The prone postion for tail gunners versus turrets.
Old July 21st 03, 12:40 PM
The Enlightenment
Default The prone postion for tail gunners versus turrets.
American and British aircraft were known for their use of power driven
tail turrets. In the case of British aircraft the aircraft was
designed around the turret. (It must have been effective: British
bombers showed no loss in performance compared to more sexy looking
yank aircraft which seemed to have less nimble but more streamlined
looking tail turrets, the Wellingtons performace was remarkable for
its small engines)
Tail armament was however rare for Russian, Japanese, Italian and
German bombers. When it did appear if usually consisted of a gunner
in the tail or (nose) in a prone position opperating a gun manualy. I
can't see a problem with this except that the allowable movement would
probably be limited to +/- 25 degrees.
The Germans were capable of making power driven turrets and tested
british style rear turrets for the He177. The loss in speed and the
cost in skills short germany must have disuaded them and the fact that
their small 2 engined tactical bombers would not have accepted maned
tale turrets gracefully. It appears that their objective were 400mph
bombers like the Ju 288 with remote control barbetts in the dorsal,
ventral and tail position. (Bomber B due in 1942 failed for reasons
to do with engine delays for unknown reasons). Some german bomber did
have remote controlled tail armament.
Back to the prone position. Intitially this postition seemed poor to
me but then I read the sumarised results of extensive German WW2
research which indicates that it was comfortable for 1 to 1.5 hours
and that the G tollerance in this position was much higher than the G
tollerane of a sitting pilot.
The reseach is sumarised he
http://www.luft46.com/prototyp/berlin9.html
The cost in CD (Coefficnt of Drag) I estimate as follows: 1 meter (40
inch) diameter flat hole of 0.77 m2 area in the tail of an aircraft to
me seems to add a coefficint of drag of about 0.2.
( A bullet has a CD of about 0.30 and a near perfect streamline
0.1-0.05 so I assume the conversion of a strealine tail to a flat cut
off would result in a
Cd = 0.78 x (0.3 - 0.05) = 0.2 on the basis of the kamm effect.
The power this would absorb at 440 mph or 200 meters/second would be
calculated from this.
drag = 1/2 x Cd x Area x air density x speed^2
extra power = drag x speed x 1/prop efficiency.
Doing those caculations for an air density of 0.5 at about 25,000 feet
and a prop efficiency of 0.75 I come up with a maned rear gun
absorbing about 2000N force or 200 kg drag at 200m/sec which would
require 533kW or 700hp.
At 100m/sec spped or 220mph the drag is only 500N (50Kg) and the power
only 66kw or about 100hp.
For 150m/sec or 330mph the firgures a
1150N drag (115kg)
225kw power (300hp)
It seems to me that a 400mph aircaft with tail armament was possible.
I daresay a mosquito would not have suffered too much in speed if the
tail had of been completely redesigned to accomodate a prone tail
gunner. Little other armament would be necessary.
In other words an aircraft so fast it would be very difficult to
intercept and upon which only a tail chase attack would be possible.
It also looks like that speed did not suffer much at speeds below
330mph.
I of course have not include the effect of weight of such an
installation.
