alternate carb heat
Old October 18th 04, 10:53 PM
Matt Whiting
Steelgtr62 wrote:
Some British engines used an oil passage through the carb venturi, a far more
elegant solution. However using fuel injection or mounting the carburetor on
top of the engine instead of underneath would largely obviate the problem.
Fuel injection will help a lot, but mounting the carb on top makes
almost no difference.
Matt
Old October 19th 04, 01:37 AM
Dave Hyde
Matt Whiting wrote...
...but he may be referring to turning on the carb heat
after he's already accumulated enough carb ice to noticeably
decrease his RPM.
Yeah, that's it. g No, I'm afraid UltraJohn was right.
I haven't seen anything remotely resembling carb ice,
and from what I've heard it's not very common in RVs.
I get a very slight RPM *drop* with carb heat, presumably
to a slight temperature *rise* from switching to undercowl
air.
Dave 'cold throat' Hyde
"My wallet's fat and so is my head" - Greenday, 'Walking Contradiction
Old October 20th 04, 12:55 AM
Dan Thomas
Matt Whiting wrote in message ...
Matt
The Gipsy Major took its carb heat from up next to the
crankcase. As with using undercowl air, the time between startup and
useable heated air is too long and carb ice can form while warming up.
We see carb ice shortly after startup rather regularly here, and
we live in fairly dry country. Need to pull carb heat soon after
startup some mornings. It's a good thing the exhaust piping heats up
quickly.
Dan
Old October 23rd 04, 07:42 PM
Ray Toews
Thanks for the insightful help, I planned to install some sensors to
check the rise. I think I will glue one rite to the outside of the
carb at the intake for as realistic a measurment as possible.
I use those little automotive outside air temp sensors I buy from
Canadian Tire, I noticed Wally wallmart has them as well but the ones
I bought from wally were celsius only, irritating but not
unsurmountable. They have about six feet of wire and a sticky back
wich seems to hold well.
God bless all the little borocrats who consented to give us the
homebuilt movement.
ray
On 19 Oct 2004 16:55:42 -0700, (Dan
Matt
quickly.
Dan
Old October 28th 04, 06:56 PM
Bob Hoover
Ray Toews wrote in message ...
Canadian Tire,
Dear Ray (and the Group),
Take your outside air temp sensor and hit it with a hammer. Okay,
okay... squeeze it with a pair of pliers. IF (Big IF) IF... you're
lucky, inside you will find a thermistor about the size of a grain of
sand; the the tiny bit of **** that seems to be welded to the wires.
To measure temperature at the carb, drill a hole in it large enough to
accept the thermistor. (#80 works for the little thermistors.) SOP
is one hole just above the throttle plate (if you have a throttle
plate). (If you want to measure inlet air, put a thermistor on the
carb-side of your carb heat box.) Now put a piece of tape over the
hole on the INSIDE of the carb and go find yourself some metal-filled
epoxy. The Good Stuff comes from Kodak, contains silver and transfers
heat with virtually no loss at all. Mix up a dot of it, dip the
thermistor into the epoxy and plug it into the hole. Now let it cure.
(Don't forget to remove the tape.)
You may install a suitable connector, if you wish. Should I mention
that it's a good idea to only drill where the carb is solid metal?
(Nah!)
A carburetor makes a nice refrigerator. Outside air temp has
surprisingly little to do with it. The pressure drop across the
venturi (traditional carb assumed) and gasoline's endothermic
change-of-state is enough to put frost on a can of beer quick like a
bunny. With a suitable temperature probe in place you can sit there
warm & cozy in the cockpit and see it all happen long before the
engine starts running ruff and the Bad Silence ensues. (You may want
to pull out that red knob over there...)
-R.S.Hoover
Old October 29th 04, 01:50 AM
Blueskies
May want to test the thermistor after you free it from the evil probe and before you capture it in the refrigerator....
"Bob Hoover" wrote in message ...
Canadian Tire,
(Nah!)
-R.S.Hoover
Old October 29th 04, 12:41 PM
smjmitchell
Just use a standard K or J type welded junction type thermocouple (i.e. two
wires welded together in a small bead). I would be cautious of any other
type of sensor ... they may have too much mass and will introduce lag or
damping into the readings because of the time required to heat the mass of
the sensor housing.
Also don't bond the thermocouple to the carby housing. You want to measure
the air temperature, not the temperature of the metal inlet flange to the
carby.
Just stick the thermocouple wire into the inlet area - depending on the
engine you can loosen a cable clamp in the alternative air system and just
slide it in and retighten the clamp. I would slide in approx 1" of
thermocouple wire so that the thermocouple is somewhere near the middle of
the inlet hose.
homebuilt movement.
ray
far more
carburetor on
problem.
Matt
quickly.
Dan
Heat treating 4130 RAM Home Built 0 July 18th 04 04:33 PM
Painting and air cooled motor? CitizenX Home Built 5 June 30th 04 12:47 PM
28 volt pitot heat B2431 Home Built 15 April 17th 04 03:25 PM
Heat treating wing ribs Holger Stephan Home Built 13 February 3rd 04 11:59 PM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 03:32 PM
