Heavy pilot & lead in tail
Old January 3rd 04, 01:27 AM
Flyhighdave
Default Heavy pilot & lead in tail
Is it acceptable practice to put lead in a gliders tail to counter the weight
of a large pilot?
David R.
Old January 3rd 04, 01:28 AM
Scott
I've heard of it being done
"Flyhighdave" wrote in message
weight
of a large pilot?
David R.
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old January 3rd 04, 02:03 AM
Udo Rumpf
In the case of an ASW 24 My friend who weighs 230 lb is well over six feet
has a lead weight of six kilo's or 13.2 lb. installed in the fin.
Each glider has or at least should have provisions to install this type of
weight to make sure the glider flies within the required C of G.
Udo
weight
of a large pilot?
David R.
Old January 3rd 04, 02:16 AM
Shawn Curry
of a large pilot?
David R.
Stay within the aft CG limit ;-)
Old January 3rd 04, 05:24 AM
BTIZ
any weight added to the tail.. by means other than factory supplied ballast
weights.. should be noted in the forms.. and the min/max placarded weight
limits in the cockpit updated to reflect the change..
you have effectively changed the "empty" weight and CG of the glider.
BT
weight
of a large pilot?
David R.
Old January 3rd 04, 08:47 AM
Chris Rollings
It's an accepted and widespread practice to put lead
in the tail to get the C of G where you want it. However,
be aware that although a glider with a heavy pilot
and tail ballast may well have the C of G in the same
place as one with a light pilot and no ballast, its
spinning behaviour may well be quite different due
to the greater rotational inertia. In general a glider
with a heavy pilot and tail ballast will have a greater
tendancy for the spin to flatten, and recovery may
be more difficult or at least slower.
Gliders with tail ballast, particularly if carried
fairly high up in the fin, are also more likely to
suffer damage in ground loops.
in the fin.
C of G.
Udo
tail to counter the
weight
of a large pilot?
David R.
Old January 3rd 04, 10:45 AM
Sleigh
The other thing to consider, beside the sensible advice
below is:-
Is the glider able to carry any more weight,over and
above that of the pilot.
Many earlier generation glass gliders Cirrus,Asw15.Libelle,Astir,
the max cockpit weight is limited by the max all up
weight, resulting in cockpit max weights of much less
than 110kg,
The addition of lead in the tail to adjust the C/G
would only result in reducing cockpit load even more
in the fin.
C of G.
Udo
tail to counter the
weight
of a large pilot?
David R.
Old January 3rd 04, 11:24 PM
Mark James Boyd
weight
of a large pilot?
David R.
I flew a twin commander (small twin power plane) which was overly
forward C.G. The owner had removed two large 1960's radios from
the mid/tail. Our A&P simply installed weights in the tailcone.
Personally, I would have an A&P do this kind of installation
in a glider as well. I would also find others who have done so.
I know the Sparrowhawk seems to have three different metals
for interchangable tail stabilizer crossmembers. Perhaps
someone could fabricate some replacement tail part from a
heavier metal?
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 05:39 AM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 06:11 AM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
