I'll get all those speed points" from the
mental calculation. The only way to do this is to give essentially the
same points for landing 5 miles out as for squeaking it in to the
airport.
6. Soaring needs a little danger. If you can't stand the heat, get out
of the kitchen.
Several pilots have forcefully stated this opinion. If you think that
physical danger and an occasional fatality are important to keep
soaring exiting, vote against this rule.
Disclaimer: All of this is entirely my own opinion and has no
connection with the rules committee.
John Cochrane (BB)
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Can a Private Pilot tow gliders and get paid? zatatime Piloting 3 October 17th 04 02:35 AM
FAA has temporarily withdrawn the proposed Sport Pilot rule Larry Dighera Piloting 2 March 27th 04 07:23 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 04:58 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
