While I would like to have a transponder installed,
I don't have two necessary items: 1. Money 2. Panel Space My panel isn't overly large and doesn't have room for a B-50 (two holes) AND room for a 'back-up' variometer. So, when I 'splurge' for another instrument, it will be for a B-50 and not a transponder. The B-50 will have to occupy the holes currently filled by a B-40 and a PZL mechanical vario. So, without a transponder, I keep the ATC Arrival/Departure folks apprised to my where-abouts by calling in on the radio and telling them. They respond, 'Glider N124, Squak 42xx (or whatever) and remain clear of the Class C Airspace.' I tell them I don't have a transponder and they politely acknowledge. If they have time, they might look for me with the primary radar. I keep the radio tuned to their frequency when I'm flying near the Class C around Raleigh-Durham Intl Airport and just listen to traffic. Do other pilots monitor the local ATC facility, or do they keep the radio's tuned to 123.3? I prefer to listen to the aircraft talking to ATC than to other glider pilots when there will be more GA and commercial aircraft in the area than gliders. It helps me keep up with the traffic situation. I don't do this on every flight, just the rare ones that take me close to the Class C airspace. And, the next time I plan on attempting the Diamond Goal flight which takes me completely around the Class C airspace, not only will I tune to the ATC frequency, I'll call them on the telephone before I launch just to let them know about my intentions. I'm just wondering if anyone else monitors ATC when near congested airspace? Thanks, Ray Lovinggood Carrboro, North Carolina, USA LS-1d, 'W8' |
Ray Lovinggood wrote:
And, the next time I plan on attempting the Diamond Goal flight which takes me completely around the Class C airspace, not only will I tune to the ATC frequency, I'll call them on the telephone before I launch just to let them know about my intentions. www.duats.com allows one to file a flight plan before the flight. This is pretty useful for the controller, because when you call ATC, he can use your tail number, call up the flight plan, and read the comments section, without clogging the ATC radio frequency with a bunch of dumb questions (where are you going, what type aircraft, if experimental how does it perform, did you get a waiver through "C" without a transponder). I flew transponderless in an experimental to 26 airports in the LA area, including 3 "C" airports last year. I did this in two days. On both days I filed a flight plan, and on contact with ATC, there were no questions because the performance stats and destinations were all right in front of them. On one of the days, I had to call the supervisor to get a waiver one hour before as required by 91.215(d)(3). I got this, but had some confusion later, as the supervisor thought I was asking for an IFR no-transponder waiver, rather than a VFR no-transponder waiver, so despite the VFR checked box on the flight plan, ATC on initial contact started talking to me in IFRspeak. So if you ask for a transponder waiver in "C", make sure you mention it is for VFR flight... I'm just wondering if anyone else monitors ATC when near congested airspace? A disproportionate number of midairs happen in "D" airspace (because the tower controllers have no radar, or just a tiny radar feed screen but the pilots assume the tower is fully responsible for separation). So I'm on the ATC freq when I'm near or above them. I used to be very careful on poor vis days of IFR traffic inbound and their routes, but it seems that super clear days are much more dangerous because the volume of traffic is so much higher. "D" airspace on a sparkly clear saturday at noon is a dangerous place to be (McClellan Palomar is an example). I think monitoring ATC does a good job of helping me pick out SOME targets. The key is to not just fixate on the targets I find this way. ATC may have a second tower freq, or some folks on approach, or I may just be overwhelmed with the radio traffic (especially if I'm gliding). So ATC monitoring is an extra tool for me, but not one I rely on for all traffic, and certainly not if it distracts me from the priority of scanning for traffic and flying my own aircraft. Sometimes, though, I hear "Heavy XYZ, traffic 12 o'clock, two miles, altitude unknown" and I realize they're talking about me. Sometimes I then call up and tell them I am that traffic, at XXX altitude, headed for YYY. I've always gotten good results this way, and once the controller knows the altitude is deconflicted, it eases his workload. I'd recommend pilots announce their altitude and location on whatever freq they are on if they have the extra time, are transponderless and believe there may be a conflict... |
| Thread Tools | |
| Display Modes | |
| SSA petition to allow transponder to be turned off | Eric Greenwell | Soaring | 57 | March 10th 04 01:22 AM |
| Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 3rd 03 12:27 AM |
