#21
be interesting to know where you where when you saw the B-1...
do you know if there were any IR or VR routes in your area? or were you inside a MOA and trust me.. when down low and fast.. two sets of eyes are looking outside and forward.. BT "C.Fleming" wrote in message ... It sounds like a scary 10-15 seconds! I know the feeling: I too have had close encounters with jets. I've been closer than I would have liked to 737's, F-117's, and a B1-b with its wings fully swept back flying Nap-of-the-Earth. With one 737, I saw its shadow flying directly at mine, but it took several seconds for me to find it. The other 737 was pointed out to me by the Approach controller, but neither of us saw each other. The flight of F-117's I'm sure saw me, for they came up from behind and on my right, and overtook me on a parallel course. They got my heart pounding though! But it was the B1-B about 1,000 feet below flying at nearly the speed of sound that scared the bejeezers out of me! Yes, keep your eyes outside 99% of the time. Feel for the lift, listen to the audio vario, and look outside. Not only does this help keep aluminum off of fiberglass, but it improves your piloting technique as well. A couple of points about the Harriers you encountered though: 1.) They may or may not have been in contact with ATC, and even if they were, there would be no separation requirements between them and you. 2.) Military aircraft do not have the 200 knot limitation under the Class B airspace. 3.) Jet pilots tend not to look outside of the cockpit nearly as much as we do, and even if they did, it would be extremely difficult for them to see us. There was a video made of a near-miss a couple of years ago between an F-16 and a Cessna 172. The footage was from the Heads-Up Display (HUD) of the F-16. They missed by 15 feet, and you had to play the video in slow motion to even see the Cessna. I know those points don't give us a warm and fuzzy feeling, but that's the world we live in. The best advice that I have is to either avoid the areas of high risk, communicate with the controlling agency, or work from within the system to keep the aircraft apart from each other through a Letter of Agreement (LOA). Fly safe, Chris Fleming, 'L9' ATP B-767, CFI-G "Terry Claussen" wrote in message ... I have no idea if they were IFR, nor if they could, should or did comply with the 200 KIAS speed limit under the shelf of the class B. I also have no idea whether either I or the other glider was seen by the lead. After the encounter, I lost my enthusiasm for the flight along with the thermal and worked my way back to the sailport. When I fly with students in this area, I hammer the idea that our piece of the sky is busy due to the natural and man-created boundaries which will force through traffic to overfly our thermal hunting area. So I received yet another reminder that I cannot see everything even part of the time. Were one of the Harriers and me to collide does anyone think that the TV would have the blame anywhere other than me? Let's be careful out there. I think I am, but again I got another chance. Terry Claussen |
"Bill Daniels" wrote in message ...
Actually, if you hear an airplane engine, it's likely that it is directly below you where the sound can reflect back from the ground. I'll now tell my near miss story. Thermalling near Riverside California one day I say a small puff of smoke off to the south. "That's strange", I thought as I continued to circle. Next time around the ball of smoke was still there and it seemed bigger. Several more turns in the thermal and the ball of smoke was getting very pro minent and there was a black dot in the center of it. The smoke was jet exhaust and the black dot turned out to be a B52 with me in his crosshairs. As I dove for clearance, he passed less than 100 feet above me. That was noisy. Bill Daniels Good point, I've listened to the race cars near Turf Soaring many times while working the house thermal, fun to watch them running sideways around the short dirttrack. I once broke hard upon hearing a jet, and turned right into a two-ship of F-16s who were frantically pulling to get away from me! So we all saw each other and waggled wings, and went on our business. OTOH, once while thermalling on the Estrella ridge, just outside a big piece of class B airspace, I watched a Southwest 737 letting down towards me, and after a few turns it was obvious that he and I were going to share a very small piece of sky pretty soon! (Crew must have been heads down getting their before landing checks done). So when they got "close enough", I moved aside, let them by (with a wave), then returned to my thermal, which seemed none the worse for wear. Kind of like a Laser meeting a supertanker - sometimes right of way is the wrong way! But was was scary was that this big 737 cruised by absolutely silently - not a whisper. What if: near cloudbase, poor vis, same place: No warning whatsoever - Wham, tinkle, tinkle. It is really important to know where the heavy and fast iron flies in your area! Cheers! Kirk |
Yeah, I have a published 10nm-wide IR route nearby. It extends from 500 ft
AGL to 7,000 ft MSL. Whenever I head out on cross-countries, I get their status, and plan accordingly. I've seen F-16's and F-117's mostly, but it was the big B1-b that snuck up on me! I try to transit the route as close to 90 degrees and as rapidly as possible. The time with the B1-b had me hit some serious sink 10 minutes before, and I had to thermal in the area; which I never do! The terrain is very rugged (canyons, mountains, and rolling sand dunes), so I have to stay high, usually above 10,000 ft. Chris Fleming, 'L9' El Paso, Texas "BTIZ" wrote in message news:wBETb.7074$IF1.1160@fed1read01... be interesting to know where you where when you saw the B-1... do you know if there were any IR or VR routes in your area? or were you inside a MOA and trust me.. when down low and fast.. two sets of eyes are looking outside and forward.. BT |
Ian Johnston skrev den 3 Feb 2004 04:55:56 -0800:
I am planning to fit a marine aluminium corner cube into the fuselage of the Pirat. It's about 12" on each side, very light, and can be assembled in situ. There more compact reflectors for marine use which are claimed to have larger radar cross sections, but the emphasis has to be on "claimed" there. It'd be interesting to find out what the speed threshold for the doppler radars typically is. Unfortunately, that is not a piece of information they go out of their way to make available. ![]() below the speed of a glider in a thermal? Cheers, Fred |
#28
we have no problems with local ATC radar picking up our Grob 103, LS-4,
Libelle, and of course.. the Schweitzer Iron, 2-33 and 1-26 but they have to be looking at Primary Radar.. and not just the transponders BT "Martin Gregorie" wrote in message ... On 3 Feb 2004 04:55:56 -0800, (Ian Johnston) wrote: (Mark James Boyd) wrote in message news:401ec338$1@darkstar... If radar getting you is a problem, for boats they make fairly compact aluminum "radar reflectors" that are pretty lightweight. Dunno if they'd fit in a tail section though, kinda "ship-in-a-bottle" maybe? I am planning to fit a marine aluminium corner cube into the fuselage of the Pirat. It's about 12" on each side, very light, and can be assembled in situ. There more compact reflectors for marine use which are claimed to have larger radar cross sections, but the emphasis has to be on "claimed" there. Sounds interesting. Can you supply more detail yet, like cost, weight, sources? -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
#29
Fredrik Thörnell wrote:
Ian Johnston skrev den 3 Feb 2004 04:55:56 -0800: I am planning to fit a marine aluminium corner cube into the fuselage of the Pirat. It's about 12" on each side, very light, and can be assembled in situ. There more compact reflectors for marine use which are claimed to have larger radar cross sections, but the emphasis has to be on "claimed" there. It'd be interesting to find out what the speed threshold for the doppler radars typically is. Unfortunately, that is not a piece of information they go out of their way to make available. ![]() or below the speed of a glider in a thermal? Cheers, Fred In an air surveillance radar the doppler information (instantaneous radial velocity) is used primarily to reject stationary targets that creep in via the sidelobes (as opposed to a weather radar which is really interested in all the IRV data it can gather). In my experience the doppler clutter threshold was set very low - say 1 or 2 knots. My experience is military, where the cutoff was set as low as possible to counter the postulated "spiral in at low radial velocity" attack, but I believe ATC radar would also have compelling reasons to keep the doppler cutoff very low (don't want tangential targets disappearing on you). Where gliders are likely to disappear is in the processing of multiple radar returns into tracks. A variety of clutter rejection algorithms can be used, and we never used anything quite as simple as "under X knots, throw it out". We did, however, try very hard to eliminate bird tracks, and glider flight patterns obviously have much in common with certain birds. The distinction is between "visible to ATC" and "tracked by ATC" - and we'd really like to be tracked. In short, I don't think there is any simple answer to at what speed a glider will be tracked by ATC. And while I think using a corner reflector to provide a great big RCS is a great idea, I can still imagine the ATC software thinking, "Hmmm, that must be a GREAT BIG hawk out there...". IMHO, Dave |
#30
On Tue, 3 Feb 2004 16:36:06 UTC, Martin Gregorie
wrote: : On 3 Feb 2004 04:55:56 -0800, (Ian Johnston) : wrote: : I am planning to fit a marine aluminium corner cube into the fuselage : of the Pirat. It's about 12" on each side, very light, and can be : assembled in situ. There more compact reflectors for marine use which : are claimed to have larger radar cross sections, but the emphasis has : to be on "claimed" there. : : Sounds interesting. Can you supply more detail yet, like cost, weight, : sources? Any chandler will sell them. I'm not sure who does mail order these days, as a coupleof big names went bust. Gaelforce in Inverness, maybe, or Jimmy Green in Devon? I think they are about thirty quid and the one I have on the boat weighs less than a pound. Ian |
Indiana National Guard pilot killed in midair collision | Otis Willie | Military Aviation | 0 | June 17th 04 08:08 PM |
Aviation Consumer and Collision Avoidance | BHelman | Products | 52 | April 23rd 04 05:35 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
"China blamed in '01 air collision" | Mike Yared | Naval Aviation | 8 | September 15th 03 05:07 PM |
"China blamed in '01 air collision" | Mike Yared | Military Aviation | 2 | September 14th 03 06:08 PM |
